2 Replies Latest reply on May 23, 2008 1:54 PM by Hermie3
    TOC titles, topic titles and search
    Hermie3
      Suppose you want to create the same structure within TOC books.
      Here's an example of what I mean:
      TOC book: Chapter 1
      --> TOC page: General
      --> TOC page: Procedures
      TOC book: Chapter 2
      For the topic titles of the underlying HTM files, I used the exact same description as for the TOC (Chapter 1, General, Procedures etc.), because I wish to create the exact same navigational structure in both WebHelp (TOC) and PDF format (bookmarks).
      I found that the PDF converter uses the topic titles for bookmarks, whereas the TOC title is being used for WebHelp. That's why I want to maintain the relation beween TOC title and topic title.
      If you perform a search, the search will list the topic titles found.
      Example: Suppose a certain word appears in both 'General' topics (Chapter 1 and Chapter 2), the search will list the topic title 'General' twice:
      General
      General
      This outcome of course doesn't make much sense.
      Is it possible to add additional info to the search outcome, so that you'll get something like e.g:
      General (Chapter 1)
      General (Chapter 2)
      Any advice/suggestions on how to tackle this problem is very much appreciated?
      Herman
        • 1. Re: TOC titles, topic titles and search
          MergeThis Level 4
          Your topic names should be more focused (different), such as Naming (Ch1) Overview, Naming Procedures, Group Naming (Ch2) Overview, Group Naming Procedures, etc.
          While this might originally result in a more cluttered TOC, you can edit those TOC names to the shorter version as in your example.
          Leon
          • 2. Re: TOC titles, topic titles and search
            Hermie3 Level 1
            Hi Leon,
            That's what I initially did.
            I started out with this:
            COGS
            --> COGS General
            --> COGS Procedures
            OPEX
            --> OPEX General
            --> OPEX Procedures
            and I then renamed the TOC names:
            COSG
            --> General
            --> Procedures
            etc.
            That worked fine and a search was showing descriptive topic tiles like 'COGS General' (to my audience that is :-)
            Later on, I noticed that this structure created inconsistencies between WebHelp and Printed Output:
            TOC in WebHelp:
            COSG
            --> General
            --> Procedures
            TOC and BOOKMARKS in PDF:
            COSG
            --> COGS General
            --> GOGS Procedures
