1. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Matthew Laun Jan 18, 2012 12:57 PM (in response to gbjof)This isn't currently possible. The Adobe Viewer code only utilizes the gyroscope or accelerometer to change it's orientation (I believe it's the later as the code was developed to be compatible with iOS 3).
Matthew
2. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
gbjof Jan 18, 2012 1:02 PM (in response to Matthew Laun)Thanks Matthew, so it's not possible to navigate a panoramic photo in a magazine using the gyroscope? I recall seeing an advertisement that animated when the ipad was lifted up, which is why I'm asking.
3. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Matthew Laun Jan 18, 2012 1:10 PM (in response to gbjof)@gbjof,
I've seen things where an animation is set only in one of the orientations (aka layouts) of an article's page, set to play on page load, and changing the orientation thus activates the animation. But if you can find an example that seems to trigger animation based on a device movement that doesn't trigger the orientation change, share it with me and I'll dig into it's guts to see how they do it.
Matthew
4. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Michal Kovar Jan 19, 2012 6:05 AM (in response to Matthew Laun)"...The Adobe Viewer code only utilizes the gyroscope or accelerometer to change it's orientation..." this is not exactly correct.
You can use accelerometer and gyroscope in offline HTML code which you can use in your folio.
See here: http://www.mobilexweb.com/blog/safari-ios-accelerometer-websockets-html5
I tried some examples - and it seems that it works
5. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Johannes Eckert Jan 19, 2012 6:15 AM (in response to Michal Kovar)there are plenty of examples where you can make use of the device's
gyroscope, accelerometer and geo location from within HTML. Mobile Safari
has some Apis that you can read from.
It all need to be done in HTML5 inside your folio (or on a server).
Project magazine had a nice parallax cover, see here:
http://www.youtube.com/watch?v=MMspQHt6ukU
—Johannes
6. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
gbjof Jan 19, 2012 7:43 AM (in response to Johannes Eckert)@Johannes, that's a great example, thank you. Is Project Magazine built in DPS? I'm wondering if I might have to open a web view and host the panoramic there instead of inside of the folio.
7. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Matthew Laun Jan 19, 2012 10:09 AM (in response to Michal Kovar)@Michael,
Thanks for providing the answer. To be clear though, this statement is still true: "...The Adobe Viewer code only utilizes the gyroscope or accelerometer to change it's orientation..." It's the webkit code built into the OS that is performing this effect, not the Adobe Viewer code. Semantics; the key is that it can be incorporated into the DPS platform. The more people recognice how we leverage webkit, the more they can see how to do things that re not natively supported by the Viewer code.
Cheers!
Matthew
8. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Johannes Eckert Jan 19, 2012 10:27 AM (in response to gbjof)@gbjof:
PROJECT is built with WoodWing and might change to DPS later.
(mobil gesendet)
Am 19.01.2012 16:43 schrieb "gbjof" <forums@adobe.com>:
Re: Gyroscope enabled panoramic photo in Digital Publishing Suite created by
gbjof <http://forums.adobe.com/people/gbjof> in Digital Publishing Suite- View
the full discussion <http://forums.adobe.com/message/4151885#4151885>
9. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
johntidis Feb 10, 2012 9:32 AM (in response to gbjof)Hi,
I am trying to use this but I have no luck.!
Can someone help & explain us .. step by step...
what must be done to make this happend ... because a lot of us have a few knowledge of development... -
10. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
gbjof Feb 10, 2012 10:09 AM (in response to johntidis)This is done using js in the HTML file you connect the panoramic file to.
Create a web view, embed the html panoramic with gyroscope code.
11. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Stephen Barrante Feb 22, 2012 9:07 AM (in response to gbjof)(On topic, so I thought I would ask a related question...)
Is the accel/gyro data only accessible and supported in an HTML stack? or will it also work in a Web Area overlay in a standard DPS article?
For instance, our creative team has proposed features like the panorama, or even something as simple as an object hanging down into the page - that they would like to have react with the orientation of the device. However, it's less than desirable to have to move completely to an HTML article simply to support these "bells & whistels", on the cover of the article. I'd rather drag out a rectangle, link it to an HTML page, and have that functionality perform in that space.
A bit crunched on time, otherwise I'd just start experiementing.
Stephen -
12. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Johannes Eckert Feb 22, 2012 9:18 AM (in response to Stephen Barrante)i am pretty sure it should be available in web content as well.
—Johannes
13. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Stephen Barrante Feb 22, 2012 9:33 AM (in response to Johannes Eckert)Thanks Johannes - We'll dive in and see if we can pull together an example.
Cheers
14. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Johannes Eckert Feb 22, 2012 9:41 AM (in response to Stephen Barrante)i found this tutorial very helpful:
http://www.peterfriese.de/how-to-use-the-gyroscope-of-your-iphone-in-a-mobile-web-app/
also, he made a demo site that you can pop into your web content to see the
accelerometer data appear inside your folio:
http://demos.peterfriese.de/gyro/gyro.html
—Johannes
15. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
gbjof Feb 22, 2012 9:49 AM (in response to Johannes Eckert)Try this: http://gardengnomesoftware.com/
It has an option to automatically enable "inertia / gyroscope" in advanced settings.
16. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Stephen Barrante Feb 22, 2012 9:58 AM (in response to gbjof)Thanks - We actually have Pano2VR, is it part of that softare or the Object2VR? And I assume it would be related to exporting the content as an HTML file set. Just took a quick peek into Pano and I didn't specifically see anything related to gyro or accelerometer support.
Thanks for the tip!
17. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
johntidis Feb 22, 2012 1:10 PM (in response to gbjof)Hi gbjof
Can you please give an example of html panoramic with gyroscope code?
Or enyone else ?
THNX
18. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
landrvr1 Nov 29, 2012 9:42 AM (in response to Johannes Eckert)Wow, that Project Mag parallax is pretty amazing. I've hunted for some comprehensive tuts on how to do that but so far only coming up with pieces of info here and there. There's tuts on parallax, and info on gyro, but nothing I can find in terms of bringing the two worlds together. Anyone find anything since this thread began?
I'm actually rather shocked that we aren't seeing a ton of this kind of tut around the web. It's definitely one of the most impressive features of HTML5 and a tablet. Hmm.
Oh, I ran across this site which is really quite something as well. Very cool:
Yowza. Parallax WITH hotspots and zoom. Nice.
19. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
Jason Bernert Dec 5, 2012 10:38 AM (in response to Johannes Eckert)Hi Johannes,
Did you ever find a good way to use the gyroscope Javascript API to control an image?
Also, I use your Adobe DPS HTML5 Boilerplate all the time. Thanks!
-Jason
20. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
landrvr1 Dec 10, 2012 5:09 AM (in response to Jason Bernert)I did manage to get this working using a nice jQuery script I found here:
http://zachholman.com/posts/parallaxing-parallax-on-ios/
You can just save the webpage and it's assets locally and start playing around. Just point to that local html file on an overlay and you can test it immediately.
Here's the thing: While it certainly works and the effect is very cool, it's also very jittery. I cannot figure out how to smooth out the motion. Increasing the framerate works for browsers, but not for iOS - DPS or Safari. I simply lack the scripting knowledge to make it smooth.
The trouble really is the lack of folks doing this and publishing the code/results. There's cool jQuery parallaxing examples like this that work well:
http://torontographic.wordpress.com/2012/08/11/so-you-want-parallax-scrolling-in-ios-ipad- and-ipod/
But integrating the gyro is never included and few people ask about it, lol.
BTW, with the Zach Holman example you can get a parallax going by just setting the x direction motion to 0 on your .png files.
21. Re: Gyroscope enabled panoramic photo in Digital Publishing Suite
nicksed Mar 2, 2014 9:02 AM (in response to landrvr1)Hey ! Could you give me step by step on how to do this ? I'm looking to use the gyroscope to change the orientation on one photo as you move the tablet around.
Thanks !
