14 Replies Latest reply on Jan 26, 2012 4:57 PM by phillipschip
    Photoshop CS5 dissapears when saving files
    phillipschip
      I have been having an issue where the program just dissapears when I try and save a file.  All my work is gone and the program just dissapears in a blink with no error message. It happens many times when opening up the folder to save the file in.
      I have used paid support through Microsoft for 3 sessions and there isn't anything they can come up with because there is no evidence of the crash.  I have tried reinstalling Windows 7 (64-bit) and putting CS5 on just after as the only program running, and it still happened.  All my drivers are up to date.  Any help on this would be greatly appreciated.  Thanks, Chip
        • 1. Re: Photoshop CS5 dissapears when saving files
          phillipschip Level 1
          Also, I have tried deleting preferences many times and this doesn't help.  I have also dissable open Gl in preferences and this didn't help.
          • 2. Re: Photoshop CS5 dissapears when saving files
            Noel Carboni Level 8
            I saw this myself for a while.  Best I could determine it stopped after an update of my display driver from the ATI web site.
            -Noel
            • 3. Re: Photoshop CS5 dissapears when saving files
              D Fosse Adobe Community Professional & MVP
              Huh. Me too - it just stopped...and I'm still on 11.7. Weird.
              Windows update? Was it Windows all the time?
              • 4. Re: Photoshop CS5 dissapears when saving files
                Hudechrome Level 2
                I saw it a long time ago and like Noel and Fosse, it just stopped.I don't recall whether it was XP or Win 7, however. I have it on both. But XP doesn't do this at this date either.
                Welcome to the Twilight Zone (do do, doo, doo!)
                • 5. Re: Photoshop CS5 dissapears when saving files
                  I don't doubt it could have been a Windows update.
                  -Noel
                  • 6. Re: Photoshop CS5 dissapears when saving files
                    I don't have this same problem with PS and XP or Vista on my other machines.  I have received this error in the past couple days a few times, and am not sure if it is related to the problem:
                    Problem signature:
                      Problem Event Name:    APPCRASH
                      Application Name:    Photoshop.exe
                      Application Version:    12.1.0.0
                      Application Timestamp:    4d90d339
                      Fault Module Name:    CoolType.dll
                      Fault Module Version:    5.7.83.12130
                      Fault Module Timestamp:    4d077df9
                      Exception Code:    c0000005
                      Exception Offset:    0000000000143b52
                      OS Version:    6.1.7601.2.1.0.768.3
                      Locale ID:    1033
                      Additional Information 1:    f1cf
                      Additional Information 2:    f1cf8ca4483d410c59eca75064d4325f
                      Additional Information 3:    117e
                      Additional Information 4:    117e5a93546f81b42415b3f8d5103b62
                    I went in and deleted all my fonts that aren't essential to the OS, including all of the Adobe fonts.  I have also deleted my font cache.  One other thing I have done is switched to an Aero theme and enabled "desktop composition".  Not sure if any of this will help, but the problem hasn't happened yet today.  I'll let you know if this has fixed it.
                    • 7. Re: Photoshop CS5 dissapears when saving files
                      Well, given that CoolType.dll is an Adobe component involved in displaying text on your display, your thought to clean up your fonts may be on target, but I'm thinking that if you're not using Aero you're not running things in the most likely tested/debugged configuration.  You haven't changed the default font used for menu displays, etc. (Segoe UI) have you?
                      -Noel
                      • 8. Re: Photoshop CS5 dissapears when saving files
                        Nope, that font still exists.  I only deleted the ones maked "hidden" and even many of those were un-deletable.  My system is pretty bare, and I haven't installed any additional fonts.  I think the only non-stock ones were the Adobe fonts, which I deleted all of.  Hope that's ok.
                        • 9. Re: Photoshop CS5 dissapears when saving files
                          None of that helped.  It is still happening. So frustrating.  Looks like someone else just posted something related to this....
                          • 10. Re: Photoshop CS5 dissapears when saving files
                            Not quite what I asked.
                            Are you using the Windows 7 Aero theme?
                            Have you used the advanced configuration to change any of the settings, e.g., the font used for the display of menus?
                            -Noel
                            • 11. Re: Photoshop CS5 dissapears when saving files
                              Thanks for the response Noel.  Yes, I am using the Windows 7 Aero theme.  I selected "enable desktop composition", "enable transparent glass" and "show thumbnail instead of icons".  Everything else is unckecked.
                              Also, I didn't change any of the fonts used for display.
                              Maybe I'll try "let windows decide what is best for my computer"  instead of unchecking anything for performance and see if that helps.  I don't see why this should make a difference though.  Any thoughts?
                              Chip
                              • 12. Re: Photoshop CS5 dissapears when saving files
                                It's worth a try.  It's not something that would be hard to live with.  You can be sure more software was more fully tested in that configuration.
                                Do you have anything installed to change the look and feel of Windows Explorer?  Any special codecs or anything?
                                -Noel
                                • 13. Re: Photoshop CS5 dissapears when saving files
                                  I don't have anything that is changing the look or feel.  It's all stock right now.  MCEBuddy runs on my system and converts video files when they are recorded from the Media Center.  After the last re-install of Windows from disk, I didn't have this on yet-just PS, and the crashes were happening then, so I came to the conclusion that it wasn't the cause.
                                  • 14. Re: Photoshop CS5 dissapears when saving files
                                    Today I had a crash and got this report info from a little program I installed called AppCrashView.  Can anyone help me with this?  I'm not sure how to use it to figure out what is going on,
                                    Version=1
                                    EventType=BEX64
                                    EventTime=129720988384357402
                                    ReportType=2
                                    Consent=1
                                    ReportIdentifier=761660f7-4880-11e1-8d80-002564d7847d
                                    IntegratorReportIdentifier=761660f6-4880-11e1-8d80-002564d7847d
                                    Response.type=4
                                    Sig[0].Name=Application Name
                                    Sig[0].Value=Photoshop.exe
                                    Sig[1].Name=Application Version
                                    Sig[1].Value=12.1.0.0
                                    Sig[2].Name=Application Timestamp
                                    Sig[2].Value=4d90d339
                                    Sig[3].Name=Fault Module Name
                                    Sig[3].Value=StackHash_60e1
                                    Sig[4].Name=Fault Module Version
                                    Sig[4].Value=0.0.0.0
                                    Sig[5].Name=Fault Module Timestamp
                                    Sig[5].Value=00000000
                                    Sig[6].Name=Exception Offset
                                    Sig[6].Value=000007ff7fe23a20
                                    Sig[7].Name=Exception Code
                                    Sig[7].Value=c0000005
                                    Sig[8].Name=Exception Data
                                    Sig[8].Value=0000000000000008
                                    DynamicSig[1].Name=OS Version
                                    DynamicSig[1].Value=6.1.7601.2.1.0.768.3
                                    DynamicSig[2].Name=Locale ID
                                    DynamicSig[2].Value=1033
                                    DynamicSig[22].Name=Additional Information 1
                                    DynamicSig[22].Value=60e1
                                    DynamicSig[23].Name=Additional Information 2
                                    DynamicSig[23].Value=60e1dbb7fe41a65d81ede1e150bfe328
                                    DynamicSig[24].Name=Additional Information 3
                                    DynamicSig[24].Value=30a2
                                    DynamicSig[25].Name=Additional Information 4
                                    DynamicSig[25].Value=30a2544e880db2a1e036bd2d5f915c09
                                    UI[2]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Photoshop.exe
                                    UI[3]=Adobe Photoshop CS5.1 has stopped working
                                    UI[4]=Windows can check online for a solution to the problem.
                                    UI[5]=Check online for a solution and close the program
                                    UI[6]=Check online for a solution later and close the program
                                    UI[7]=Close the program
                                    LoadedModule[0]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Photoshop.exe
                                    LoadedModule[1]=C:\Windows\SYSTEM32\ntdll.dll
                                    LoadedModule[2]=C:\Windows\system32\kernel32.dll
                                    LoadedModule[3]=C:\Windows\system32\KERNELBASE.dll
                                    LoadedModule[4]=C:\Program Files\AVAST Software\Avast\snxhk64.dll
                                    LoadedModule[5]=C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.760 1.17514_none_2b24536c71ed437a\gdiplus.dll
                                    LoadedModule[6]=C:\Windows\system32\msvcrt.dll
                                    LoadedModule[7]=C:\Windows\system32\USER32.dll
                                    LoadedModule[8]=C:\Windows\system32\GDI32.dll
                                    LoadedModule[9]=C:\Windows\system32\LPK.dll
                                    LoadedModule[10]=C:\Windows\system32\USP10.dll
                                    LoadedModule[11]=C:\Windows\system32\ole32.dll
                                    LoadedModule[12]=C:\Windows\system32\RPCRT4.dll
                                    LoadedModule[13]=C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.616 1_none_08e61857a83bc251\MSVCP90.dll
                                    LoadedModule[14]=C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.616 1_none_08e61857a83bc251\MSVCR90.dll
                                    LoadedModule[15]=C:\Windows\system32\OPENGL32.dll
                                    LoadedModule[16]=C:\Windows\system32\ADVAPI32.dll
                                    LoadedModule[17]=C:\Windows\SYSTEM32\sechost.dll
                                    LoadedModule[18]=C:\Windows\system32\GLU32.dll
                                    LoadedModule[19]=C:\Windows\system32\DDRAW.dll
                                    LoadedModule[20]=C:\Windows\system32\DCIMAN32.dll
                                    LoadedModule[21]=C:\Windows\system32\SETUPAPI.dll
                                    LoadedModule[22]=C:\Windows\system32\CFGMGR32.dll
                                    LoadedModule[23]=C:\Windows\system32\OLEAUT32.dll
                                    LoadedModule[24]=C:\Windows\system32\DEVOBJ.dll
                                    LoadedModule[25]=C:\Windows\system32\dwmapi.dll
                                    LoadedModule[26]=C:\Windows\system32\WS2_32.dll
                                    LoadedModule[27]=C:\Windows\system32\NSI.dll
                                    LoadedModule[28]=C:\Windows\system32\WINSPOOL.DRV
                                    LoadedModule[29]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\AdobeLinguistic.dll
                                    LoadedModule[30]=C:\Windows\system32\PSAPI.DLL
                                    LoadedModule[31]=C:\Windows\system32\SHELL32.dll
                                    LoadedModule[32]=C:\Windows\system32\SHLWAPI.dll
                                    LoadedModule[33]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\cg.dll
                                    LoadedModule[34]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\cgGL.dll
                                    LoadedModule[35]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\adbeape.dll
                                    LoadedModule[36]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\AdobeOwl.dll
                                    LoadedModule[37]=C:\Windows\system32\WTSAPI32.dll
                                    LoadedModule[38]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\AdobeOwlCanvas.dll
                                    LoadedModule[39]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\ahclient.dll
                                    LoadedModule[40]=C:\Windows\system32\WININET.dll
                                    LoadedModule[41]=C:\Windows\system32\Normaliz.dll
                                    LoadedModule[42]=C:\Windows\system32\iertutil.dll
                                    LoadedModule[43]=C:\Windows\system32\urlmon.dll
                                    LoadedModule[44]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\amtlib.dll
                                    LoadedModule[45]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\AXEDOMCore.dll
                                    LoadedModule[46]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\MPS.dll
                                    LoadedModule[47]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\PlugPlug.dll
                                    LoadedModule[48]=C:\Windows\system32\IMM32.DLL
                                    LoadedModule[49]=C:\Windows\system32\MSCTF.dll
                                    LoadedModule[50]=C:\Windows\system32\VERSION.dll
                                    LoadedModule[51]=C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1d f_6.0.7601.17514_none_fa396087175ac9ac\comctl32.dll
                                    LoadedModule[52]=C:\Windows\system32\CRYPTBASE.dll
                                    LoadedModule[53]=C:\Windows\system32\uxtheme.dll
                                    LoadedModule[54]=C:\Windows\system32\STI.DLL
                                    LoadedModule[55]=C:\Windows\system32\CLBCatQ.DLL
                                    LoadedModule[56]=C:\Windows\system32\CRYPTSP.dll
                                    LoadedModule[57]=C:\Windows\system32\rsaenh.dll
                                    LoadedModule[58]=C:\Windows\system32\RpcRtRemote.dll
                                    LoadedModule[59]=C:\Windows\system32\wiatrace.dll
                                    LoadedModule[60]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Photoshop.dll
                                    LoadedModule[61]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\PSViews.dll
                                    LoadedModule[62]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\PSArt.dll
                                    LoadedModule[63]=C:\Windows\system32\c_g18030.dll
                                    LoadedModule[64]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\amtservices.dll
                                    LoadedModule[65]=C:\Windows\system32\IPHLPAPI.DLL
                                    LoadedModule[66]=C:\Windows\system32\WINNSI.DLL
                                    LoadedModule[67]=C:\Windows\system32\WINHTTP.dll
                                    LoadedModule[68]=C:\Windows\system32\webio.dll
                                    LoadedModule[69]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\adobe_caps.dll
                                    LoadedModule[70]=C:\Windows\system32\ntmarta.dll
                                    LoadedModule[71]=C:\Windows\system32\WLDAP32.dll
                                    LoadedModule[72]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\asneu.dll
                                    LoadedModule[73]=C:\Windows\system32\MSIMG32.dll
                                    LoadedModule[74]=C:\Windows\system32\IconCodecService.dll
                                    LoadedModule[75]=C:\Windows\system32\WindowsCodecs.dll
                                    LoadedModule[76]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Extensions\FastCore.8BX
                                    LoadedModule[77]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Extensions\MMXCore.8BX
                                    LoadedModule[78]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\libmmd.dll
                                    LoadedModule[79]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Extensions\MultiProcessor Support.8BX
                                    LoadedModule[80]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\PLUGIN.dll
                                    LoadedModule[81]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\ADM\ADMPlugin.apl
                                    LoadedModule[82]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\QuickTimeGlue.dll
                                    LoadedModule[83]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\AdobeXMP.dll
                                    LoadedModule[84]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Perfect Resize 7.0 Professional Edition.plugin\GFFormat.8li
                                    LoadedModule[85]=C:\Windows\SYSTEM32\MSCOREE.DLL
                                    LoadedModule[86]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\onOneCoreFoundation.dll
                                    LoadedModule[87]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\icuuc42.dll
                                    LoadedModule[88]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\icudt42.dll
                                    LoadedModule[89]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\icuin42.dll
                                    LoadedModule[90]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\onOneToolBox2.dll
                                    LoadedModule[91]=C:\Windows\system32\COMDLG32.dll
                                    LoadedModule[92]=C:\Windows\system32\OLEACC.dll
                                    LoadedModule[93]=C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.616 1_none_08e61857a83bc251\msvcm90.dll
                                    LoadedModule[94]=C:\Program Files\Common Files\Adobe\Plug-Ins\CS5\File Formats\Camera Raw.8bi
                                    LoadedModule[95]=C:\Windows\system32\WINMM.dll
                                    LoadedModule[96]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\dvaadameve.dll
                                    LoadedModule[97]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\boost_threads.dll
                                    LoadedModule[98]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\dvacore.dll
                                    LoadedModule[99]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\dvaui.dll
                                    LoadedModule[100]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\BIB.dll
                                    LoadedModule[101]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\BIBUtils.dll
                                    LoadedModule[102]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\ACE.dll
                                    LoadedModule[103]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\AGM.dll
                                    LoadedModule[104]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\CoolType.dll
                                    LoadedModule[105]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\AXE8SharedExpat.dll
                                    LoadedModule[106]=C:\Windows\system32\mscms.dll
                                    LoadedModule[107]=C:\Windows\system32\USERENV.dll
                                    LoadedModule[108]=C:\Windows\system32\profapi.dll
                                    LoadedModule[109]=C:\Windows\system32\icm32.dll
                                    LoadedModule[110]=C:\Windows\System32\msxml6.dll
                                    LoadedModule[111]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Nik Software\Selective Tool\SelectivePalette.8li
                                    LoadedModule[112]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\aif_core.dll
                                    LoadedModule[113]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\tbb.dll
                                    LoadedModule[114]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\aif_ogl.dll
                                    LoadedModule[115]=C:\Windows\system32\nvoglv64.DLL
                                    LoadedModule[116]=C:\Windows\system32\WINTRUST.dll
                                    LoadedModule[117]=C:\Windows\system32\CRYPT32.dll
                                    LoadedModule[118]=C:\Windows\system32\MSASN1.dll
                                    LoadedModule[119]=C:\Windows\system32\wbem\wbemprox.dll
                                    LoadedModule[120]=C:\Windows\system32\wbemcomn.dll
                                    LoadedModule[121]=C:\Windows\system32\wbem\wbemsvc.dll
                                    LoadedModule[122]=C:\Windows\system32\wbem\fastprox.dll
                                    LoadedModule[123]=C:\Windows\system32\NTDSAPI.dll
                                    LoadedModule[124]=C:\Windows\system32\apphelp.dll
                                    LoadedModule[125]=C:\Windows\system32\wpdshext.dll
                                    LoadedModule[126]=C:\Windows\System32\shdocvw.dll
                                    LoadedModule[127]=C:\Windows\system32\PROPSYS.dll
                                    LoadedModule[128]=C:\Windows\System32\ieframe.dll
                                    LoadedModule[129]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Extensions\ScriptingSupport.8li
                                    LoadedModule[130]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\ExtendScript.dll
                                    LoadedModule[131]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\ScCore.dll
                                    LoadedModule[132]=C:\Windows\system32\WINSTA.dll
                                    LoadedModule[133]=C:\Program Files\AVAST Software\Avast\ashShA64.dll
                                    LoadedModule[134]=C:\Windows\system32\msi.dll
                                    LoadedModule[135]=C:\Users\Chip\AppData\Roaming\Dropbox\bin\DropboxExt64.14.dll
                                    LoadedModule[136]=C:\Windows\system32\dbghelp.dll
                                    LoadedModule[137]=C:\Windows\system32\msvcp60.dll
                                    LoadedModule[138]=C:\Windows\system32\EhStorShell.dll
                                    LoadedModule[139]=C:\Windows\system32\ntshrui.dll
                                    LoadedModule[140]=C:\Windows\system32\srvcli.dll
                                    LoadedModule[141]=C:\Windows\system32\cscapi.dll
                                    LoadedModule[142]=C:\Windows\system32\slc.dll
                                    LoadedModule[143]=C:\Program Files\Common Files\Adobe\APE\3.101\adbeapecore.dll
                                    LoadedModule[144]=C:\Windows\system32\SXS.DLL
                                    LoadedModule[145]=C:\Program Files\Common Files\Adobe\APE\3.101\AdobeSWFL.dll
                                    LoadedModule[146]=C:\Windows\system32\DSOUND.dll
                                    LoadedModule[147]=C:\Windows\system32\POWRPROF.dll
                                    LoadedModule[148]=C:\Windows\system32\DNSAPI.dll
                                    LoadedModule[149]=C:\Windows\system32\mlang.dll
                                    LoadedModule[150]=C:\Windows\system32\Secur32.dll
                                    LoadedModule[151]=C:\Windows\system32\SSPICLI.DLL
                                    LoadedModule[152]=C:\Windows\system32\credssp.dll
                                    LoadedModule[153]=C:\Windows\system32\schannel.DLL
                                    LoadedModule[154]=C:\Windows\system32\MMDevAPI.DLL
                                    LoadedModule[155]=C:\Windows\system32\wdmaud.drv
                                    LoadedModule[156]=C:\Windows\system32\ksuser.dll
                                    LoadedModule[157]=C:\Windows\system32\AVRT.dll
                                    LoadedModule[158]=C:\Windows\system32\AUDIOSES.DLL
                                    LoadedModule[159]=C:\Windows\system32\msacm32.drv
                                    LoadedModule[160]=C:\Windows\system32\MSACM32.dll
                                    LoadedModule[161]=C:\Windows\system32\midimap.dll
                                    LoadedModule[162]=C:\Windows\system32\mswsock.dll
                                    LoadedModule[163]=C:\Windows\System32\wshtcpip.dll
                                    LoadedModule[164]=C:\Windows\System32\wship6.dll
                                    LoadedModule[165]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\updaternotifications.dll
                                    LoadedModule[166]=C:\Windows\system32\NETAPI32.dll
                                    LoadedModule[167]=C:\Windows\system32\netutils.dll
                                    LoadedModule[168]=C:\Windows\system32\wkscli.dll
                                    LoadedModule[169]=C:\Windows\system32\taskschd.dll
                                    LoadedModule[170]=C:\Program Files (x86)\Common Files\Adobe\CS5.5ServiceManager\lib\ServiceManager-Launcher_x64.dll
                                    LoadedModule[171]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\WRServices.dll
                                    LoadedModule[172]=C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll
                                    LoadedModule[173]=C:\Windows\system32\NetworkExplorer.dll
                                    LoadedModule[174]=C:\Windows\System32\StructuredQuery.dll
                                    LoadedModule[175]=C:\Windows\system32\actxprxy.dll
                                    LoadedModule[176]=C:\Program Files\Internet Explorer\ieproxy.dll
                                    LoadedModule[177]=C:\Windows\system32\thumbcache.dll
                                    LoadedModule[178]=C:\Windows\system32\SearchFolder.dll
                                    LoadedModule[179]=C:\Windows\system32\samcli.dll
                                    LoadedModule[180]=C:\Windows\system32\SAMLIB.dll
                                    LoadedModule[181]=C:\Windows\system32\windowscodecsext.dll
                                    LoadedModule[182]=C:\Windows\system32\XmlLite.dll
                                    LoadedModule[183]=C:\Windows\system32\LINKINFO.dll
                                    LoadedModule[184]=C:\Windows\system32\mssprxy.dll
                                    LoadedModule[185]=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\FileInfo.dll
                                    LoadedModule[186]=C:\Windows\system32\PhotoMetadataHandler.dll
                                    FriendlyEventName=Stopped working
                                    ConsentKey=BEX64
                                    AppName=Adobe Photoshop CS5.1
                                    AppPath=C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Photoshop.exe
