3 Replies Latest reply on Jan 20, 2012 8:38 AM by Scott Brodersen
    get content of custom component rendtion
    kasq Level 3
      I have question related to getting content of custom component rendition.
      I have something like contentpage component where I defined contentpage.jsp and test.jsp which creates a custom rendition retrieving from a page only some parts of this page.
      For example if I have example.html created from contentpage component like:
      <html>
          <head>
          </head>
          <body>
              <div id="ex">Some content example ...</div>
              <div id="ex1">Some content example 1</div>
              <div id="ex2">Some content example 2</div>
          </body>
      </html>
      my test.jsp creates only following example.test.html rendition:
      My question is - how using CQ API gets in the java code to some String property content of the example.test.html to have something like:
      String rendContent = "<div id="ex1">Some content example 1</div>";
      Thanks a lot for any answer or suggestion.
      Regards,
      kasq
        • 1. Re: get content of custom component rendtion
          Scott Brodersen Level 4
          Could you store the various strings as node properties, and then retrieve the node property from test.jsp?
          • 2. Re: get content of custom component rendtion
            kasq Level 3
            Hi Scott,
            I can store this strings as a node property, but how to achieve this? I mean maybe you could give some simple code how to create new property for specific node?
            • 3. Re: get content of custom component rendtion
              Say I make a component /apps/geometrixx/components/example:
              • Under the example node, I create another node called examplecontent, of type nt:unstructured.
              • In examplecontent, I create 3 String properties witth the following name/value:
                • example1/The text for example 1
                • example2/The text for example 2
                • example3/The text for example 3
              • example.jsp has the following code that displays the value of the example1 property:
              <%--    Example component.  --%><%
              %><%@include file="/libs/foundation/global.jsp"%><%
              %><%@page session="false" %><%
              <h1>Example page</h1>
              <%=currentNode.getNode("../../../../../apps/geometrixx-outdoors/components/example/examplecontent").getProperty("example1").getString() %>
              </body> </html>
