9 Replies Latest reply: Jul 1, 2014 7:37 PM by alanda RSS
    Decode Compressed 2d Barcode PDF417
    pmoralesm Community Member
      Hi All,
      I have a form and I'm using a PDF417 barcode to store all XML data.
      The form is big and I need to compress data.
      That is the part I already did... What I need now is how to uncompress
      the data in workbench after I use Decode operation from Barcoded Forms
      and save the XML.
      After decode I got binary data...
      How can I uncompress a compressed PDF417?...
      thanks to all
        • 1. Re: Decode Compressed 2d Barcode PDF417
          g5spark Community Member
          You dont have to do anything different to decompress.
          In workbench, what is your output variable on the Barcode.Decode step?
          Is it defined as xml?
          Did you print+scan your input file?  The Barcode.Decode can't read the barcode from a interactive form.  It must be flattened, no xml hierarchy.
          What does the adobe.log say when you run it?
          • 2. Re: Decode Compressed 2d Barcode PDF417
            Hi
            You are correct, it decompress with no problem---
            But I have another issue, if I use an external program I got an XML with
            binary data inside wich is the pdf417 content.
            How can I uncompress it using C# without using any LC service?...
            2012/1/19 g5spark <forums@adobe.com>
               Re: Decode Compressed 2d Barcode PDF417  created by g5spark<http://forums.adobe.com/people/g5spark>in
            LiveCycle Barcoded Forms ES - View the full discussion<http://forums.adobe.com/message/4151954#4151954>
            • 3. Re: Decode Compressed 2d Barcode PDF417
              binary data passed in a xml is encoded in base64 but i dont think thats your problem.  If it is, then you need to convert it back to binary.
              I dont know c#, but i did find this..
              Syste.Convert.ToBase64String(toEncodeAsBtytes)
              System.Convert.FromBase64String(encodedData)
              I think your problem is that you dont know how the data was compressed in the barcode.  In otherwords, if you created the pdf form in designer and checked the compress data parameter then the LC Barcode.Decode will be able to decompress it.  If some other program compressed it, LC Barcode.Decode isn't going to know what compression algorithm was used to compress it, so it wont be able to decompress it.
              • 4. Re: Decode Compressed 2d Barcode PDF417
                Exactly!  The problem now is to decode outside LC using C#. I don't know if
                the content of the compressed barcode is in base64 or not, maybe is just
                zipped.
                I'll try to find out...
                LiveCycle Barcoded Forms ES - View the full discussion<http://forums.adobe.com/message/4152319#4152319>
                • 5. Re: Decode Compressed 2d Barcode PDF417
                  Take a look at this website
                  http://www.motobit.com/util/base64-decoder-encoder.asp
                  Is the content of your binary in characters alphanumeric?
                  /9j/4AAQSkZJRgABAQAAAQABAAD//gA8Q1JFQVRPUjogZ2QtanBlZyB2MS4wICh1c2luZyBJSkcg
                  SlBFRyB2NjIpLCBxdWFsaXR5ID0gMTAwCv/bAEMAAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB
                  AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAf/bAEMBAQEBAQEBAQEBAQEBAQEB
                  OR is it a bunch of letters, and symbols?
                  ÿØÿà  JFIF          ÿþ <CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 100
                  ÿÛ C        ÿÛ C        ÿÀ    X   "       ÿÄ
                  ÿÄ µ                }        !1A  Qa "q 2‘¡ #B±Á RÑð$3br‚
                       %&'()*456789:CDEFGHIJSTUVWXYZcdefghijstuvwxyzƒ„…†‡ˆ‰Š’“”•–—˜™š¢£¤¥¦§¨©ª²³´µ¶·¸¹ºÂÃÄÅÆÇÈÉÊ ÒÓÔÕÖרÙÚáâãäåæçèéêñòóôõö÷øùúÿÄ
                  The 1st one is base64.  The 2nd is binary.
                  • 6. Re: Decode Compressed 2d Barcode PDF417
                    Lee Anthony
                    There is a trick to the compression and decompression for the barcode. The barcode itself is FLATE compressed. However, you need to drop the first 2 bytes of the data stream to DEFLATE the data outside of LiveCycle.
                    Lee.
                    • 7. Re: Decode Compressed 2d Barcode PDF417
                      Thanks Lee for your help,
                      I've attached 1 xml file, there is one field that has a property called
                      value that has the compressed "data"... I have to convert that data into
                      the original xml data...
                      The original uncompressed data I have to obtain from the compressed data is
                      the following:
                      Again, thanks for any tips you can give me...
                      Pablo
                      • 8. Re: Decode Compressed 2d Barcode PDF417
                        Lee Anthony Community Member
                        Pablo, if you are able to extract XML from the barcode decode then technically, you should have your data. Again, dropping the first 2 bytes of the data stream before you run the data through a DEFLATE process should provide you with the extracted data you're looking for.
                        • 9. Re: Decode Compressed 2d Barcode PDF417
                          alanda
                          Have you ever read this post? It seems someone posted the same PDF 417 barcode decoding question here.
                          Google Groups
