36 Replies Latest reply on Mar 23, 2017 9:36 AM by Marc Autret
    Search document for SpecialCharacters Enumerator
    TᴀW Adobe Community Professional & MVP
      I've placed a Word document that has loads of irritating Unicode markers
      (left-to-right etc.)
      There is no way that I can see of using the UI to search and delete
      these characters.
      The unicode value of these markers is: 0x200E as it appears from the
      Info palette, but that Unicode value is shared by various things.
      Selecting a marker and get its contents (app.selection[0].contents)
      returns the number: 1399616109. This is in fact the number for
      SpecialCharacters.LEFT_TO_RIGHT_MARK.
      To cut a long story short and make a specific question general:
      How do you search for a SpecialCharacter that doesn't have an escape
      code in the GREP find/replace?
      What I've done so far is looped through all the characters in the
      document and compared their contents to 1399616109. But this is very
      slow, and is also causing InDesign to crash.
      Is there a better way?
      Ariel
        • 1. Re: Search document for SpecialCharacters Enumerator
          Marc Autret Level 4
          Hi Ariel,
          Use the Unicode code point in the GREP F/R field this way:
          \x{200E}
          See also:
          http://www.indiscripts.com/post/2009/07/idcs4-special-characters
          Marc
          • 2. Re: Search document for SpecialCharacters Enumerator
            Hi Marc,
            Thank you. I couldn't find that documented anywhere.
            Ariel
            • 3. Re: Search document for SpecialCharacters Enumerator
              Marc Autret Level 4
              To complete my previous post:
              1) Given a Character myChar whose contents property returns a SpecialCharacter enumerator, you can still retrieve the Unicode codepoint using myChar.texts[0].contents instead of myChar.contents:
              alert( myChar.texts[0].contents.charCodeAt(0).toString(16) ); // => Unicode CP (hexa)
              2) Since ID CS5 the Enumeration objects (Locale, SpecialCharacters, etc.) describe a set of Enumerator objects rather than a set of numbers. An Enumerator is a special native object which converts itself into either a String or a Number depending on the context:
              // ID CS5+
              alert( SpecialCharacters.emDash ); // => EM_DASH (string)
              alert( +SpecialCharacters.emDash ); // => 1397058884 (number)
              In fact, these respectively correspond to myEnumerator.toString() and myEnumerator.valueOf():
              // ID CS5+
              var myEnumerator = SpecialCharacters.emDash;
              alert( myEnumerator.toString() ); // => EM_DASH (string)
              alert( myEnumerator.valueOf() ); // => 1397058884 (number)
              But every Enumerator has its == and === operators overriden so as we can still compare it with a number:
              alert( SpecialCharacters.emDash==1397058884 ); // => true
              alert( SpecialCharacters.emDash===1397058884 ); // => true
              Also, an Enumeration object see both the camelcase and the uppercase name of an enumerator as a regular own property:
              // ID CS5+
              alert( SpecialCharacters.hasOwnProperty('emDash') ); // => true
              alert( SpecialCharacters.hasOwnProperty('EM_DASH') ); // => true
              Both are [[enumerable]] but the for-in loop only collects the uppercase forms ('EM_DASH', etc.).
              Marc
              • 4. Re: Search document for SpecialCharacters Enumerator
                Trevorׅ Adobe Community Professional
                Hi Marc or anybody else who knows
                Is there a way of getting the full Enumeration string, i.e. SpecialCharacters.EM_DASH and not just EM_DASH ?
                Regards
                Trevor
                • 5. Re: Search document for SpecialCharacters Enumerator
                  Harbs. Level 6
                  Huh?
                  I'm not sure what you are asking...
                  • 6. Re: Search document for SpecialCharacters Enumerator
                    Hi Harbs
                    If I want to get the Enumeration value for an object I could use for example.
                    app.selection[0].appliedParagraphStyle .diacriticPosition*1
                    I would get back the value for example 1685090164
                    To get the string of the enumaration I can use
                    app.selection[0].appliedParagraphStyle .diacriticPosition.toString()
                    this will return OPENTYPE_POSITION (will also return this without the toString but the toString prevents it revering back to a numeric)
                    If I were to enter app.selection[0].appliedParagraphStyle .diacriticPosition = 1685090164 that's going to work
                    but if I enter app.selection[0].appliedParagraphStyle .diacriticPosition = OPENTYPE_POSITION that's not going to work.
                    In this non-numeric form I need to enter app.selection[0].appliedParagraphStyle .diacriticPosition = DiacriticPositionOptions.OPENTYPE_POSITION
                    Is there a way of "Extracting" this term DiacriticPositionOptions ?
                    I hope that's clear (have my doubts) if still not clear I have a script that I can post that should make it clear.
                    Trevor
                    • 7. Re: Search document for SpecialCharacters Enumerator
                      I think it might be useful to include this script.
                      I preduces a "manual" of how to set the properties of a selected object (between 40 to 100 pages of properties).
                      The script is not finished but works quite nicely.
                      Select an object / text / something and then run the script. Takes about 30 seconds to run.
                      If I say so myself it's quite a nice not script
                      Let me know if all clear.
                      #target "indesign"
                      #targetengine "main"
                      myDoc = app.activeDocument;
                      mySelection=app.selection[0]
                      pl=""
                          myProperties=mySelection;
                          myPropertiesString="app.selection[0]";
                      //mo = new Object
                      //mo = {a:4, b:5, c:{q:5, w:8, ss:"foo", fred:{we:5,fh:65}}, d:10};
                      s=""
                      ss=0;
                      myObjConstructor=myProperties.constructor.name.toString();
                      n = (myObjConstructor[0]=="A" ||myObjConstructor[0]=="E" ||myObjConstructor[0]=="I" ||myObjConstructor[0]=="O" ||myObjConstructor[0]=="U") ?
                      "n ": " ";
                      s="* "+myPropertiesString+" is a"+n+myObjConstructor+" *\r\r";
                      elem(myProperties,myPropertiesString)
                      function elem(obj, subObj)
                      var oldSubObj = subObj;
                      var p=0
                      var y=[]
                      var z = []
                      for (x in obj)
                      { ++p
                          y[p]=x
                      ss++;
                      try { (obj[x]!=null) ? z[p]=obj[x] : z[p]="nullnulllnull";} catch (notApplicable) {z[p]="null"}
                      try {zz= z[p].properties} catch (np) {zz=z[p].constructor.name; /*alert(z[p])*/};
                      zzz=z[p].constructor.name;
                      szp=(zzz=="Enumerator") ? z[p].toString() + " or ":"";
                      if (z[p]!=null)
                          { if     (zz=="[object Object]" )
                              if( y[p] !="parent"&& y[p] !="parentStory"
                              && y[p] !="startTextFrame"  && y[p] !="endTextFrame"
                              && y[p] !="nextTextFrame"  && y[p] !="previousTextFrame"
                              && y[p]!="nextStyle" && y[p]!="previousStyle"
                              && y[p]!="pageStart" && y[p]!="pageEnd"
                              && y[p]!="index" && y[p]!="index")
                              var sz=(subObj+"."+y[p].toString())
                              s+=subObj+" ."+y[p]+" = "+z[p]+"\t"+zz+"\t"+zzz+" *\r";
                            eval("elem("+sz+",'"+sz+"');");
                        else   {s+=subObj+" ."+y[p]+" = "+szp+z[p]+"\t"+zz+"\t"+zzz+"\r";subObj = oldSubObj ;}
                      } else  {s+=subObj+" ."+y[p]+" = "+szp+z[p]+"\t"+zz+"\t"+zzz+"\r"; subObj = oldSubObj ;}
                      myContents=s;
                      myDoc = app.documents.add();
                      app.activeDocument.layoutWindows[0].screenMode = ScreenModeOptions.PRESENTATION_PREVIEW;
                      oldUnits=app.scriptPreferences.measurementUnit;
                      app.scriptPreferences.measurementUnit=MeasurementUnits.MILLIMETERS;
                      myDoc.documentPreferences.properties =
                      {facingPages:0, intent:DocumentIntentOptions.PRINT_INTENT, pageHeight:210,
                         pageWidth:297, pageOrientation:PageOrientation.LANDSCAPE}
                      setUpStyles();
                      mastertextFrames = myDoc.masterSpreads.item("A-Master").textFrames.add
                      ({geometricBounds: [200,0,210,297], contents:SpecialCharacters.AUTO_PAGE_NUMBER});
                      mastertextFrames.parentStory.paragraphs[0].justification=Justification.CENTER_ALIGN
                      mastertextFrames.duplicate([297,200])
                       myTextFrame = app.activeWindow.activePage.textFrames.add({geometricBounds:[12, 12, 198, 285], strokeWeight:0, strokeColor:"None"});
                      myTextFrame.parentStory.appliedParagraphStyle=mps
                      myTextFrame.parentStory.contents=myContents
                      while (myTextFrame.overflows) {addPage(myTextFrame)}
                      function addPage(prevTextFrame)
                          myPage = myDoc.pages.add();
                          myTextFrame = myPage.textFrames.add({geometricBounds:[12, 12, 198, 285], strokeWeight:0, strokeColor:"None"});
                          myTextFrame.previousTextFrame = prevTextFrame;
                      function setUpStyles()
                          mcs=myDoc.characterStyles.add({name:"Value", fillColor:"Black", appliedFont:"Minion Pro", fontStyle:"Bold"});
                          mcs2=myDoc.characterStyles.add({name:"Properties", fillColor:"Black", appliedFont:"Minion Pro", fontStyle:"Bold Cond"});
                          mcs3=myDoc.characterStyles.add({name:"Property", fillColor:"Black", appliedFont:"Minion Pro", fontStyle:"Bold Italic", horizontalScale:115});
                          mcs4=myDoc.characterStyles.add({name:"Object", pointSize:6, underline:1});
                          mps=myDoc.paragraphStyles.add({name:"main", pointSize:3.5, fillColor:"C=0 M=100 Y=0 K=0", appliedFont:"Minion Pro", fontStyle:"Medium", justification:Justification.LEFT_ALIGN,
                          paragraphDirection:ParagraphDirectionOptions.LEFT_TO_RIGHT_DIRECTION, digitsType:DigitsTypeOptions.ARABIC_DIGITS})
                      mps.nestedGrepStyles.add({appliedCharacterStyle:mcs4, grepExpression:".+?\\*$"});
                      mps.nestedGrepStyles.add({appliedCharacterStyle:mcs, grepExpression:"(?<=\=).+?\\t"});
                      mps.nestedGrepStyles.add({appliedCharacterStyle:mcs2, grepExpression:"^\\S+"});
                      mps.nestedGrepStyles.add({appliedCharacterStyle:mcs3, grepExpression:"(?<=\s).+? \="});
                      app.activeWindow.activePage = app.activeDocument.pages[0];
                      • 8. Re: Search document for SpecialCharacters Enumerator
                        Harbs. Level 6
                        You can use Enum.valueOf() to get the numeric value.
                        • 9. Re: Search document for SpecialCharacters Enumerator
                          But I don't want the numeric value I want the full enumaration string i.e.
                          DiacriticPositionOptions.OPENTYPE_POSITION as apposed to just OPENTYPE_POSITION
                          Did you run the script?
                          • 10. Re: Search document for SpecialCharacters Enumerator
                            Hi Trevor,
                            I know that this thread is more than four years old, but today Marc Autret linked to it.
                            To answer your question—if it is not answered yet—I think, you should study Dirk Becker's enumToSource.jsx script:
                            enumToSource.jsx script for Adobe InDesign
                            Best,
                            Uwe
                            • 11. Re: Search document for SpecialCharacters Enumerator
                              Hi Uwe
                              I did get the answer a few years back.
                              I wrote the below myself before seeing Dirks version (not nicked).
                              From what I remember my version has some plus points, I think that Dirk's breaks if the Enum was removed from InDesign and my one doesn't but I really don't remember well.
                              Thanks either way
                              Trevor
                              // script to show most of the selection properties by Trevor
                              // Creative-Scripts.Com (Still not ready!) available (sometimes) for custom scripts $$$
                              // scripts {at} Creative-Scripts [dot] Com
                              $.level = 0; // set debug mode to allow try catch (not read only as stated in manual);
                              var e;
                              $.writeln(getEnum(app.wordRTFImportPreferences.resolveCharacterStyleClash));
                              function getEnum(prop) {
                                  var p, n, c, i;
                                  getEnum.enums = getEnum.enums || {
                                      AcrobatCompatibility: true,
                                      AddPageOptions: true,
                                      AdornmentOverprint: true,
                                      AlignDistributeBounds: true,
                                      AlignOptions: true,
                                      AlignmentStyleOptions: true,
                                      AlternateGlyphForms: true,
                                      AlternatingFillsTypes: true,
                                      AnchorPoint: true,
                                      AnchorPosition: true,
                                      AnchoredRelativeTo: true,
                                      AnimationEaseOptions: true,
                                      AnimationPlayOperations: true,
                                      AntiAliasType: true,
                                      ArrangeBy: true,
                                      ArrowHead: true,
                                      AssetType: true,
                                      AssignmentExportOptions: true,
                                      AssignmentStatus: true,
                                      AutoEnum: true,
                                      AutoSizingReferenceEnum: true,
                                      AutoSizingTypeEnum: true,
                                      BalanceLinesStyle: true,
                                      BaselineFrameGridRelativeOption: true,
                                      BaselineGridRelativeOption: true,
                                      BehaviorEvents: true,
                                      BevelAndEmbossDirection: true,
                                      BevelAndEmbossStyle: true,
                                      BevelAndEmbossTechnique: true,
                                      BindingOptions: true,
                                      BitmapCompression: true,
                                      BlendMode: true,
                                      BlendingSpace: true,
                                      BookContentStatus: true,
                                      BookletTypeOptions: true,
                                      BoundingBoxLimits: true,
                                      BuildingBlockTypes: true,
                                      BulletCharacterType: true,
                                      BulletListExportOption: true,
                                      Capitalization: true,
                                      ChangeBackgroundColorChoices: true,
                                      ChangeCaseOptions: true,
                                      ChangeConditionsModes: true,
                                      ChangeMarkings: true,
                                      ChangeTextColorChoices: true,
                                      ChangeTypes: true,
                                      ChangebarLocations: true,
                                      ChangecaseMode: true,
                                      ChapterNumberSources: true,
                                      CharacterAlignment: true,
                                      CharacterCountLocation: true,
                                      CharacterDirectionOptions: true,
                                      ClippingPathType: true,
                                      ColorModel: true,
                                      ColorOutputModes: true,
                                      ColorRenderingDictionary: true,
                                      ColorSettingsPolicy: true,
                                      ColorSpace: true,
                                      ComposeUsing: true,
                                      CompressionQuality: true,
                                      ConditionIndicatorMethod: true,
                                      ConditionIndicatorMode: true,
                                      ConditionUnderlineIndicatorAppearance: true,
                                      ContainerType: true,
                                      ContentType: true,
                                      ContourOptionsTypes: true,
                                      ConvertPageBreaks: true,
                                      ConvertShapeOptions: true,
                                      ConvertTablesOptions: true,
                                      CoordinateSpaces: true,
                                      CopyrightStatus: true,
                                      CornerOptions: true,
                                      CreateProxy: true,
                                      CrossReferenceType: true,
                                      CursorTypes: true,
                                      CustomLayoutTypeEnum: true,
                                      DataFormat: true,
                                      DefaultRenderingIntent: true,
                                      DesignOptions: true,
                                      DiacriticPositionOptions: true,
                                      DigitsTypeOptions: true,
                                      DimensionsConstraints: true,
                                      DisplayOrderOptions: true,
                                      DisplaySettingOptions: true,
                                      DistributeOptions: true,
                                      DocumentIntentOptions: true,
                                      DocumentPrintUiOptions: true,
                                      DynamicDocumentsJPEGQualityOptions: true,
                                      DynamicDocumentsTextExportPolicy: true,
                                      DynamicMediaHandlingOptions: true,
                                      DynamicTriggerEvents: true,
                                      EPSColorSpace: true,
                                      EPSImageData: true,
                                      EditingState: true,
                                      EmptyFrameFittingOptions: true,
                                      EndCap: true,
                                      EndJoin: true,
                                      EpubCover: true,
                                      EpubVersion: true,
                                      EventPhases: true,
                                      ExportFormat: true,
                                      ExportLayerOptions: true,
                                      ExportOrder: true,
                                      ExportPresetFormat: true,
                                      ExportRangeOrAllPages: true,
                                      FeatherCornerType: true,
                                      FeatherMode: true,
                                      FeatureSetOptions: true,
                                      FindChangeTransliterateCharacterTypes: true,
                                      FirstBaseline: true,
                                      FitDimension: true,
                                      FitMethodSettings: true,
                                      FitOptions: true,
                                      Fitting: true,
                                      FlattenerLevel: true,
                                      Flip: true,
                                      FlipValues: true,
                                      FloatingWindowPosition: true,
                                      FloatingWindowSize: true,
                                      FollowShapeModeOptions: true,
                                      FontDownloading: true,
                                      FontEmbedding: true,
                                      FontStatus: true,
                                      FontTypes: true,
                                      FootnoteFirstBaseline: true,
                                      FootnoteMarkerPositioning: true,
                                      FootnoteNumberingStyle: true,
                                      FootnotePrefixSuffix: true,
                                      FootnoteRestarting: true,
                                      GIFOptionsPalette: true,
                                      GlobalClashResolutionStrategy: true,
                                      GlobalClashResolutionStrategyForMasterPage: true,
                                      GlowTechnique: true,
                                      GoToZoomOptions: true,
                                      GradientType: true,
                                      GridAlignment: true,
                                      GridViewSettings: true,
                                      GuideTypeOptions: true,
                                      HeaderFooterBreakTypes: true,
                                      HeaderTypes: true,
                                      HorizontalAlignment: true,
                                      HorizontalOrVertical: true,
                                      HyperlinkAppearanceHighlight: true,
                                      HyperlinkAppearanceStyle: true,
                                      HyperlinkAppearanceWidth: true,
                                      HyperlinkDestinationPageSetting: true,
                                      ICCProfiles: true,
                                      IconSizes: true,
                                      ImageAlignmentType: true,
                                      ImageConversion: true,
                                      ImageDataTypes: true,
                                      ImageExportOption: true,
                                      ImageFormat: true,
                                      ImagePageBreakType: true,
                                      ImageResolution: true,
                                      ImageSizeOption: true,
                                      ImportFormat: true,
                                      ImportPlatform: true,
                                      ImportedPageCropOptions: true,
                                      InCopyUIColors: true,
                                      IndexCapitalizationOptions: true,
                                      IndexFormat: true,
                                      InkTypes: true,
                                      InnerGlowSource: true,
                                      InteractiveElementsOptions: true,
                                      InteractivePDFInteractiveElementsOptions: true,
                                      JPEGOptionsFormat: true,
                                      JPEGOptionsQuality: true,
                                      JoinOptions: true,
                                      JpegColorSpaceEnum: true,
                                      Justification: true,
                                      KashidasOptions: true,
                                      KentenAlignment: true,
                                      KentenCharacter: true,
                                      KentenCharacterSet: true,
                                      KinsokuHangTypes: true,
                                      KinsokuSet: true,
                                      KinsokuType: true,
                                      LanguageAndRegion: true,
                                      LayoutRuleOptions: true,
                                      Leading: true,
                                      LeadingModel: true,
                                      LibraryPanelViews: true,
                                      LineAlignment: true,
                                      LineSpacingType: true,
                                      LinkStatus: true,
                                      ListAlignment: true,
                                      ListType: true,
                                      LiveDrawingOptions: true,
                                      Locale: true,
                                      LocationOptions: true,
                                      LockStateValues: true,
                                      MapType: true,
                                      MarkLineWeight: true,
                                      MarkTypes: true,
                                      MatrixContent: true,
                                      MeasurementUnits: true,
                                      MojikumiTableDefaults: true,
                                      MonoBitmapCompression: true,
                                      MoviePlayOperations: true,
                                      MoviePosterTypes: true,
                                      NestedStyleDelimiters: true,
                                      NoteBackgrounds: true,
                                      NoteColorChoices: true,
                                      NothingEnum: true,
                                      NumberedListExportOption: true,
                                      NumberedParagraphsOptions: true,
                                      OTFFigureStyle: true,
                                      ObjectTypes: true,
                                      OpenOptions: true,
                                      OpenTypeFeature: true,
                                      OutlineJoin: true,
                                      OverrideType: true,
                                      PDFColorSpace: true,
                                      PDFCompressionType: true,
                                      PDFCrop: true,
                                      PDFJPEGQualityOptions: true,
                                      PDFMarkWeight: true,
                                      PDFProfileSelector: true,
                                      PDFRasterCompressionOptions: true,
                                      PDFXStandards: true,
                                      PNGColorSpaceEnum: true,
                                      PNGExportRangeEnum: true,
                                      PNGQualityEnum: true,
                                      PPDValues: true,
                                      PageBindingOptions: true,
                                      PageColorOptions: true,
                                      PageLayoutOptions: true,
                                      PageNumberPosition: true,
                                      PageNumberStyle: true,
                                      PageNumberingOptions: true,
                                      PageOrientation: true,
                                      PagePositions: true,
                                      PageRange: true,
                                      PageReferenceType: true,
                                      PageSideOptions: true,
                                      PageTransitionDirectionOptions: true,
                                      PageTransitionDurationOptions: true,
                                      PageTransitionOverrideOptions: true,
                                      PageTransitionTypeOptions: true,
                                      PageViewOptions: true,
                                      PaginationOption: true,
                                      PanelLayoutResize: true,
                                      PanningTypes: true,
                                      PaperSize: true,
                                      PaperSizes: true,
                                      ParagraphDirectionOptions: true,
                                      ParagraphJustificationOptions: true,
                                      PathType: true,
                                      PathTypeAlignments: true,
                                      PdfMagnificationOptions: true,
                                      PerformanceMetricOptions: true,
                                      PlacedVectorProfilePolicy: true,
                                      PointType: true,
                                      Position: true,
                                      PositionalForms: true,
                                      PostScriptLevels: true,
                                      PreflightLayerOptions: true,
                                      PreflightProfileOptions: true,
                                      PreflightRuleFlag: true,
                                      PreflightScopeOptions: true,
                                      PreviewPagesOptions: true,
                                      PreviewSizeOptions: true,
                                      PreviewTypes: true,
                                      PrintLayerOptions: true,
                                      PrintPageOrientation: true,
                                      Printer: true,
                                      PrinterPresetTypes: true,
                                      Profile: true,
                                      ProofingType: true,
                                      RangeSortOrder: true,
                                      RasterResolutionOptions: true,
                                      RecordSelection: true,
                                      RecordsPerPage: true,
                                      RepaginateOption: true,
                                      ResizeConstraints: true,
                                      ResizeMethods: true,
                                      ResolveStyleClash: true,
                                      RestartPolicy: true,
                                      RotationDirection: true,
                                      RowTypes: true,
                                      RubyAlignments: true,
                                      RubyKentenPosition: true,
                                      RubyOverhang: true,
                                      RubyParentSpacing: true,
                                      RubyTypes: true,
                                      RuleDataType: true,
                                      RuleWidth: true,
                                      RulerOrigin: true,
                                      SWFBackgroundOptions: true,
                                      SWFCurveQualityValue: true,
                                      Sampling: true,
                                      SaveOptions: true,
                                      ScaleModes: true,
                                      Screeening: true,
                                      ScreenModeOptions: true,
                                      ScriptLanguage: true,
                                      SearchModes: true,
                                      SearchStrategies: true,
                                      SelectAll: true,
                                      SelectionOptions: true,
                                      Sequences: true,
                                      ShadowMode: true,
                                      SignatureSizeOptions: true,
                                      SingleWordJustification: true,
                                      SmartMatchOptions: true,
                                      SnapshotBlendingModes: true,
                                      SortAssets: true,
                                      SoundPosterTypes: true,
                                      SourceFieldType: true,
                                      SourceSpaces: true,
                                      SourceType: true,
                                      SpanColumnCountOptions: true,
                                      SpanColumnTypeOptions: true,
                                      SpecialCharacters: true,
                                      SpreadFlattenerLevel: true,
                                      StartParagraph: true,
                                      StateTypes: true,
                                      StaticAlignmentOptions: true,
                                      StoryDirectionOptions: true,
                                      StoryHorizontalOrVertical: true,
                                      StoryTypes: true,
                                      StrokeAlignment: true,
                                      StrokeCornerAdjustment: true,
                                      StrokeFillProxyOptions: true,
                                      StrokeFillTargetOptions: true,
                                      StrokeOrderTypes: true,
                                      StyleConflict: true,
                                      StyleSheetExportOption: true,
                                      SyncConflictResolution: true,
                                      TabStopAlignment: true,
                                      TableDirectionOptions: true,
                                      TableFormattingOptions: true,
                                      TagRaster: true,
                                      TagTextExportCharacterSet: true,
                                      TagTextForm: true,
                                      TagTransparency: true,
                                      TagType: true,
                                      TagVector: true,
                                      TaggedPDFStructureOrderOptions: true,
                                      TaskAlertType: true,
                                      TaskState: true,
                                      TextFrameContents: true,
                                      TextImportCharacterSet: true,
                                      TextPathEffects: true,
                                      TextStrokeAlign: true,
                                      TextTypeAlignments: true,
                                      TextWrapModes: true,
                                      TextWrapSideOptions: true,
                                      ThumbsPerPage: true,
                                      TilingTypes: true,
                                      ToolTipOptions: true,
                                      ToolsPanelOptions: true,
                                      TrapEndTypes: true,
                                      TrapImagePlacementTypes: true,
                                      Trapping: true,
                                      UIColors: true,
                                      UITools: true,
                                      UndoModes: true,
                                      UpdateLinkOptions: true,
                                      UserInteractionLevels: true,
                                      VariableNumberingStyles: true,
                                      VariableScopes: true,
                                      VariableTypes: true,
                                      VersionCueSyncStatus: true,
                                      VersionState: true,
                                      VerticalAlignment: true,
                                      VerticalJustification: true,
                                      VerticallyRelativeTo: true,
                                      ViewDisplaySettings: true,
                                      ViewZoomStyle: true,
                                      WarichuAlignment: true,
                                      WatermarkHorizontalPositionEnum: true,
                                      WatermarkVerticalPositionEnum: true,
                                      WhenScalingOptions: true,
                                      XFLRasterizeFormatOptions: true,
                                      XMLElementLocation: true,
                                      XMLElementPosition: true,
                                      XMLExportUntaggedTablesFormat: true,
                                      XMLFileEncoding: true,
                                      XMLImportStyles: true,
                                      XMLTransformFile: true,
                                      ZoomOptions: true,
                                  getEnum.nnums = getEnum.nnums || {};
                                  if (getEnum.nnums[+prop] !== undefined) return getEnum.nnums[+prop];
                                  for (n in getEnum.enums) {
                                      try {
                                          if ((p = $.global[n]) && p.constructor.name === "Enumeration") {
                                              for (i in p) {
                                                  c = +p[i];
                                                  getEnum.nnums[c] = n + "." + i;
                                      } catch (e) {}
                                  return "Enumerator UNKNOWN";
                              • 12. Re: Search document for SpecialCharacters Enumerator
                                Marc Autret Level 4
                                Hi Uwe and Trevor,
                                Thanks a lot!
                                Dirk's code sounds definitely brilliant to me, as it only relies on parsing the $.dictionary database (meaning that it properly reflects the current DOM in use), and most importantly it fixes Enumerator's prototype in a way that makes toSource() both effective and verbose, including when you invoke toSource() from a parent DOM object properties that may contain enumerators. Also, the code only instantiates NothingEnum in the global scope (in order to wake up the Enumerator constructor—a live object entity) so one can consider it very 'non-polluting' when included in a larger project or framework.
                                Anyway, I had fun in writing a (slightly) different implementation which (slightly) increases the verbosity. Numbers are now formatted in 0xHEXA form and the Adobe 4-char tag is shown too. Here it is:
                                // Repair toSource() for enumerations [alternative version]
                                // for InDesign CS5 and later
                                // Based on Dirk Becker's 2014 original code at
                                // http://ixta.com/scripts/utilities/enumToSource.html
                                // Output either the format
                                //     <Enumeration>.<Enumerator> /* <Hexa> [<Tag>] */
                                //     if <Enumeration> is the unique parent for that value,
                                //     e.g: AnchorPosition.INLINE_POSITION /* 414F5069 [AOPi] */
                                // or
                                //     0x<Hexa> /* <Enumerator> [<Tag>] */
                                //     if Enumerator's value belongs to multiple parents,
                                //     e.g: 0x74787466 /* TEXT_FRAME [txtf] */
                                // TIP: You can access the whole 'database' (cache)
                                //      browsing the following object
                                //      NothingEnum.NOTHING.__proto__.toSource.Q
                                (function(P)
                                    P.toSource = function F(){ return F.Q[this] || "({})" };
                                    (function(/*obj&*/Q,  n,i,a,s,x,t,k,v)
                                        const DIC = $.dictionary;
                                        const CHR = String.fromCharCode;
                                        const FMT = $.global.localize;
                                        const REGULAR_PATTERN = "%1.%2 /*\xA0%3\xA0[%4]\xA0*/";
                                        const SPECIAL_PATTERN = "0x%3 /*\xA0%2\xA0[%4]\xA0*/";
                                        for( a=DIC.getClasses(), n=a.length, i=-1 ; ++i < n ; )
                                            x = DIC.getClass(s=a[i]).toXML();
                                            if( 'true' != x.@enumeration ) continue;
                                            x = x.elements.property;
                                            for each( t in x )
                                                k = String(t.@name);
                                                v = Number(t..value);
                                                Q[k] = FMT(
                                                    Q.hasOwnProperty(k) ? SPECIAL_PATTERN : REGULAR_PATTERN,
                                                    // %1 :: Enumeration class name
                                                    s,
                                                    // %2 :: Enumerator key
                                                    k,
                                                    // %3 :: Hexa representation
                                                    v.toString(16).toUpperCase(),
                                                    // %4 :: Adobe 4-char tag
                                                    CHR(0xFF&(v>>>24),0xFF&(v>>>16),0xFF&(v>>>8),0xFF&(v>>>0))
                                    })( P.toSource.Q={} );
                                })(NothingEnum.NOTHING.__proto__);
                                // Sample test:
                                alert( Locale.frenchLocale.toSource() );
                                // => Locale.FRENCH_LOCALE /* 4C434672 [LCFr] */
                                Marc
                                2 people found this helpful
                                • 13. Re: Search document for SpecialCharacters Enumerator
                                  Dirk Becker Level 4
                                  Trevor is probably referring to the previous version that touched every enum.
                                  http://www.ixta.com/scripts/utilities/pretty.html
                                  Regards,
                                  Dirk
                                  • 14. Re: Search document for SpecialCharacters Enumerator
                                    Hi all
                                    Yes, Dirk, spot on, I was referring to the previous version I didn't see your new post until you pointed that out.
                                    Very nice implementations both yours and Marc's, looks like a real improvement on both our older versions.
                                    I now understand why Marc complimented your version above mine.
                                    Thanks and well done!
                                    Trevor
                                    • 15. Re: Search document for SpecialCharacters Enumerator
                                      Dirk Becker Level 4
                                      Here a few notes about Marc's version:
                                      By using the closure, you probably introduce some memory leaks. The toString() method assigned from within the closure will keep it around forever. My site has another utility based on $.summary that can point out such leaks, at http://ixta.com/scripts/utilities/summaryDifference.html - the leaks should be a workspace object (the closure) plus the outer anonymous function.
                                      Ages ago I was warned to not use __proto__, it is not equivalent to my .prototype approach. The ExtendScript engine makes some assumptions about that object. Unfortunately I only found an old email from 2006 where I mentioned that info, but not the original quote from Michael Däumling.
                                      Dirk
                                      • 16. Re: Search document for SpecialCharacters Enumerator
                                        Marc Autret Level 4
                                        Hi Dirk,
                                        Taking into account your informed opinion, here is an upgrade of my code safe of (workspace) leaks and using the regular constructor.prototype path. According to your great $.summary.difference() utility, its cost is now:
                                        1 Dictionary
                                        12 Function
                                        1 Math
                                        1 Enumeration
                                        1 Enumerator
                                        3 Object
                                        1 Reflection
                                        New code:
                                        // for InDesign CS5 and later -- v.2.0
                                        // or
                                                for each( t in x )
                                                    Q[k] = FMT(
                                                        s,
                                                        k,
                                        })( (NothingEnum.NOTHING.constructor.prototype.toSource=function F(){ return F.Q[this] || "({})" }).Q={} );
                                        Best,
                                        Marc
                                        • 17. Re: Search document for SpecialCharacters Enumerator
                                          Ok my turn now
                                          DISCLAIMERS
                                          I did not test for memory leakages.
                                          I did not really test for anything much at all
                                          No fancy features like returning hex values
                                          But for a simple answer to my question of how to get the "ColorModel" part of the "ColorModel.PROCESS" enum the below method should work even if multiple enums had the property "PROCESS" to them.
                                          function getEnum(_enum) {
                                              if (getEnum.dataBase) {
                                                  return getEnum.dataBase[_enum] || "Enumerator Unknown";
                                              var dic, _Class, n, l, en;
                                              getEnum.dataBase = {};
                                              dic = $.dictionary.getClasses();
                                              for (_Class in dic) {
                                                  en = dic[_Class];
                                                  if (!$.global[en]) continue;
                                                  reflection = $.global[en].reflect.properties;
                                                  l = reflection.length - 1;
                                                  for (n = 0; n < l; n++) {
                                                      getEnum.dataBase[$.global[en][reflection[n]]] = en + '.' + reflection[n];
                                          /*** USAGE ***/
                                          var doc, rect, m;
                                          doc = app.documents.add();
                                          rect = doc.rectangles.add({ fillColor: doc.colors.itemByName("Cyan") });
                                          m = [
                                              'Using getEnum method',
                                              getEnum(rect.fillColor.space),
                                              getEnum(rect.fillColor.model),
                                              'Not using getEnum method',
                                              rect.fillColor.space,
                                          ].join('\n');
                                          alert(m);
                                              Alerts
                                              JpegColorSpaceEnum.CMYK
                                              ColorModel.PROCESS
                                              CMYK
                                              PROCESS
                                          • 18. Re: Search document for SpecialCharacters Enumerator
                                            MasterDomino
                                            Hello dear scripting pros,
                                            I am trying to get this to work, however, I always get an error in the line with $.dictionary.getClasses(): Type error: null is not an object. I tested all variations Dirk's, Marc's and Trevor's, always the same error.
                                            So, $.dictionary is null in my case. Also I don't see where the .getClasses() method is coming from, as it is not listed in the ID object model? Do I need to make some preparations for this to work, like augment a prototype or something along these lines?
                                            Thanks for your help.
                                            TR
                                            (CS6, OS X 10.8.5, German local version)
                                            • 19. Re: Search document for SpecialCharacters Enumerator
                                              Hi TR,
                                              just tested with CS6 8.1.0 and CC 9.3.0 on OSX 10.6.8.
                                              ESTK 4.0.0.1 with ExtendScript 4.5.5.
                                              $.dictionary will return null with CS6.
                                              $.dictionary will return [object Dictionary] with CC.
                                              So this is only working with CC and above, I think.
                                              Regards,
                                              Uwe
                                              • 20. Re: Search document for SpecialCharacters Enumerator
                                                MasterDomino Level 1
                                                Hi Uwe,
                                                ah, okay. Since Marc wrote "for InDesign CS5 and later" I just assumed it would work for CS6, but then again, I should not expect that everyone checks every snippet against every version. So maybe it does work in CS5 (can't test it) and then again in CC?
                                                Either way, thanks for the confirmation, that it does not work in CS6.
                                                (Btw. if anyone knows a workaround for CS6 that would be great of course, but I imagine this can be quite tricky.
                                                Thanks Uwe!
                                                Regards,
                                                TR
                                                • 21. Re: Search document for SpecialCharacters Enumerator
                                                  Hi TR
                                                  As a work around you could try my method in #11 that is if your aiming for the full enumerator.
                                                  Regards
                                                  TRevor
                                                  P.s. If I get a chance I'll try the $.dic method on CS5
                                                  • 22. Re: Search document for SpecialCharacters Enumerator
                                                    Hi Trevor and TR,
                                                    just tested $.dictionary with CS5 and CS5.5.
                                                    To my surprise:
                                                    $.dictionary will return [object Dictionary] with CS5.5.
                                                    So maybe it's a bug, that $.dictionary will return null with CS6 8.1.0 ?
                                                    OSX 10.6.8
                                                    Regards,
                                                    Uwe
                                                    • 23. Re: Search document for SpecialCharacters Enumerator
                                                      Well, what do you know?
                                                      Windows version  8.1.0.420 (CS6) works
                                                      Mac version 8.1.0.419 doesn't work
                                                      • 24. Re: Search document for SpecialCharacters Enumerator
                                                        Interesting find.
                                                        Just a side question, to rule this out: This is not possibly related to my version (and yours possibly to, Uwe?) being a localized German version?
                                                        Apparently not, if Trevor has the same result. Hm, quite annoying, really. :/
                                                        • 25. Re: Search document for SpecialCharacters Enumerator
                                                          P.s. no chance of Adobe fixing that one.
                                                          • 27. Re: Search document for SpecialCharacters Enumerator
                                                            What the hell…
                                                            FWIW: I'm on a German CS6 8.1.0.419 Mac OSX version.
                                                            So with Windows it'll work? Arrgh!
                                                            Thanks for testing, Trevor!
                                                            Regards,
                                                            Uwe
                                                            • 28. Re: Search document for SpecialCharacters Enumerator
                                                              How abouts
                                                              if (!$.dictionary) $.dictionaryCS6Mac = {
        classes: ['Assignment', 'Assignments', 'AssignedStory', 'AssignedStories', 'PrintEvent', 'PlaceGun', 'EventListener', 'EventListeners', 'Event', 'Events', 'IdleEvent', 'MutationEvent', 'IdleTask', 'IdleTasks', 'ScriptArg', 'Application', 'BackgroundTask', 'BackgroundTasks', 'Document', 'Documents', 'Window', 'Windows', 'LayoutWindow', 'LayoutWindows', 'StoryWindow', 'StoryWindows', 'DocumentEvent', 'ImportExportEvent', 'ContentPlacerObject', 'Book', 'Books', 'BookContent', 'BookContents', 'Ink', 'Inks', 'TrapPreset', 'TrapPresets', 'MixedInk', 'MixedInks', 'MixedInkGroup', 'MixedInkGroups', 'Gradient', 'Gradients', 'GradientStop', 'GradientStops', 'Swatch', 'Swatches', 'Color', 'Colors', 'Tint', 'Tints', 'OpacityGradientStop', 'OpacityGradientStops', 'DataMergeTextPlaceholder', 'DataMergeTextPlaceholders', 'DataMergeImagePlaceholder', 'DataMergeImagePlaceholders', 'DataMergeField', 'DataMergeFields', 'StoryTypes', 'StoryDirectionOptions', 'ImportFormat', 'NestedStyleDelimiters', 'RuleWidth', 'Justification', 'SingleWordJustification', 'StartParagraph', 'HorizontalOrVertical', 'TabStopAlignment', 'FirstBaseline', 'VerticalJustification', 'Leading', 'OTFFigureStyle', 'Capitalization', 'Position', 'TextFrameContents', 'SpecialCharacters', 'ChangecaseMode', 'BindingOptions', 'PageOrientation', 'RulerOrigin', 'MeasurementUnits', 'PageBindingOptions', 'BaselineGridRelativeOption', 'PageSideOptions', 'WhenScalingOptions', 'PageColorOptions', 'DocumentIntentOptions', 'LayoutRuleOptions', 'SnapshotBlendingModes', 'EPSColorSpace', 'PreviewTypes', 'FontEmbedding', 'ScaleModes', 'PrintLayerOptions', 'UITools', 'GlobalClashResolutionStrategyForMasterPage', 'ClippingPathType', 'UpdateLinkOptions', 'IconSizes', 'PanelLayoutResize', 'PageViewOptions', 'PDFColorSpace', 'AcrobatCompatibility', 'ICCProfiles', 'BitmapCompression', 'CompressionQuality', 'MonoBitmapCompression', 'PDFMarkWeight', 'Sampling', 'ExportPresetFormat', 'PDFCrop', 'PDFCompressionType', 'PDFProfileSelector', 'PDFXStandards', 'ExportLayerOptions', 'PdfMagnificationOptions', 'PageLayoutOptions', 'RasterResolutionOptions', 'PDFRasterCompressionOptions', 'PDFJPEGQualityOptions', 'InteractiveElementsOptions', 'InteractivePDFInteractiveElementsOptions', 'PageTransitionOverrideOptions', 'TaggedPDFStructureOrderOptions', 'ConvertShapeOptions', 'CoordinateSpaces', 'MatrixContent', 'BoundingBoxLimits', 'ResizeConstraints', 'ResizeMethods', 'EmptyFrameFittingOptions', 'CornerOptions', 'DimensionsConstraints', 'ContentType', 'EndCap', 'EndJoin', 'StrokeCornerAdjustment', 'ArrowHead', 'DisplaySettingOptions', 'FitOptions', 'StrokeAlignment', 'GuideTypeOptions', 'ContourOptionsTypes', 'TextWrapSideOptions', 'TextWrapModes', 'FontStatus', 'FontTypes', 'OpenTypeFeature', 'CharacterAlignment', 'AlternateGlyphForms', 'AdornmentOverprint', 'KentenCharacter', 'RubyKentenPosition', 'KentenCharacterSet', 'RubyTypes', 'RubyAlignments', 'RubyParentSpacing', 'RubyOverhang', 'WarichuAlignment', 'KinsokuType', 'KinsokuHangTypes', 'LeadingModel', 'KinsokuSet', 'MojikumiTableDefaults', 'GridAlignment', 'KentenAlignment', 'ComposeUsing', 'PageNumberStyle', 'PaginationOption', 'GradientType', 'JoinOptions', 'PathType', 'PointType', 'CreateProxy', 'ImportedPageCropOptions', 'StrokeFillProxyOptions', 'StrokeFillTargetOptions', 'RotationDirection', 'LocationOptions', 'UIColors', 'NothingEnum', 'AutoEnum', 'EventPhases', 'ExportFormat', 'PlacedVectorProfilePolicy', 'ColorSettingsPolicy', 'DefaultRenderingIntent', 'ProofingType', 'ChangeConditionsModes', 'SearchModes', 'ObjectTypes', 'FindChangeTransliterateCharacterTypes', 'LibraryPanelViews', 'SortAssets', 'LinkStatus', 'AssetType', 'ChangeTypes', 'TextPathEffects', 'TextTypeAlignments', 'PathTypeAlignments', 'FlipValues', 'XMLElementLocation', 'XMLElementPosition', 'XMLImportStyles', 'XMLFileEncoding', 'ImageConversion', 'GIFOptionsPalette', 'JPEGOptionsQuality', 'JPEGOptionsFormat', 'XMLExportUntaggedTablesFormat', 'XMLTransformFile', 'AnchorPosition', 'HorizontalAlignment', 'VerticalAlignment', 'AnchoredRelativeTo', 'BalanceLinesStyle', 'VerticallyRelativeTo', 'PositionalForms', 'TextStrokeAlign', 'OutlineJoin', 'BaselineFrameGridRelativeOption', 'FootnoteFirstBaseline', 'FootnoteRestarting', 'FootnotePrefixSuffix', 'FootnoteNumberingStyle', 'FootnoteMarkerPositioning', 'OverrideType', 'GlobalClashResolutionStrategy', 'StoryHorizontalOrVertical', 'AddPageOptions', 'VariableTypes', 'VariableScopes', 'VariableNumberingStyles', 'SearchStrategies', 'ChangeCaseOptions', 'AutoSizingTypeEnum', 'AutoSizingReferenceEnum', 'SpanColumnTypeOptions', 'SpanColumnCountOptions', 'LineAlignment', 'GridViewSettings', 'CharacterCountLocation', 'InCopyUIColors', 'CursorTypes', 'AntiAliasType', 'LineSpacingType', 'RepaginateOption', 'BookContentStatus', 'SmartMatchOptions', 'RowTypes', 'HeaderFooterBreakTypes', 'AlternatingFillsTypes', 'StrokeOrderTypes', 'DisplayOrderOptions', 'FlattenerLevel', 'BlendingSpace', 'BlendMode', 'ShadowMode', 'FeatherMode', 'FeatherCornerType', 'SpreadFlattenerLevel', 'GlowTechnique', 'InnerGlowSource', 'BevelAndEmbossStyle', 'BevelAndEmbossTechnique', 'BevelAndEmbossDirection', 'FollowShapeModeOptions', 'PageNumberPosition', 'NumberedParagraphsOptions', 'TextImportCharacterSet', 'ImportPlatform', 'ConvertPageBreaks', 'TagTextExportCharacterSet', 'TagTextForm', 'StyleConflict', 'TextExportCharacterSet', 'ConvertTablesOptions', 'TableFormattingOptions', 'AlignmentStyleOptions', 'ResolveStyleClash', 'ContainerType', 'CopyrightStatus', 'IndexCapitalizationOptions', 'IndexFormat', 'CrossReferenceType', 'PageReferenceType', 'HeaderTypes', 'TagTransparency', 'TagVector', 'TagRaster', 'HyperlinkAppearanceHighlight', 'HyperlinkAppearanceWidth', 'HyperlinkAppearanceStyle', 'HyperlinkDestinationPageSetting', 'BuildingBlockTypes', 'RangeSortOrder', 'PreflightRuleFlag', 'RuleDataType', 'PreflightScopeOptions', 'PreflightLayerOptions', 'PreflightProfileOptions', 'PNGExportRangeEnum', 'PNGQualityEnum', 'PNGColorSpaceEnum', 'StateTypes', 'FloatingWindowPosition', 'FloatingWindowSize', 'MoviePosterTypes', 'MoviePlayOperations', 'SoundPosterTypes', 'BehaviorEvents', 'GoToZoomOptions', 'PlayOperations', 'AnimationPlayOperations', 'ViewZoomStyle', 'VersionState', 'EditingState', 'VersionCueSyncStatus', 'SyncConflictResolution', 'LanguageAndRegion', 'UserInteractionLevels', 'Locale', 'ScriptLanguage', 'FeatureSetOptions', 'UndoModes', 'OpenOptions', 'TaskState', 'TaskAlertType', 'SaveOptions', 'ZoomOptions', 'ViewDisplaySettings', 'AnchorPoint', 'ColorModel', 'ColorSpace', 'ScreenModeOptions', 'WatermarkVerticalPositionEnum', 'WatermarkHorizontalPositionEnum', 'PageNumberingOptions', 'ToolTipOptions', 'SelectionOptions', 'SelectAll', 'PreviewSizeOptions', 'ToolsPanelOptions', 'LiveDrawingOptions', 'PreviewPagesOptions', 'StaticAlignmentOptions', 'RenderingIntent', 'MarkLineWeight', 'MarkTypes', 'ColorOutputModes', 'DataFormat', 'Flip', 'FontDownloading', 'PagePositions', 'PostScriptLevels', 'PrintPageOrientation', 'ImageDataTypes', 'Sequences', 'SourceSpaces', 'ThumbsPerPage', 'TilingTypes', 'Trapping', 'InkTypes', 'PrinterPresetTypes', 'ColorRenderingDictionary', 'PageRange', 'PaperSize', 'PPDValues', 'Profile', 'Screeening', 'PaperSizes', 'Printer', 'TrapImagePlacementTypes', 'TrapEndTypes', 'EPSImageData', 'BookletTypeOptions', 'SignatureSizeOptions', 'DocumentPrintUiOptions', 'NoteBackgrounds', 'NoteColorChoices', 'ChangeMarkings', 'ChangebarLocations', 'ChangeTextColorChoices', 'ChangeBackgroundColorChoices', 'LockStateValues', 'JpegColorSpaceEnum', 'ExportRangeOrAllPages', 'RecordSelection', 'ArrangeBy', 'RecordsPerPage', 'Fitting', 'SourceFieldType', 'ListType', 'BulletCharacterType', 'NumberingStyle', 'RestartPolicy', 'ListAlignment', 'ChapterNumberSources', 'CustomLayoutTypeEnum', 'AssignmentExportOptions', 'AssignmentStatus', 'PanningTypes', 'AlignDistributeBounds', 'AlignOptions', 'DistributeOptions', 'SourceType', 'TagType', 'ImageFormat', 'ImageSizeOption', 'ImageResolution', 'ImageAlignmentType', 'ImagePageBreakType', 'PerformanceMetricOptions', 'SWFBackgroundOptions', 'XFLRasterizeFormatOptions', 'AnimationEaseOptions', 'DynamicTriggerEvents', 'PageTransitionTypeOptions', 'PageTransitionDirectionOptions', 'RasterCompressionOptions', 'DynamicDocumentsJPEGQualityOptions', 'DynamicDocumentsTextExportPolicy', 'FitMethodSettings', 'FitDimension', 'PageTransitionDurationOptions', 'SWFCurveQualityValue', 'DynamicMediaHandlingOptions', 'DesignOptions', 'ConditionIndicatorMethod', 'ConditionUnderlineIndicatorAppearance', 'ConditionIndicatorMode', 'SmoothScrollingOptions', 'FolioOrientationOptions', 'FolioBindingDirectionOptions', 'DigpubVersion', 'AttachedDevices', 'DigpubArticleVersion', 'ExportOrder', 'EpubCover', 'BulletListExportOption', 'NumberedListExportOption', 'StyleSheetExportOption', 'EpubVersion', 'ImageExportOption', 'MapType', 'ParagraphDirectionOptions', 'ParagraphJustificationOptions', 'CharacterDirectionOptions', 'DigitsTypeOptions', 'KashidasOptions', 'DiacriticPositionOptions', 'TableDirectionOptions', 'Hyperlink', 'Hyperlinks', 'Bookmark', 'Bookmarks', 'HyperlinkPageItemSource', 'HyperlinkPageItemSources', 'HyperlinkTextSource', 'HyperlinkTextSources', 'HyperlinkTextDestination', 'HyperlinkTextDestinations', 'HyperlinkPageDestination', 'HyperlinkPageDestinations', 'HyperlinkExternalPageDestination', 'HyperlinkExternalPageDestinations', 'HyperlinkURLDestination', 'HyperlinkURLDestinations', 'CrossReferenceFormat', 'CrossReferenceFormats', 'CrossReferenceSource', 'CrossReferenceSources', 'BuildingBlock', 'BuildingBlocks', 'ParagraphDestination', 'ParagraphDestinations', 'Index', 'Indexes', 'IndexOptions', 'Topic', 'Topics', 'CrossReference', 'CrossReferences', 'PageReference', 'PageReferences', 'IndexSection', 'IndexSections', 'FormField', 'FormFields', 'Button', 'Buttons', 'State', 'States', 'MultiStateObject', 'MultiStateObjects', 'CheckBox', 'CheckBoxes', 'ComboBox', 'ComboBoxes', 'ListBox', 'ListBoxes', 'RadioButton', 'RadioButtons', 'TextBox', 'TextBoxes', 'SignatureField', 'SignatureFields', 'Movie', 'Movies', 'NavigationPoint', 'NavigationPoints', 'Sound', 'Sounds', 'Behavior', 'Behaviors', 'GotoFirstPageBehavior', 'GotoFirstPageBehaviors', 'GotoLastPageBehavior', 'GotoLastPageBehaviors', 'GotoNextPageBehavior', 'GotoNextPageBehaviors', 'GotoPreviousPageBehavior', 'GotoPreviousPageBehaviors', 'GotoNextViewBehavior', 'GotoNextViewBehaviors', 'GotoPreviousViewBehavior', 'GotoPreviousViewBehaviors', 'GotoURLBehavior', 'GotoURLBehaviors', 'MovieBehavior', 'MovieBehaviors', 'ShowHideFieldsBehavior', 'ShowHideFieldsBehaviors', 'AnimationBehavior', 'AnimationBehaviors', 'OpenFileBehavior', 'OpenFileBehaviors', 'GotoNextStateBehavior', 'GotoNextStateBehaviors', 'GotoPreviousStateBehavior', 'GotoPreviousStateBehaviors', 'GotoStateBehavior', 'GotoStateBehaviors', 'ViewZoomBehavior', 'ViewZoomBehaviors', 'SoundBehavior', 'SoundBehaviors', 'GotoAnchorBehavior', 'GotoAnchorBehaviors', 'GotoPageBehavior', 'GotoPageBehaviors', 'ClearFormBehavior', 'ClearFormBehaviors', 'PrintFormBehavior', 'PrintFormBehaviors', 'SubmitFormBehavior', 'SubmitFormBehaviors', 'TimingSetting', 'TimingList', 'TimingLists', 'TimingGroup', 'TimingGroups', 'TimingTarget', 'TimingTargets', 'Layer', 'Layers', 'Spread', 'Spreads', 'Page', 'Pages', 'MasterSpread', 'MasterSpreads', 'PDFAttribute', 'PageItem', 'PageItems', 'Oval', 'Ovals', 'Rectangle', 'Rectangles', 'GraphicLine', 'GraphicLines', 'Polygon', 'Polygons', 'Group', 'Groups', 'Image', 'Images', 'EPS', 'EPSs', 'PDF', 'PDFs', 'WMF', 'WMFs', 'PICT', 'PICTs', 'Graphic', 'Graphics', 'TransformationMatrix', 'TransformationMatrices', 'FrameFittingOption', 'Guide', 'Guides', 'TextWrapPreference', 'ContourOption', 'Section', 'Sections', 'Path', 'Paths', 'PathPoint', 'PathPoints', 'SplineItem', 'SplineItems', 'EPSText', 'EPSTexts', 'ImportedPage', 'ImportedPages', 'MediaItem', 'MediaItems', 'Snippet', 'Snippets', 'MotionPreset', 'MotionPresets', 'Article', 'Articles', 'ArticleMember', 'ArticleMembers', 'ArticleChild', 'ArticleChildren', 'HtmlItem', 'HtmlItems', 'Library', 'Libraries', 'Asset', 'Assets', 'Link', 'Links', 'LinkMetadata', 'ObjectStyle', 'ObjectStyles', 'StoryPreference', 'TextFramePreference', 'TextPreference', 'TextDefault', 'DocumentPreference', 'GridPreference', 'GuidePreference', 'MarginPreference', 'PasteboardPreference', 'ViewPreference', 'DocumentPreset', 'DocumentPresets', 'PrintPreference', 'PrintBookletOption', 'PrintBookletPrintPreference', 'EPSExportPreference', 'ToolBox', 'ImagePreference', 'ImageIOPreference', 'ClippingPathSettings', 'GraphicLayerOption', 'GraphicLayer', 'GraphicLayers', 'IMEPreference', 'PDFExportPreference', 'PDFExportPreset', 'PDFExportPresets', 'PDFPlacePreference', 'InteractivePDFExportPreference', 'TaggedPDFPreference', 'PageItemDefault', 'ObjectExportOption', 'TextEditingPreference', 'MojikumiUiPreference', 'FontLockingPreference', 'DictionaryPreference', 'PolygonPreference', 'SpellPreference', 'AutoCorrectPreference', 'SmartGuidePreference', 'EPSImportPreference', 'ImportedPageAttribute', 'StrokeFillProxySetting', 'LayoutAdjustmentPreference', 'Preference', 'Preferences', 'ScriptPreference', 'ColorSetting', 'FindChangeTextOption', 'FindChangeGrepOption', 'FindChangeGlyphOption', 'FindChangeObjectOption', 'FindChangeTransliterateOption', 'FindTextPreference', 'FindGrepPreference', 'FindGlyphPreference', 'FindObjectPreference', 'FindTransliteratePreference', 'ChangeTextPreference', 'ChangeGrepPreference', 'ChangeGlyphPreference', 'ChangeObjectPreference', 'ChangeTransliteratePreference', 'LinkingPreference', 'InCopyExportOption', 'PrinterPreset', 'PrinterPresets', 'XMLImportPreference', 'XMLExportPreference', 'XMLPreference', 'ExportForWebPreference', 'AnchoredObjectDefault', 'AnchoredObjectSetting', 'BaselineFrameGridOption', 'FootnoteOption', 'PageNumberVariablePreference', 'ChapterNumberVariablePreference', 'DateVariablePreference', 'FileNameVariablePreference', 'MatchCharacterStylePreference', 'MatchParagraphStylePreference', 'CustomTextVariablePreference', 'CaptionMetadataVariablePreference', 'GridDataInformation', 'LayoutGridDataInformation', 'StoryGridDataInformation', 'CjkGridPreference', 'GridPrintingPreference', 'GalleyPreference', 'FlattenerPreset', 'FlattenerPresets', 'FlattenerPreference', 'TransparencyPreference', 'TransparencySetting', 'StrokeTransparencySetting', 'FillTransparencySetting', 'BlendingSetting', 'DropShadowSetting', 'FeatherSetting', 'InnerShadowSetting', 'OuterGlowSetting', 'InnerGlowSetting', 'BevelAndEmbossSetting', 'SatinSetting', 'ContentTransparencySetting', 'DirectionalFeatherSetting', 'GradientFeatherSetting', 'FindChangeTransparencySetting', 'FindChangeStrokeTransparencySetting', 'FindChangeFillTransparencySetting', 'FindChangeContentTransparencySetting', 'FindChangeBlendingSetting', 'FindChangeDropShadowSetting', 'FindChangeFeatherSetting', 'FindChangeInnerShadowSetting', 'FindChangeOuterGlowSetting', 'FindChangeInnerGlowSetting', 'FindChangeBevelAndEmbossSetting', 'FindChangeSatinSetting', 'FindChangeDirectionalFeatherSetting', 'FindChangeGradientFeatherSetting', 'TextImportPreference', 'TextExportPreference', 'WordRTFImportPreference', 'TaggedTextExportPreference', 'TaggedTextImportPreference', 'ExcelImportPreference', 'MetadataPreference', 'DisplayPerformancePreference', 'DisplaySetting', 'DisplaySettings', 'XMLViewPreference', 'PreflightOption', 'PreflightBookOption', 'PNGExportPreference', 'ButtonPreference', 'WatermarkPreference', 'GeneralPreference', 'ClipboardPreference', 'TransformPreference', 'NotePreference', 'TrackChangesPreference', 'JPEGExportPreference', 'DataMergePreference', 'DataMergeOption', 'DataMerge', 'ChapterNumberPreference', 'ObjectStyleObjectEffectsCategorySettings', 'ObjectStyleStrokeEffectsCategorySettings', 'ObjectStyleFillEffectsCategorySettings', 'ObjectStyleContentEffectsCategorySettings', 'GrabberPreference', 'AlignDistributePreference', 'SWFExportPreference', 'XFLExportPreference', 'AnimationSetting', 'ConditionalTextPreference', 'EPubExportPreference', 'HTMLExportPreference', 'LinkedStoryOption', 'ParaStyleMapping', 'ParaStyleMappings', 'CellStyleMapping', 'CellStyleMappings', 'CharStyleMapping', 'CharStyleMappings', 'TableStyleMapping', 'TableStyleMappings', 'LinkedPageItemOption', 'PreflightRule', 'PreflightRules', 'RuleDataObject', 'RuleDataObjects', 'PreflightRuleInstance', 'PreflightRuleInstances', 'PreflightProfile', 'PreflightProfiles', 'PreflightProcess', 'PreflightProcesses', 'PreflightProfileRule', 'PreflightProfileRules', 'StrokeStyle', 'StrokeStyles', 'DashedStrokeStyle', 'DashedStrokeStyles', 'DottedStrokeStyle', 'DottedStrokeStyles', 'StripedStrokeStyle', 'StripedStrokeStyles', 'TOCStyle', 'TOCStyles', 'TOCStyleEntry', 'TOCStyleEntries', 'Cell', 'Cells', 'Table', 'Tables', 'Column', 'Columns', 'Row', 'Rows', 'TableStyle', 'TableStyles', 'TableStyleGroup', 'TableStyleGroups', 'CellStyle', 'CellStyles', 'CellStyleGroup', 'CellStyleGroups', 'NestedLineStyle', 'NestedLineStyles', 'NestedGrepStyle', 'NestedGrepStyles', 'Text', 'Texts', 'Character', 'Characters', 'Word', 'Words', 'Line', 'Lines', 'TextColumn', 'TextColumns', 'Paragraph', 'Paragraphs', 'TextStyleRange', 'TextStyleRanges', 'InsertionPoint', 'InsertionPoints', 'TextFrame', 'TextFrames', 'Story', 'Stories', 'ParagraphStyle', 'ParagraphStyles', 'CharacterStyle', 'CharacterStyles', 'TabStop', 'TabStops', 'NestedStyle', 'NestedStyles', 'Language', 'Languages', 'LanguageWithVendors', 'LanguagesWithVendors', 'Font', 'Fonts', 'KinsokuTable', 'KinsokuTables', 'MojikumiTable', 'MojikumiTables', 'HyphenationException', 'HyphenationExceptions', 'UserDictionary', 'UserDictionaries', 'AutoCorrectTable', 'AutoCorrectTables', 'Change', 'Changes', 'TextPath', 'TextPaths', 'Note', 'Notes', 'Footnote', 'Footnotes', 'TextVariable', 'TextVariables', 'TextVariableInstance', 'TextVariableInstances', 'StyleExportTagMap', 'StyleExportTagMaps', 'ParagraphStyleGroup', 'ParagraphStyleGroups', 'CharacterStyleGroup', 'CharacterStyleGroups', 'CompositeFont', 'CompositeFonts', 'CompositeFontEntry', 'CompositeFontEntries', 'NamedGrid', 'NamedGrids', 'IndexingSortOption', 'IndexingSortOptions', 'Bullet', 'NumberingRestartPolicy', 'NumberingList', 'NumberingLists', 'ObjectStyleGroup', 'ObjectStyleGroups', 'Condition', 'Conditions', 'HiddenText', 'HiddenTexts', 'ConditionSet', 'ConditionSets', 'PagesPanel', 'LibraryPanel', 'MenuAction', 'MenuActions', 'ScriptMenuAction', 'ScriptMenuActions', 'Menu', 'Menus', 'MenuElement', 'MenuElements', 'Submenu', 'Submenus', 'MenuItem', 'MenuItems', 'MenuSeparator', 'MenuSeparators', 'Panel', 'Panels', 'Dialog', 'Dialogs', 'Widget', 'Widgets', 'TextEditbox', 'TextEditboxes', 'StaticText', 'StaticTexts', 'Dropdown', 'Dropdowns', 'CheckboxControl', 'CheckboxControls', 'DialogColumn', 'DialogColumns', 'RadiobuttonGroup', 'RadiobuttonGroups', 'RadiobuttonControl', 'RadiobuttonControls', 'IntegerEditbox', 'IntegerEditboxes', 'IntegerCombobox', 'IntegerComboboxes', 'EnablingGroup', 'EnablingGroups', 'AngleCombobox', 'AngleComboboxes', 'PercentCombobox', 'PercentComboboxes', 'RealEditbox', 'RealEditboxes', 'PercentEditbox', 'PercentEditboxes', 'AngleEditbox', 'AngleEditboxes', 'RealCombobox', 'RealComboboxes', 'MeasurementCombobox', 'MeasurementComboboxes', 'MeasurementEditbox', 'MeasurementEditboxes', 'BorderPanel', 'BorderPanels', 'DialogRow', 'DialogRows', 'XMLElement', 'XMLElements', 'XMLAttribute', 'XMLAttributes', 'XMLTag', 'XMLTags', 'XMLImportMap', 'XMLImportMaps', 'XMLExportMap', 'XMLExportMaps', 'ValidationError', 'ValidationErrors', 'XMLComment', 'XMLComments', 'XMLInstruction', 'XMLInstructions', 'XMLItem', 'XMLItems', 'DTD', 'DTDs', 'XmlStory', 'XmlStories', 'XMLRuleProcessor', 'XMLRuleProcessors', 'XMLRuleMatchDat'],
        getClasses: function() {
        return this.classes;
                                                              try {$.dictionary.getClasses();} catch (e) {$.dictionaryCS6Mac.getClasses();}
                                                              • 29. Re: Search document for SpecialCharacters Enumerator
        Dirk Becker Level 4
        That $.dictionary is very similar to the OMV files, so it might help to point the ESTK's object model viewer to your application (i.e. InDesign) and thus cause a rebuild of the OMV file. Eventually even the current script version (as in "versioned script") is considered.
        Regards,
        Dirk
        • 30. Re: Search document for SpecialCharacters Enumerator
        Hi Dirk
        Didn't help for me.
        One could of course loads the omv from the disk to create the sort of fake $.dictionary I posted in 28
        Regards
        Trevor
        • 31. Re: Search document for SpecialCharacters Enumerator
        Marc Autret Level 4
        So, to summarize, $.dictionary may return null in a very few CS6 builds.
        At this point my personal workaround will be to just prepend `$.dictionary &&` before the whole snippet, so that Enumerator.toSource() will work the native way in that special case.
        Marc
        • 32. Re: Search document for SpecialCharacters Enumerator
        Marc Autret Level 4
        So here is my current implementation of the whole thing. (Note that Enumeration.toSource() has been added too. I needed it for improving my ExtendScript-oriented JSON module.)
        // Number.prototype.toHexa() ; Number.prototype.toAdbe()
        Number.prototype.toHexa = function toHexa()
        // Return the "0xHHHH" representation of this number.
        // E.g  123456 => "0x1E240"
        return isNaN(this) ?
        'NaN' :
        ( '0x' + this.toString(16).toUpperCase() );
        Number.prototype.toAdbe = function toAdbe()
        // Return the Adobe's 4-char string this number encodes.
        // [REM] Only makes sense if `this` is U32.
        // E.g  0x414F5069 => "AOPi" ; 0x74787466 => "txtf"
        'NaN' :
        String.fromCharCode( 0xFF&(this>>>24), 0xFF&(this>>>16), 0xFF&(this>>>8), 0xFF&(this>>>0) );
        // Temporary global aliases.
        $.global.E9nProto = NothingEnum.constructor.prototype;
        $.global.E8rProto = ('object' == typeof NothingEnum.NOTHING) && NothingEnum.NOTHING.constructor.prototype;
        // IMPLEMENTATION NOTES
        Idea based on Dirk Becker's 2014 original code at ixta.com.
        Looping through $.dictionary.getClasses() allows to collect every class
        whose Reflection has the 'enumeration' flag. From then we can both
        (a) Build a hashkey from the XML representation of the class (based on
        the sequence of its enum keys) so that we feed a {hash=>className}
        mapping. This process is achieved using an xpath() command.
        =>  Allows to implement Enumeration.prototype.toSource().
        (b) Register each enum key in a {key=>data} structure so that data is
        either a number (if no unique Enumeration is attached to that value),
        or a <value>/<className> string otherwise.
        =>  Allows to implement Enumerator.prototype.toSource() in CS5 and later.
        All needed data are cached in the corresponding methods: callee.DB for
        both, and callee.ENUM_XPATH for Enumeration's xpath request.
        Note. - The below code may consume more than 200 ms in CC 2017 (Win64.)
        [FIX170322]. - It seems that $.dictionary may return `null` in rare CS6
        versions. In that case we just ignore the whole fixer.
        $.dictionary && (function(/*fct*/fClasses,/*fct|false*/fKeys,  QC,XP,QK,a,n,i,x,s,t,k,v)
        QC = (fClasses.DB = {/*hashProps => className*/});
        XP = (fClasses.ENUM_XPATH = "//property[datatype/type='number' or datatype/type='Enumerator']/@name");
        QK = fKeys ? (fKeys.DB = {/*key => value[/className]*/}) : 0;
        // Enum Classes
        QC[String(x.xpath(XP))] = s;
        if( !QK ) continue; // before CS5
        // Enum Keys
        // [FIX170319] Check whether x..property has more than one
        // item (.length()>1) otherwise `for each` would loop inside!
        x = ( 1 < (t=x..property).length() ) ? t : (t.parent());
        if( null===x ){ throw Error("XML Error on Enumeration " + s); }
        for each( t in x )
        if( !(k&&v) ){ throw Error("XML Error on Enumeration " + s); }
        QK[k] = QK.hasOwnProperty(k) ? v : (v + '/' + s);
        (E9nProto.toSource = function toSource(/*0|1=0*/VERBOSE)
        // Output an evaluable string S such as this==eval(S) for any Enumeration.
        // Eg. Locale.toSource() => "(Locale)"
        return '(' +
        callee.DB[String(this.reflect.toXML().xpath(callee.ENUM_XPATH))] ||
        ( "{" + (VERBOSE?"/*not found Enumeration*/":"") + "}" )
        E8rProto && (E8rProto.toSource = function toSource(/*0|1=0*/VERBOSE,  k,v,s)
        // Output an evaluable string S such as this==eval(S) for any Enumerator.
        //   <Enumeration>.<Enumerator> /* 0x<Hexa> [<Tag>] */
        //   Eg: AnchorPosition.INLINE_POSITION /* 0x414F5069 [AOPi] */
        // or
        // [REM] The comment part /*...*/ is added only if VERBOSE is on.
        if( (v=callee.DB[k=String(this)]) && 'string' == typeof v )
        // Case 1  --  String("<number>/<class>")
        // => EnumClass.ENUM_KEY format.
        s = v.substr(1+v.indexOf('/')) + '.' + k;
        if( !VERBOSE ) return s;
        v = parseInt(v,10);
        k = v.toHexa();
        else
        // Case 2 -- Unknown key or number only (multiple parents.)
        // => 0xHHHH format.
        s = (v||(v=this.valueOf())).toHexa();
        return $.global.localize("%1 /* %2 [%3] */", s, k, v.toAdbe());
        // Clear globals.
        delete $.global.E9nProto;
        delete $.global.E8rProto;
        delete $.global.NothingEnum;
        // Tests
        alert( Locale.toSource() );
        // =>  "(Locale)"     --if( $.dictionary )
        // =>  "({})"         --fallback
        alert( Locale.germanLocale.toSource() );
        // => "Locale.GERMAN_LOCALE"      --if( CS5+ && $.dictionary)
        // => "(new Number(1279477613))"  --fallback
        alert( CoordinateSpaces.parentCoordinates.toSource(1) );
        // => "CoordinateSpaces.PARENT_COORDINATES /* 0x78797061 [xypa] */"   --if( CS5+ && $.dictionary)
        // => "(new Number(2021224545))"                                      --fallback
        Marc
        • 33. Re: Search document for SpecialCharacters Enumerator
        Sorry for being the days party pooper, but it ain't working for me.
        I get 3 alerts of ({})
        • 34. Re: Search document for SpecialCharacters Enumerator
        Marc Autret Level 4
        In all versions and platforms? (Weird!)
        [I've tested it in six different versions from CS4 to CC (2017), of course outside of ESTK.]
        Marc
        • 35. Re: Search document for SpecialCharacters Enumerator
        Hi Marc,
        tested your code from reply 32 :
        German CS4 6.0.6.622 on German Mac OSX 10.6.8 :
        Result: "(Locale)" , "(new Number(1279477613))" , "(new Number(2021224545))"
        German CS5 7.0.4.553 on German Mac OSX 10.6.8 :
        Result: "(Locale)" , "Locale.GERMAN_LOCALE" , "CoordinateSpaces.PARENT_COORDINATES /* 0x78797061 [xypa] */"
        German CS5.5 7.5.3.333 on German Mac OSX 10.6.8 :
        German CS6 8.1.0.419 on German Mac OSX 10.6.8 :
        Result: ({}) , ({}) , ({})
        German CC 9.3.0.106 on German Mac OSX 10.6.8 :
        Best,
        Uwe
        • 36. Re: Search document for SpecialCharacters Enumerator
        Marc Autret Level 4
        Hi Uwe,
        Thanks a lot for your detailed report.
        Almost what I was expecting. I just made a mistake in the description of the tests. Indeed, since the snippet does nothing if (!$.dictionary), toSource will simply behaves its native way in that specific case, which explains the ({}) results. One could likely improve this using either Trevor's approach—that is, hardcoding a fake $.dictionary—, or at least this.valueOf() for the purpose of returning a `Number(…)` source for Enumerators in CS6 8.1.0.419 Mac OSX 10.6.8.
        Left as an exercise to the readers ;-)
        Marc
