13 Replies Latest reply on Jan 29, 2012 5:29 PM by Claudio González
    update fails
    joe62665
      while updating 9.4.7 HALF way though computer resets itself or goes to a light blue screen. Removed 9.4.7 from computer tried to downlown the latest 10. ? the same thing happens. Using windows XP service pack 3 HP computer.
        • 1. Re: update fails
          Ankit_Jain Adobe Employee
          Please try downloading the latest version of Adobe Reader from: http://get.adobe.com/reader/enterprise/
          • 2. Re: update fails
            joe62665 Level 1
            Went to where you said to go, downloaded the file, ran the download got 52.21% complete of "extracting installation" and the computer locked up. mouse would not work, keyboard did not work ,clock did not change, waited 45 mins. reset the computer. i am running AVG 2011. went to msconfig ran dianostic setting . Tried to run the download again same results. Have  adobe 9.20 now. took off 9.4 because it locked up on update. put 9.0 on 1 up date went fine. the next update for 9.20 locked up. Need some help. Thank You
            • 3. Re: update fails
              Could you try and temporarily disable the antivirus and retry running the downloaded file.
              It could be a case wherein the antivirus is stopping the installation from taking place.
              • 4. Re: update fails
                The original BillP
                I run an advanced computer shop/lab. Acrobat reader version (Latest 10.1.2) stutters and stalls at 52.21% on ALL of our test systems, then it continues after a second or 2 with decompressing. Test systems use WINXP PRO and Home. (Haven't tried with Vista or WIN7.)  We are also using the full-size install file.
                On a customer's system, procedure stalls at 52.21%, then locks up computer. We disabled anti-virus; disabled ALL start-up items; we even disabled ALL SERVICES. We restarted computer every time, as it had locked up every time. SAFE mode or REGULAR start-up, it didn't make any difference. Just for fun, we uninstalled a couple dozen other programs and re-installed, no problems at all. We didn't bother to try any of the 9.X versions. We'd simply like to know what is happening at the 52.21% of decompression point?? I'd be happy to work with any Adobe staffer.
                • 5. Re: update fails
                  Could you try and delete the following folder depending upon your OS.
                  Win XP
                  C:\Documents and Settings\All Users\Application Data\Adobe\Setup
                  Win 7/ Win Vista
                  C:\Programdata\Adobe\Setup
                  Now try and install the Reader 10.1.2 EXE and see if you face the same issue.
                  Ankit
                  • 6. Re: update fails
                    joe62665 Level 1
                    Tried both solutions --- turned off antivirus and removing the folder did not help. hangs up at the same point.even did all the things Billp did. the only program i removed was reader 9.4.1. did not help.
                    • 7. Re: update fails
                      Looks like some permission issue with the C:\programdata folder wherin the contents are extracted.
                      Could you please try and extract the contents elsewhere and install the application using the following steps:
                      1. Copy the Reader 10.1.2 EXE to a folder say C:\Rdr_EXE
                      2. Launch Command Prompt
                      3. Type in the following command and hit enter:
                          C:\Rdr_EXE\AdbeRdr1012_en_US.exe -sfx_o"C:\Rdr_EXE"
                      This will extract the files at C:\Rdr_EXE folder and install from thereon.
                      Post the installation, you can safely delete the AdbeRdr1012_en_US.exe but Please do not delete the folder since it will be used for repairing the application if the need comes.
                      Hope this works
                      Ankit
                      • 8. Re: update fails
                        joe62665 Level 1
                        that did not work either. i DO NOT have a folder named " programdata" on C drive .note only have one drive. (C) It stops at the same place. i have Windows XP service pack 3. This all started when i tried to update 9.4.1
                        • 9. Re: update fails
                          Did you try running the above mentioned command..?
                          • 10. Re: update fails
                            joe62665 Level 1
                            Yes. I got the same result as before. i followed your steps. did it three times. 2 time it froze the download screen the other time i got a blank RED screen and nothing worked.
                            • 11. Re: update fails
                              Really weird!! Please try running the below command (once more )
                              C:\Rdr_EXE\AdbeRdr1012_en_US.exe -sfx_o"C:\Rdr_EXE" -sfx_ne
                              Does this result in the same issue.
                              • 12. Re: update fails
                                joe62665 Level 1
                                did it TWICE same result same place.
                                • 13. Re: update fails
                                  Claudio González Most Valuable Participant
                                  When everything else fails, you may want to try the following:
                                  Run this fix from Microsoft: http://support.microsoft.com/mats/Program_Install_and_Uninstall
                                  Uninstall all traces of any versions of Reader using Add/Remove Programs
                                  If you want to reinstall Reader, download it from http://get.adobe.com/reader/enterprise/
