0 Replies Latest reply on Jan 19, 2012 3:41 PM by Z4g0s
    Flex mobile TextInput Editable strange behavior
    Z4g0s
      I have a problem using textinput component with the property editable set to false, if it's not editable and I create the components without text I have a wrong layout, otherwise the layout is good...
      it's better to write a simple example...
      I have this two textinput
      <s:TextInput id="lblorig" color="#000000" width="350"
      fontFamily="Verdana" change="lbltrg.text = lblorig.text;" right="0"/>
      <s:TextInput id="lbltrg" color="#000000" editable="false"
      width="350" fontFamily="Verdana" text="" right="0"/>
      Writing a text in the first one will get me this result
      If otherwise in the creation I set the text different from "" I will have a correct behaviour...
      width="350" fontFamily="Verdana" text="default text" right="0"/>
      And changing the text in the first textinput will have a correct update on the not editable one..
      Why is this happening? How can I fix that? I cannot set the default text different from "" so I have to find an altenative solution..
      Thank in advance..
