4 Replies Latest reply on Jan 19, 2012 9:22 PM by VDOSurfer
    PRE 10 will not create a new project
    AlanSaw911
      I have a brand new install of PRE10 and cannot create a new project. The main screen starts and I select New Project, but then the application shuts down. I have tried this on two seperate computers but the same thing happens on both machines. Any help would be great.
        • 1. Re: PRE 10 will not create a new project
          As the note says at the top of this forum, we need clues in order to solve these mysteries.
          What is your operating system? Is it 32-bit or 64-bit? Are you using the 32-bit or 64-bit version of the program?
          How fast is your processor? How much RAM do you have and how much free, clean, freshly defragmented space is on your C or main drive?
          Are you editing on your C drive or to a second or external drive?
          Is the program crashing while you're editing or before you can even start a project?
          What model of camcorder is your video coming from, and which project settings did you select when you started your Premiere Elements project?
          • 2. Re: PRE 10 will not create a new project
            the_wine_snob Level 9
            Welcome to the forum.
            At the very top of this forum, there is a "sticky" on How To Ask a Question. It cycles between another sticky. Take a look at it, and if it is not at the top of the forum's main page, just wait a bit. It goes into detail on the information, that would be so useful to remotely helping a user.
            In the meantime, take a look at this ARTICLE, for ways to get PrE working.If nothing there helps, after the initial checklist, it goes into a series of links on tuning up one's computer, and OS, and then troubleshooting.
            Good luck, and please let us know more,
            • 3. Re: PRE 10 will not create a new project
              Wow, that Steve is FAST!!!!
              I agree with him 100%.
              PS - that is what I get for going after that article link - he beat me...
              • 4. Re: PRE 10 will not create a new project
                VDOSurfer Level 3
                Some thoughts..
                1. Display Driver
                     Update the display driver. Two versions ago, this was a very common problem and the display drivers were usually the culprit.
                2. Corrupt Preferences
                     For this, delete the preferences from where they are created. (Go to Start->Run and paste this link there "%appdata%\Adobe\Premiere Elements\10.0\" and delete the *.prefs file)
                3. Plugins
                     Delete the plugin cache from the registry. Go to Start->Run and type regedit and browse to HKEY_CURRENT_USER\Software\Adobe\Premiere Elements\10.0 and delete the plugin cache folders. They will be recreated once launched successfully.
                4. Reinstall the software, ensure you have Quicktime installed.
