0 Replies Latest reply on Jan 20, 2012 12:18 AM by Andy_I
    TypeError: Error #1034 after generating AS classes from Java using Data Centric Development
    Andy_I
      Hello together,
      is it possible to generate Action Script Classes from complex Java Classes with the new Data-centric development in Adobe Flash Builder 4? I tried it couple of days, but I always run in an TypeError: Error #1034: Type Coercion failed: cannot convert Object@e60c149  to valueObjects.ChildObject.
      In case of complex java Objects, I mean objects which contain an Object again. In my example: Object “parent” comprises Object “child” (Aggregation).
      By loading object “parent” the object “child” cannot be mapped to the Action Script Class, and  it ends in TypeError: Error #1034. Why is the “child” object not mapped? And what can I do, to solve this issue?
      Main Application with Service call:
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     xmlns:services="services.*"
                     minWidth="955" minHeight="600">
          <fx:Script>
              <![CDATA[
                  import mx.rpc.events.ResultEvent;
                  import valueObjects.ParentObject;
                  protected function button_clickHandler(event:MouseEvent):void
                      getMyObjectResult.token = fxService.getMyObject();
                  protected function getMyObjectResult_resultHandler(event:ResultEvent):void
                      var parentObject:ParentObject = getMyObjectResult.lastResult;
                      trace(parentObject);
                      trace(parentObject.childObject);
          </fx:Script>
          <fx:Declarations>
              <s:CallResponder id="getMyObjectResult" result="getMyObjectResult_resultHandler(event)"/>
              <services:FxService id="fxService"
                                  fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)"
                                  showBusyCursor="true"/>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:Button id="button" x="10" y="10" label="getMyObj" click="button_clickHandler(event)"/>
      </s:Application>
      Here are a part of my generated Classes:
      _Super_FxService:
      [ExcludeClass]
      internal class _Super_FxService extends com.adobe.fiber.services.wrapper.RemoteObjectServiceWrapper
          // Constructor
          public function _Super_FxService()
              // initialize service control
              _serviceControl = new mx.rpc.remoting.RemoteObject();
              // initialize RemoteClass alias for all entities returned by functions of this service
              var operations:Object = new Object();
              var operation:mx.rpc.remoting.Operation;
              operation = new mx.rpc.remoting.Operation(null, "getMyObject");
              operation.resultType = valueObjects.ParentObject;
              operations["getMyObject"] = operation;
              _serviceControl.operations = operations;
              _serviceControl.convertResultHandler = com.adobe.serializers.utility.TypeUtility.convertResultHandler;
               preInitializeService();
               model_internal::initialize();
          //init initialization routine here, child class to override
          protected function preInitializeService():void
              destination = "FxService";
            * This method is a generated wrapper used to call the 'getMyObject' operation. It returns an mx.rpc.AsyncToken whose
            * result property will be populated with the result of the operation when the server response is received.
            * To use this result from MXML code, define a CallResponder component and assign its token property to this method's return value.
            * You can then bind to CallResponder.lastResult or listen for the CallResponder.result or fault events.
            * @see mx.rpc.AsyncToken
            * @see mx.rpc.CallResponder
            * @return an mx.rpc.AsyncToken whose result property will be populated with the result of the operation when the server response is received.
          public function getMyObject() : mx.rpc.AsyncToken
              var _internal_operation:mx.rpc.AbstractOperation = _serviceControl.getOperation("getMyObject");
              var _internal_token:mx.rpc.AsyncToken = _internal_operation.send() ;
              return _internal_token;
      _Super_ParentObject
      [ExcludeClass]
      public class _Super_ParentObject extends flash.events.EventDispatcher implements com.adobe.fiber.valueobjects.IValueObject
          model_internal static function initRemoteClassAliasSingle(cz:Class) : void
              try
                  if (flash.net.getClassByAlias("com.fx.model.ParentObject") == null)
                      flash.net.registerClassAlias("com.fx.model.ParentObject", cz);
              catch (e:Error)
          model_internal static function initRemoteClassAliasAllRelated() : void
              valueObjects.ChildObject.initRemoteClassAliasSingleChild();
          model_internal var _dminternal_model : _ParentObjectEntityMetadata;
          model_internal var _changedObjects:mx.collections.ArrayCollection = new ArrayCollection();
          public function getChangedObjects() : Array
              _changedObjects.addItemAt(this,0);
              return _changedObjects.source;
          public function clearChangedObjects() : void
              _changedObjects.removeAll();
           * properties
          private var _internal_childObject : valueObjects.ChildObject;
          private static var emptyArray:Array = new Array();
           * derived property cache initialization
          model_internal var _cacheInitialized_isValid:Boolean = false;
          model_internal var _changeWatcherArray:Array = new Array();
          public function _Super_ParentObject()
              _model = new _ParentObjectEntityMetadata(this);
              // Bind to own data or source properties for cache invalidation triggering
           * data/source property getters
          [Bindable(event="propertyChange")]
          public function get childObject() : valueObjects.ChildObject
              return _internal_childObject;
          public function clearAssociations() : void
           * data/source property setters
          public function set childObject(value:valueObjects.ChildObject) : void
              var oldValue:valueObjects.ChildObject = _internal_childObject;
              if (oldValue !== value)
                  _internal_childObject = value;
                  this.dispatchEvent(mx.events.PropertyChangeEvent.createUpdateEvent(this, "childObject", oldValue, _internal_childObject));
      _Super_ChildObject
      [ExcludeClass]
      public class _Super_ChildObject extends flash.events.EventDispatcher implements com.adobe.fiber.valueobjects.IValueObject
              try
                  if (flash.net.getClassByAlias("com.fx.model.ChildObject") == null)
                      flash.net.registerClassAlias("com.fx.model.ChildObject", cz);
              catch (e:Error)
          model_internal var _dminternal_model : _ChildObjectEntityMetadata;
           * properties
          private var _internal_f : Number;
          private var _internal_d : Number;
          private var _internal_s : String;
          private var _internal_l : Number;
          private var _internal_i : int;
          // Change this value according to your application's floating-point precision
          private static var epsilon:Number = 0.0001;
          public function _Super_ChildObject()
              _model = new _ChildObjectEntityMetadata(this);
          public function get f() : Number
              return _internal_f;
          public function get d() : Number
              return _internal_d;
          public function get s() : String
              return _internal_s;
          public function get l() : Number
              return _internal_l;
          public function get i() : int
              return _internal_i;
          public function set f(value:Number) : void
              var oldValue:Number = _internal_f;
              if (isNaN(_internal_f) == true || Math.abs(oldValue - value) > epsilon)
                  _internal_f = value;
                  this.dispatchEvent(mx.events.PropertyChangeEvent.createUpdateEvent(this, "f", oldValue, _internal_f));
          public function set d(value:Number) : void
              var oldValue:Number = _internal_d;
              if (isNaN(_internal_d) == true || Math.abs(oldValue - value) > epsilon)
                  _internal_d = value;
                  this.dispatchEvent(mx.events.PropertyChangeEvent.createUpdateEvent(this, "d", oldValue, _internal_d));
          public function set s(value:String) : void
              var oldValue:String = _internal_s;
                  _internal_s = value;
                  this.dispatchEvent(mx.events.PropertyChangeEvent.createUpdateEvent(this, "s", oldValue, _internal_s));
          public function set l(value:Number) : void
              var oldValue:Number = _internal_l;
                  _internal_l = value;
                  this.dispatchEvent(mx.events.PropertyChangeEvent.createUpdateEvent(this, "l", oldValue, _internal_l));
          public function set i(value:int) : void
              var oldValue:int = _internal_i;
                  _internal_i = value;
                  this.dispatchEvent(mx.events.PropertyChangeEvent.createUpdateEvent(this, "i", oldValue, _internal_i));
      Could it be that this method is not called? -> initRemoteClassAliasAllRelated()
      Andy the Java objects look like this:
      Model:
      ParentObject:
      package com.fx.model;
      public class ParentObject {
          private ChildObject childObject;
          public ChildObject getChildObject() {
              return childObject;
          public void setChildObject(ChildObject childObject) {
              this.childObject = childObject;
      ChildObject:
      public class ChildObject {
          private String         s;
          private Integer     i;
          private Long        l;
          private Float         f;
          private Double        d;
          public ChildObject(String s, Integer i, Long l, Float f, Double d) {
              super();
              this.s = s;
              this.i = i;
              this.l = l;
              this.f = f;
              this.d = d;
          public String getS() {
              return s;
          public void setS(String s) {
              this.s = s;
          public Integer getI() {
              return i;
          public void setI(Integer i) {
              this.i = i;
          public Long getL() {
              return l;
          public void setL(Long l) {
              this.l = l;
          public Float getF() {
              return f;
          public void setF(Float f) {
              this.f = f;
          public Double getD() {
              return d;
          public void setD(Double d) {
              this.d = d;
      Service:
      package com.fx.service;
      import com.fx.model.ChildObject;
      import com.fx.model.ParentObject;
      public class FxService {
          public ParentObject getMyObject() {
              ParentObject po = new ParentObject();
              po.setChildObject(new ChildObject("hallo", 1, 100l, 1.2f, 1.22222d));
              return po;
      Configuration Files:
      remoting-config.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <service id="remoting-service"
          class="flex.messaging.services.RemotingService">
          <adapters>
              <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
          </adapters>
          <default-channels>
              <channel ref="my-amf"/>
          </default-channels>
          <destination id="FxService">
              <properties>
                  <source>
                      com.fx.service.FxService
                  </source>
                  <scope>session</scope>
              </properties>
          </destination>
      </service>
      web.xml
      <!-- begin rds -->
      <servlet>
      <servlet-name>RDSDispatchServlet</servlet-name>
      <servlet-class>flex.rds.server.servlet.FrontEndServlet</servlet-class>
      <init-param>
      <param-name>useAppserverSecurity</param-name>
      <param-value>false</param-value>
      </init-param>
      <load-on-startup>10</load-on-startup>
      </servlet>
      <servlet-mapping id="RDS_DISPATCH_MAPPING">
      <url-pattern>/CFIDE/main/ide.cfm</url-pattern>
      </servlet-mapping>
      <!-- end rds -->
      If someone wants to see the whole project, I could send it by e-mail.
      Please help me to find the issue.
      Many thanks in advance.
