1 Reply Latest reply on Aug 26, 2006 7:31 PM by Chafic
    Application Class Entry Point?
    arc_twelve
      Can you specify the entry point for the application class? It seems like its the constructor only? You should be able to specify the static main method.
        • 1. Application Class Entry Point?
          Chafic
          In a Flex application only the root Application instance is the first instantiated object. It is not like other platforms where you have a main() method. Your root Application is instantiated and things start there. One way for you to handle having a main method is to set a method handler for the even initialize of the root application
          -- sample root application --
          <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" initialize="init()">
          <mx:Script>
          <![CDATA[
          private function init():void
          //code here
          </mx:Script>
          </mx:Application>
