9 Replies Latest reply on Jan 24, 2012 7:01 PM by -==cfSearching==-
    CFCHART - Percentages not right
    ACS LLC Level 1
      I tried to set up a simple chart to display the results of a query, it works fine with labelformat="numbers", but if I change it to percent the results are odd, I get values above 100% on many of the pie slices. Anybody any idea?
      Here's the code
      <CFCHART
      format="flash"
      show3d="yes"
      showlegend="yes"
      chartheight="800"
      chartwidth="900"
      labelformat="percent"
      showborder="true"
      pieSliceStyle="sliced"
      sortXAxis = "yes"
      <cfchartseries
      type="pie"
      query="GetCountry"
      valuecolumn="countrycounter"  itemcolumn="countrylong" />
      Mark
        • 1. Re: CFCHART - Percentages not right
          Adam Cameron. Level 5
          Can you provide a repro case that includes the data (which is kinda important to your question).
          Just mock a query up with queryNew() / queryAddColumn() etc.
          Where possible, if you have a problem you should try to give us a repro case that is completely self-contained, and stand-alone (without any inferences as to how external systems like DB data might affect what you're seeing).  Obviously this is not always possible, but it definitely is in this case.
          Cheers.
          Adam
          • 2. Re: CFCHART - Percentages not right
            ACS LLC Level 1
            The query is pretty basic
            <CFQUERY NAME="GetCountry" DATASOURCE="#datasource#">
            SELECT countrylong,countrycounter
            FROM countrylist
            WHERE countrycounter > 0
            </CFQUERY>
            Here is a CFDUMP of the data
            query
            RESULTSET
            query
            COUNTRYCOUNTERCOUNTRYLONG
            12 BELGIUM
            213 ALGERIA
            36 KUWAIT
            410 OMAN
            52 VENEZUELA, BOLIVARIAN REPUBLIC OF
            628 PHILIPPINES
            712 BRUNEI DARUSSALAM
            82 CZECH REPUBLIC
            94 GHANA
            101 BANGLADESH
            1171 MALAYSIA
            12505 UNITED STATES
            1332 ITALY
            141 LATVIA
            152 PANAMA
            162 NORWAY
            175 AUSTRIA
            188 ROMANIA
            1963 THAILAND
            205 NETHERLANDS
            2127 MEXICO
            2212 UNITED ARAB EMIRATES
            234 IRAQ
            2422 EGYPT
            2565 KOREA, REPUBLIC OF
            26114 VIET NAM
            273 SWITZERLAND
            2811 SWEDEN
            296 MOROCCO
            3027 UNITED KINGDOM
            3113 SPAIN
            3218 CHINA
            335 CAMBODIA
            3466 INDONESIA
            357 JORDAN
            3626 TURKEY
            3713 SINGAPORE
            383 BAHRAIN
            3934 GERMANY
            4017 AUSTRALIA
            41407 INDIA
            4214 KAZAKHSTAN
            4333 SLOVAKIA
            4414 PAKISTAN
            454 KENYA
            468 UKRAINE
            47111 SAUDI ARABIA
            4826 TAIWAN
            492 ISRAEL
            5029 BRAZIL
            514 PERU
            525 ARGENTINA
            535 COSTA RICA
            541 LAO PEOPLE'S DEMOCRATIC REPUBLIC
            5543 RUSSIAN FEDERATION
            5610 CANADA
            576 SERBIA
            585 PUERTO RICO
            593 SLOVENIA
            603 BELARUS
            614 FINLAND
            6239 HONG KONG
            631 GUAM
            6485 JAPAN
            656 SOUTH AFRICA
            661 ESTONIA
            673 HUNGARY
            686 GREECE
            692 DENMARK
            7016 FRANCE
            711 BULGARIA
            722 GUADELOUPE
            731 TURKMENISTAN
            744 POLAND
            CACHEDfalse
            EXECUTIONTIME2
            SQLSELECT countrylong,countrycounter FROM countrylist WHERE countrycounter > 0
            • 3. Re: CFCHART - Percentages not right
              Can you go back to my earlier post and read it.  You've not provided a repro case, you've just given me a dump of some data.  What am I supposed to do with that?
              A repro case is some code that can be run and deomnstrates the problem (and then it can be tweaked etc to work out what the problem is).  SO go back and - please - do what I've asked you to do.  This is all part of learning how to solve your own problems (which in the long run is gonna be more helpful to you than just asking questions).
              Trust me.
              Adam
              • 4. Re: CFCHART - Percentages not right
                BKBK Adobe Community Professional & MVP
                Here's the code
                <CFCHART
                format="flash"
                show3d="yes"
                showlegend="yes"
                chartheight="800"
                chartwidth="900"
                showborder="true"
                sortXAxis = "yes"
                <cfchartseries
                type="pie"
                query="GetCountry"
                You are right. The chart attribute labelformat="percent" produces a pie chart with percentages that don't match. Indeed, many are several hundred percent! That could possibly be a bug.
                To correct the problem, use the following chartseries attribute instead: datalabelstyle="pattern". That is
                <CFCHART
                format="flash"
                show3d="yes"
                showlegend="yes"
                chartheight="800"
                chartwidth="900"
                showborder="true"
                sortXAxis = "yes"
                <cfchartseries
                type="pie"
                query="GetCountry"
                </cfchart>
                However, be aware that it is inadvisable to represent more than, say, a dozen or so data values on a pie chart. It can then get a bit crowded, especially if you decide to slice the pie, as you have done. In any case, 74 data points is way too much data to represent on a pie chart.
                • 5. Re: CFCHART - Percentages not right
                  ACS LLC Level 1
                  Thanks for the help, I could not find any info on datalabelstyle, and even after a search now that I have it I can't find anything
                  You are right, once I added this, its a little busy, trying to label every country
                  I think I might be best trying to label with a percentage and then mouse over for the country with percentage but I'm not sure if this can be done?
                  Right now when I mouse over the slice I get the country name with a total, but no percentage.
                  Is it possible to put the percentage and country etc into the mouse over label?
                  Then perhaps I can switch the regular label to just a percentage
                  Thanks!
                  Mark
                  • 6. Re: CFCHART - Percentages not right
                    The functionality you seek could be in some curious attribute combination in there somewhere. However, we could also play dumb, and create just what we need manually, and then do a mouseover. I was thinking of something like this
                    <cfquery name="getSum" dbtype="query">
                        select sum(countrycounter) as sumCounter
                        from GetCountry
                    </cfquery>
                    <cfquery name="getCountryPercentage" dbtype="query">
                        select countrycounter*100/#getSum.sumCounter# as countryCounter, countrylong
                        from GetCountry
                    </cfquery>
                    <CFCHART
                    format="flash"
                    show3d="yes"
                    showlegend="yes"
                    chartheight="800"
                    chartwidth="900"
                    showborder="true"
                    tipStyle = "mouseOver"
                    sortXAxis = "yes"
                    <cfchartseries
                    type="pie"
                    query="getCountryPercentage"
                    </cfchart>
                    • 7. Re: CFCHART - Percentages not right
                      ACS LLC Level 1
                      Very Creative
                      That's much easier to read now, the only thing I am missing is the totals, in the first attempt on the main labels that were visible without mouse over it had the count of the slice and also 'out of' ... am I pushing it now ;-)
                      Mark
                      • 8. Re: CFCHART - Percentages not right
                        ACS LLC wrote:
                        Very Creative
                        That was the datalabelstyle="pattern" attribute of the chartseries. However, it puts the "out of..." on the chart itself, not on the mouseover. In any case, if we were to do that now, I would expect it to say "out of 100%"!
                        • 9. Re: CFCHART - Percentages not right
                          -==cfSearching==- Level 4
                          "LabelFormat"  does not perform calcuations. It just applies a simple mask to the axis values, controlling how they are displayed ie As a simple number (33), percentage (3300%), currency ($33.00) etecetera.
