7 Replies Latest reply on Jan 23, 2012 3:45 AM by nealeh
    PE 8 Burn errors
    videowrk
      I have a project that I can not get to burn.  The project will burn as mpg with no menus but I can not burn the project to a disc or a folder.  I get a Device Error:  the target device isn't suitable for use. When I cancel burn then Adobe sometimes hangs and I have to force shut down of Adobe because it is not responding.  I did save this project as AVI, pulled it into a new project, created markers and menu again, that didn't help.  Any ideas?
        • 1. Re: PE 8 Burn errors
          These messages are about Encore... but that is still an Adobe product, so the IDEAS here may help, even if not the exact steps
          As well as the below, right click the Encore icon and select Run as Administrator, which is NOT the same thing as running the computer with the Administrator account, and which fixes several "odd" problems... To create a dual layer DVD (or a BluRay?), you MUST have Encore set to use the Run as Administrator option
          Run as Administrator http://forums.adobe.com/thread/771202
          Odd Errors http://forums.adobe.com/thread/670174
          Long File Names or odd characters cause problems
          Read http://forums.adobe.com/thread/588273
          And #4 http://forums.adobe.com/thread/666558
          And This Message Thread http://forums.adobe.com/thread/665641
          Encore "No Drive" Error http://forums.adobe.com/thread/569230
          Things and Software to AVOID when authoring/burning a DVD
          Start --> http://forums.adobe.com/thread/608660
          #2 has WHY Explained http://forums.adobe.com/thread/607390
          Plus http://forums.adobe.com/thread/562941
          Create an ISO (Encore) or folder on your hard drive (Encore or Premiere Elements) and then use the FREE http://www.imgburn.com/index.php?act=download to write files or folders or ISO to disc (send the author a PayPal donation if you like his program)
          • 2. Re: PE 8 Burn errors
            nealeh Level 5
            Have you put a Stop marker at the very end of your timeline? If so delete it - PRE automatically considers the end of the timeline a 'Stop' and adding one manually can trip up PRE during the Share phase.
            Have you any Packet writing disk software installed (eg. Nero inCD, Roxio Drag To Disk, Roxio Direct CD) ? If so uninstall those components. John's links above will give you more detail about these products and why they can stop PRE working.
            Was that using Share> Computer> AVI ? What was your project setting for the new project to which you added the AVI file ?
            Cheers,
            Neale
            • 3. Re: PE 8 Burn errors
              the_wine_snob Level 9
              Also, for the Burn to Folder, how much defragmented, free-space do you have on your HDD's, and especially the destination HDD with that folder, to which you are attempting to burn?
              • 4. Re: PE 8 Burn errors
                videowrk Level 1
                THANK YOU, THANK YOU, THANK YOU.  I changed file name, took out stop menu. It burned to folder.  I downloaded imgburn, project burned to DVD just great! I was through the ringer on this one, had compatability issues with disc's and resolved that with burner mfg in finding compatible disc to burner.  Adobe was beating me up with all the different errors, program hanging, sometimes burn, sometimes not, and often burned dvd had skips.  It has been a long haul, but I think we got it.  Thanks again.
                • 5. Re: PE 8 Burn errors
                  When a burned DVD-Video skips, or hangs, the most common problem is the brand of blank disc used. This ARTICLE goes into more detail, with some suggestions for brands to use. Also, see this ARTICLE for some discussion on burning DVD-Videos for playback on set-top players.
                  • 6. Re: PE 8 Burn errors
                    Ted Smith Level 3
                    PE can alos give problems if your burner is capable of writing at speeds faster than the blank is capablew of.
                    Thats why Imgburn and some other burning programs are better for burning because you can set your burner speed to the same (or slower) than the blank disk spec.
                    Better to burn at one half the blank disk speed because some players may not be able to read it if the "tracks" are not burnt "deep enough".
                    • 7. Re: PE 8 Burn errors
                      nealeh Level 5
                      Pleased to hear the stop marker deletion fixed your issue. For blank media I always use Verbatim printables myself, both Single and Dual Layer. Rarely get a problem. I also only ever burn at x4.
                      Cheers,
                      Neale
