4 Replies Latest reply on Jan 23, 2012 8:05 AM by Dave LaRonde
    AE CS4 crashes when rendering
    Splendes
      Since the last update to version 9.0.3.8 dva 2.0.0.161039  crashes when rendering.
        • 1. Re: AE CS4 crashes when rendering
          You did not provide any info about your system, your project, your footage, your render settings etc., which makes your whole comment utterly useless....
          Mylenium
          • 2. Re: AE CS4 crashes when rendering
            Splendes Level 1
            I have AE 9.0.3, using a windows Intel Core i7-2600 Processor (8M Cache, 3.40 GHz) 4GB RAM.
            It a very simple project, with version 9.0.2 to and are already' succeeded in renderind and after the upgrade to 9.0.3 fails more to do, after a good start and fast after a while begins to slow down until total blockade.
            Sorry but I do not speak English and it's difficult to explain. Do you understand Italian?
            • 3. Re: AE CS4 crashes when rendering
              Splendes Level 1
              The project I usually rendered above is an file.mov of 29451 kb.
              • 4. Re: AE CS4 crashes when rendering
                Dave LaRonde Level 6
                There are common causes to many problems in AE.  Here is a list of them:
                Are you trying to use multiprocessing, also called "render multiple frames simultaneously"?  Turn it off:  you don't have enough memory to make it work.
                Are you using Open GL to make rendering faster?  Turn it off: Open GL does not work well for rendering.
                Are you using footage from a DSLR, HDV camera, GoPro camera, or Sony XD camera?  Many cameras record video using an encoding technique called long-gop, and AE 9 can't use it.  You should convert it to a lossless codec like Quicktime's Animation or PNG codecs.
