11 Replies Latest reply on Jan 27, 2012 9:01 AM by John Hawkinson
    InDesign CS4 ExtendScript can't report fn.exists status?
    vze26m98 Level 1
      Hi all-
      I'm running Windows XP and Indesign CS4 (6.06), and I can't get ExtendScript to tell me that a file exists. It seems to be because the XML of placed files has a different URI than ExtendScript wants to see. Here's the XML of a placed file:
      Here's some not very attractive code:
      var fn = new File('file:///Documents%20and%20Settings/Admin/My%20Documents/SAP-2_2_1-ISSUED%20TO%20CHARLES/Links/Signs/A1104.pdf');
      $.writeln('file:///Documents%20and%20Settings/Admin/My%20Documents/SAP-2_2_1-ISSUED%20TO%20CHARLES/Links/Signs/A1104.pdf');
      $.writeln('exists: ' + fn.exists);
      var pictureElement = app.activeDocument.xmlElements[0].xmlElements[4].xmlElements[0].xmlElements[6].xmlElements[0].xmlElements[0];
      fn = new File(pictureElement.xmlAttributes[0].value);
      $.writeln(pictureElement.xmlAttributes[0].value);
      And here's the result of running the code:
      It looks like ExtendScript will report true for fn.exists if the URL starts with "file:///Documents...", but reports false if the filename starts with "file:///C:/Documents..." which is (sadly) the results that InDesign wants to place into an XML picture href attribute.
      As a side note, none of this seems a problem on OSX with CS5.
      I know I might not have given folks enough information here, but does this ring a bell with anyone? What's going on?
      Best and thanks, Charles
        • 1. Re: InDesign CS4 ExtendScript can't report fn.exists status?
          Marijan Tompa [tomaxxi] Level 4
          Hi Charles,
          Here is a quick fix. Change fn variable to this:
          fn = new File(pictureElement.xmlAttributes[0].value.toString().replace("file:///", ""));
          Hope that helps.
          Marijan (tomaxxi)
          http://tomaxxi.com
          • 2. Re: InDesign CS4 ExtendScript can't report fn.exists status?
            John Hawkinson Level 5
            Charles:
            As tomaxxi implied and I think you yourself said, the syntax for file:// URLs on with DOS driver letters is not universally defined, and ExtendScript and InDesign XML apparently do it differently. I think you're much better off just handing the platform path to the File() constructor.
            Aside: Marijan's method, which feels familiar to me (ha ha ha!) doesn't account for files that might actually have file:/// in their filenames somewhere. Hopefully that's not possible.
            • 3. Re: InDesign CS4 ExtendScript can't report fn.exists status?
              vze26m98 Level 1
              Hi John and Marijan-
              Thanks for the confirmation and suggested workaround. Pretty amazing such a mismatch existed, but I guess Adobe's a big company...
              Best wishes, Charles
              • 4. Re: InDesign CS4 ExtendScript can't report fn.exists status?
                You should at least give him the Helpful Answer points!
                Well, XML is really the neglected stepchild of the black sheep of the family, right? Of course, you don't want to know what ExtendScript is in that metaphor...
                • 5. Re: InDesign CS4 ExtendScript can't report fn.exists status?
                  vze26m98 Level 1
                  Apologies- For some reason, I thought there was only one award per question. Hopefully, you'll excuse me as a relative newbie to the forum.
                  Charles
                  • 6. Re: InDesign CS4 ExtendScript can't report fn.exists status?
                    John,
                    I really don't see how the file:/// could appear somewhere in the path.
                    Windows doesn't allow any special characters in file names.
                    But in case it happens, Charles can use RegExp search instead of
                    simple string search:
                    fn = new File(pictureElement.xmlAttributes[0].value.toString().replace(/^file\:\/\/\//, ""));
                    Marijan (tomaxxi)
                    • 7. Re: InDesign CS4 ExtendScript can't report fn.exists status?
                      Yeah, I don't think so either, hence "Hopefully that's not possible."
                      I had tried to find a short snippet that was readable and functional, and sort of gave up. IMO regexps with backslash escapes approach unreadable. Maybe Regexp("^file:///"") is the way to go. Ugh.
                      • 8. Re: InDesign CS4 ExtendScript can't report fn.exists status?
                        vze26m98 Level 1
                        I think I'm far enough out of the woods with this issue that I can add a a caveat:
                        Windows uses drive letters for volume names, and these need to be included in the absolute filename.
                        InDesign CS4 and CS5.5 XML both want to write something like:
                        file:///C:/restofthepath...
                        where ExtendScript wants to see:
                        file:///c/restofthepath...
                        A fix for this would have to take into account additional drives other than the root, eg:
                        file:///z/restofthepath...
                        and so forth.
                        I have no idea whether the volume name needs to be lowercase. I also assume that "file:///restofthepath..." can refer to the root volume (this is the behavior that ExtendScript suggests), but I haven't explicitly tested it.
                        HTH, Charles
                        • 9. Re: InDesign CS4 ExtendScript can't report fn.exists status?
                          Charles, are you saying that you cannot give the File constructor a path with a colon, like new FIle("C:/restofpath")? I was under the impression that doing so worked fine, hence tomaxxi's solution of stripping off the leading file:// (or maybe file:///) before calling the constructor?
                          • 10. Re: InDesign CS4 ExtendScript can't report fn.exists status?
                            vze26m98 Level 1
                            Well, my knowledge is conditioned by my particular interest.
                            My situation involves creating placed pictures inside a TextFrame which is reflected in an XML structure. Because I'm interchanging XML data with Filemaker, I have an interest in verifying whether the picture links are preserved during the interchange. So I run through the XML structure after import to InDesign, and verify whether the files listed in the "href" attribute of a picture element actually exist on disk.
                            InDesign wants to use "file:///C:/restof path..." in the XML. It's a product of the placement process and can't be changed without bad consequences AFAICT.
                            ExtendScript can't take this filespec as a string from the XML, and on construction of a new File object with it, recognize that it exists. This is because ExtendScript wants to see "file:///c/restofpath..." Under those conditions, ExtendScript will construct a File object and recognize that the file already exists on disk.
                            I'm not certain whether ExtendScript actually constructs a new File object when the "file:///C:/restofpath..." incantation is used. As far as I got was quizzing the length of the new File, which returned -1. Obviously, reading and writing a file under the circumstances would have bad consequences, because there's a file with the same filespec actually residing at that location. So whether use of the File object ExtendScript returns from the constructor results in overwriting the existing file, or worse, I do not know.
                            HTH, Charles
                            • 11. Re: InDesign CS4 ExtendScript can't report fn.exists status?
                              It doesn't look like you answerd me about omiting file://.
                              I would try the .exists() method.
                              Not sure why reading the file is dangerous.
