2 Replies Latest reply on Jan 23, 2012 11:05 AM by tommit8721
    Premier Elements 9 operating problems
    tommit8721
      I am just getting around to using Premiere Elements 9.  I installed it and Photshop Elements 9 at one time several months ago and have used Photshop Elements with no problems.
      A. When I start Premiere Elements and get to the Welcome Screen.  I select "New Project" after a short period the New Project Window pops up.  I can not enter data into the window.  If I close that window, and go to File, New, Project.  The New Project window opens again with the Name box Highlighted with "New Project".  I give it a new name after which nothing can be entered in the other boxes and "OK" can not be selected.
      B. At this point, I uninstalled Premiere Elements then reinstalled it with my installation disk.  It promps to shut down the computer after disk 1 whick I did.  After rebooting the computer,  I again went to the welcome screen of Premier Elements and select "New Project".  The new project window opens with the Name Box Highlighted with "New Project".  I give it a new name and I can now select "OK".  The program now opens.  A box appears indicatiing there is limited content and asks to install additonal content with the content disk after which I then inserted the disk 2.  It asks to select "Yes" but I can not select it.  Therefore the Content Installation Disk will not install at this point.
      C. At this point, I close the program and then Installed the Premiere Elements Content Disk.  I restart the program and at the "Welcome Screen" I select "New Project".  The program responds exactly as in the paragraph A. shown above with no access to the program.
      D. I again uninstalled and then reinstalled Premiere Elements.  At the completetion of the installation of disk 1, instead of shutting down and rebooting.  I now install the content from disk 2.  I now reboot the computer and go to the Welcome Screen and select "New Project".  The program responds exactly as in paragraph A. above with no access to the program.
      I am at a loss to figure out how to get this program to work.  For your information, I am using windows 7,  64-bit on a Dell XPS 8100 desktop computer.
      Any help in this matter would be greatly appreciated.
      Tom Mitchell
        • 1. Re: Premier Elements 9 operating problems
          the_wine_snob Level 9
          Tom,
          Welcome to the forum.
          Take a look at this ARTICLE, which starts with a checklist to get PrE working best. It next goes into a lot of troubleshooting steps to tune up one's OS, and computer.
          I would also look into your dispaly driver, i.e. the video card's driver. What make/model of video card do you have installed?
          What is the installed video driver's number/date?
          Have you gone to the Dell driver download page, to see what the latest driver is? If not, that would be my first step, and download and install that driver.
          • 2. Re: Premier Elements 9 operating problems
            tommit8721 Level 1
            Bill,
            Thanks for the tip.  I tried a tip that I belive you have previously given.  In this tip, right clip on PrE shortcut select Properties.  Under Compatibilty, Check the Disable desktop compostion box.  Click OK.
            I performed these operations and PrE now works fine.
            Thanks again,
            Tom
