1 Reply Latest reply on Jan 30, 2012 11:09 AM by PECourtejoie
    Intermittent errors with mxmlc
    gjewell17
      Hi All,
      I have recently begun to encounter intermittent errors when executing the mxmlc ant task.  This appears to be some sort of timing issue, because I can just re-run the task and have the build run to completion.  The errors that I get vary, but usually are either invalid implicit coercions (with a line number being reported of -1), or attempting to access fields or functions that don't exist (with an actual line number where the error supposedly occurs).  In each of these case, I get many errors, followed by a ton of invalid embed commands.
      As I mentioned before, simply re-running the task will either cause a successful compilation, or a completely different set of errors and line numbers being reported.  This is turning into a very high visibility issue because automated builds are failing, and the only thing that I can do is to tell them to run it again.
      Here is the list of options that I'm sending to mxmlc:
      static-link-runtime-shared-libraries=true
      debug=false
      keep-generated-actionscript=false (have changed to true in an attempt to find the problem)
      incremental=false
      We are using the 4.5.1 "full" SDK, ant 1.8.2, and JDK 1.6.0_30.
      Thank you for any help or insight!
