7 Replies Latest reply on Jun 14, 2006 3:14 PM by flashfloozie
    preloader Can't be used on swf with flv playback component
    flashfloozie Level 1
      Cannot find a solution in any forum;
      Either preloader wont show up till the 32K baggage the component brings along to frame one loads (at about 75% , OR change publish setting for AS to load classes to frame 2 and then the movie does not play when run from the actual swf file.
      However the movie DOES play within flash after the second ctrl enter to see it with bandwidth profiler enabled. (makes you think you found the solution) I've even tried putting the flv on separate scene.
      Placing flv in separate swf file and using Loadclip has big delay when swf file is loaded,
      Is there some script snippet that plays the flv's without the use of any component?
      I've been fighting this problem on and off for quite some time now.
