2 Replies Latest reply on Jan 23, 2012 1:29 PM by jfb00
    Air menu
    jfb00 Level 3
      I am using nativeMenu in desktop Air app. Each option of the menu will be a separate window component.
      How can replace or display each component (each option of the menu) in the front of my app?
      Johnny
        • 1. Re: Air menu
          isabelle loyer
          Do you work on Mac Os or on Window system?
          In both system, you can do soemthing like that:
          var wViewCompoent:wComponent = new wComponent();
          wViewCompoen.open(true);
          If you work on Window, I'll be happy to see how you load you menu. Because, in my case, I don't found how to attach menu to application.
          Best regards
          • 2. Re: Air menu
            jfb00 Level 3
            It should be a way to replace the nativeWindow with the component that I need, or not?
            Let me try your suggestion.
            Thanks for you reply and help.
            Best,
            Update:
            I forgot to mention that it is an example of NativeMenu in Tour of Flex under Air Applications.
            Download Tour of Flex http://www.adobe.com/devnet/flex/tourdeflex.html
