2 Replies Latest reply on Jan 26, 2012 12:22 PM by DonMitchinson
    how to save the edited datagrid using array collection?
    mostpranoy Level 1
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:mx="library://ns.adobe.com/flex/mx"
        title="demo2">
        <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
        </fx:Declarations>
        <fx:Script>
        <![CDATA[
        import mx.collections.ArrayCollection;
        import mx.events.FlexEvent;
        import spark.components.gridClasses.IGridItemEditor;
        import spark.components.gridClasses.IGridItemRenderer;
        import spark.events.GridItemEditorEvent;
        [Bindable]
        private var myDP:ArrayCollection = new ArrayCollection([
        {label1:"Day1 ", label2:" Sub1", label3:"Sub2 ", label4:"Sub3 ", label5:"Sub4 ", label6:"Sub5 ", label7:"Sub6 "},
        {label1:"Day2 ", label2:" Sub1", label3:"Sub2 ", label4:"Sub3 ", label5:"Sub4 ", label6:"Sub5 ", label7:"Sub6 "},
        {label1:"Day3 ", label2:" Sub1", label3:"Sub2 ", label4:"Sub3 ", label5:"Sub4 ", label6:"Sub5 ", label7:"Sub6 "},
        {label1:"Day4 ", label2:" Sub1", label3:"Sub2 ", label4:"Sub3 ", label5:"Sub4 ", label6:"Sub5 ", label7:"Sub6 "},
        {label1:"Day5 ", label2:" Sub1", label3:"Sub2 ", label4:"Sub3 ", label5:"Sub4 ", label6:"Sub5 ", label7:"Sub6 "},
        {label1:"Day6 ", label2:" Sub1", label3:"Sub2 ", label4:"Sub3 ", label5:"Sub4 ", label6:"Sub5 ", label7:"Sub6 "}
        protected function myDG_gridItemEditorSessionSaveHandler(event:GridItemEditorEvent):void
        // TODO Auto-generated method stub
        protected function button1_clickHandler(event:MouseEvent):void
        navigator.popView();
        protected function button2_clickHandler(event:MouseEvent):void
        myDG.editable=false;
        myDP
        protected function myDG_exitStateHandler(event:FlexEvent):void
        </fx:Script>
        <s:DataGrid id="myDG" x="10" y="45" width="460" height="240" dataProvider="{myDP}"
        editable="true" exitState="myDG_exitStateHandler(event)" fontSize="11"
        gridItemEditorSessionSave="myDG_gridItemEditorSessionSaveHandler(event)"
        rowHeight="30" variableRowHeight="true" selectionMode="singleCell" >
        <s:columns>
        <s:ArrayList>
        <s:GridColumn dataField="label1" headerText="day" editable="false" />
        <s:GridColumn dataField="label2" headerText="9-10am"/>
        <s:GridColumn dataField="label3" headerText="10-11am"/>
        <s:GridColumn dataField="label4" headerText="11am-12noon"/>
        <s:GridColumn dataField="label5" headerText="1-2pm"/>
        <s:GridColumn dataField="label6" headerText="2-3pm"/>
        <s:GridColumn dataField="label7" headerText="3-4pm"/>
        </s:ArrayList>
        </s:columns >
        </s:DataGrid>
        <s:Button x="404" y="10" width="53" height="27" label="Back" click="button1_clickHandler(event)"
         fontSize="13"/>
        <s:Button x="24" y="10" width="56" height="27" label="Save" click="button2_clickHandler(event)"
         fontSize="14"/>
      </s:View>
      i have this gatagrid view i want to save the edited datagrid back to the array collectionas a click the save button!!!
      please help me!!
        • 1. Re: how to save the edited datagrid using array collection?
          mostpranoy Level 1
          please help me!!
          • 2. Re: how to save the edited datagrid using array collection?
            DonMitchinson
            You need to use two data binding on the dataFields.
            The only way I've done this on a datagrid is to use a custom item renderer for the datagrid  column.
            For example if it's just a text field - which it kind of looks like in your example than add a textbox
            as the DataGridColumn item renderer - and make the column itemrendereriseditable value = "true"
            Adding an @ sign before the bindable data field makes it a two way binding
            so .. from your example
            becomes ..
            <s:GridColumn dataField="label2" headerText="9-10am" rendererIsEditable="true">
                <s:itemRenderer>
                    <fx:Component>
                        <s:GridItemRenderer>
                            <s:HGroup left="5" top="2" horizontalAlign="center" verticalAlign="middle">
                                <s:TextInput width="50" text="@{data.label2}" textAlign="center" />
                            </s:HGroup>
                        </s:GridItemRenderer>
                    </fx:Component>
                </s:itemRenderer>
            </s:GridColumn>
