29 Replies Latest reply on Jan 25, 2012 11:15 PM by kglad
    Creating images error.
    McbainGames11 Level 2
      Hey,
      I am having problem creating my ice_block.png photo appear on the screen + be munipulated. Well I can get it to come up on the screen but when I try do things like change in positions of x+y, put in array it just shows #1007 or #1009 error!
      Level Class:
      package
                import com.greensock.*;
                import com.greensock.easing.*;
                import com.greensock.plugins.*;
                import flash.display.Bitmap;
                import flash.display.DisplayObject;
                import flash.display.MovieClip;
                import flash.display.Sprite;
                import flash.events.Event;
                import flash.filters.DisplacementMapFilter;
                TweenPlugin.activate([AutoAlphaPlugin]);
                public class Level extends Sprite
                          public var enemyA:Array = [];
                          public var birdA:Array = [];
                          public var birdImageHolder:Sprite = new Sprite();
                          public function Level()
                                    createBird();
                                    createEnemy();
                                    this.addEventListener(Event.ENTER_FRAME, loopF);
                          public function createBird():void
                                    //Creating the bird..
                                    addChild(birdImageHolder);
                                    birdImageHolder.y = 330;
                                    var birdImage:Bitmap = new Assets.bird();
                                    birdImageHolder.addChild(birdImage);
                                    birdImage.y = -37;
                                    birdImage.x = -40;
                                    //TweenLite functions..
                                    birdImage.alpha = 0;
                                    TweenLite.to(birdImage, 4, { alpha:1, visible:1, ease:Expo.easeOut });
                           public function createEnemy():void
                                    var enemyImageHolder:MovieClip = new MovieClip();
                                    var max_enemies:int = 10;
                                    var gap:int = 100;
                                    for(var i:int=1; i<max_enemies; i++)
                                              addChild(enemyImageHolder);
                                              var enemy:Bitmap = new Assets.iceBlock();
                                              enemyImageHolder.addChild(enemy);
                                              enemy.x = 200;
                                              enemy.y =  -30.65;
                                              enemyA.push(enemy);
                                              enemy.name = "enemyA";
                          public function updateEnemyPosition():void
                                    var fall_limit:int = 2;
                                    for(var i:int; i<enemyA.length; i++)
                                              var enemy:DisplayObject = new enemyA[i] as DisplayObject;
                                              enemy.y += fall_limit;
                          public function updateBirdPosition():void
                                    birdImageHolder.x = mouseX;
                          public function loopF(event:Event):void
                                    updateBirdPosition();
                                    updateEnemyPosition();
      Assets Class(Basically just my library, this doesn't matter just want to show everything I have done!):
      package
                public class Assets
      //Project library..
                          [Embed(source="../images/ice_block.png")]
                          public static var iceBlock:Class
      I have tried alot of combinations to try fix this, But I guess I have missed something. So I'm here to ask the pros
      All help appreciated, Thankyou!
        • 1. Re: Creating images error.
          copy and paste the error and highlight the line of code mentioned in the error message after ticking "permit debugging".
          • 2. Re: Creating images error.
            TypeError: Error #1007: Instantiation attempted on a non-constructor.
                      at Level/updateEnemyPosition()[C:\Users\Brendon Battye\Adobe Flash Builder 4.5\Ice Mountain\src\Level.as:68]
                      at Level/loopF()[C:\Users\Brendon Battye\Adobe Flash Builder 4.5\Ice Mountain\src\Level.as:79]
            Line 68 -> var enemy:DisplayObject = new enemyA[i] as DisplayObject;
            Line 79 -> updateEnemyPosition();
            Don't know what "Permit Debugging" is in Flash Builder, but this was just a normal debug.
            • 3. Re: Creating images error.
              use:
              var enemy:DisplayObject = enemyA[i] as DisplayObject;
              • 4. Re: Creating images error.
                That fixed most of problem
                Any reason why this code I just added would show an error? I added it in the for loop in createEnemy();
                enemy.x = Math.random() * stage.stageWidth - enemy.width;
                TypeError: Error #1009: Cannot access a property or method of a null object reference.
                          at Level/createEnemy()[C:\Users\Brendon Battye\Adobe Flash Builder 4.5\Ice Mountain\src\Level.as:56]
                          at Level()[C:\Users\Brendon Battye\Adobe Flash Builder 4.5\Ice Mountain\src\Level.as:26]
                          at Main/playGame()[C:\Users\Brendon Battye\Adobe Flash Builder 4.5\Ice Mountain\src\Main.as:140]
                Line 26 -> createEnemy();
                Line 56 -> enemy.x = Math.random() * stage.stageWidth - enemy.width;
                • 5. Re: Creating images error.
                  enemy is not defined in line 56.
                  • 6. Re: Creating images error.
                    How can I define it, I thought var enemy:Bitmap = new Assets.iceBlock(); does that.
                    • 7. Re: Creating images error.
                      i don't see that line 56 in your code where is it?
                      • 8. Re: Creating images error.
                        I just added it which is arising another problem. I originally removed those lines so I could fix the other error so there isn't 2
                        • 9. Re: Creating images error.
                          if you want help with this latest problem, copy and paste the code the contains the problematic code and bold the problematic line.
                          • 10. Re: Creating images error.
                                                          var gap:int = 100;
        enemy.y =  i * (gap + enemy.height) - 30.65;
        enemyA.push(enemy);
                            • 11. Re: Creating images error.
                              if the following trace is "null", you're not returning anything when using new Assets.iceBlock().
                              as a matter of fact, didn't you make the same error earlier today when you were supposed to be using:
                              var enemy:Bitmap=Assets.iceBlock();
                                                            var gap:int = 100;
                              trace(enemy);  // when you see "null" for this trace use:  var enemy:Bitmap=Assets.iceBlock();
        enemyA.push(enemy);
                              • 12. Re: Creating images error.
                                I tried all possibilities I could find, I tried changing to not be in sprite etc but it just doesn't like * stage.stageWidth - enemy.width;.
                                If I do:
                                enemy.x = Math.random();
                                It works.. but it isn't the code i want... * stage.stageWidth - enemy.width; is not being aloud for some reason
                                And my method with creating the object works fine in my Main Class so that should be ok.
                                Still can't find any problems!
                                It traced: Assets_iceBlock6
                                • 13. Re: Creating images error.
                                  if that trace wasn't null, use:
                                  enemyImageHolder.stage.stageWidth
                                  instead of
                                  stage.stageWidth
                                  • 14. Re: Creating images error.
                                    Same thing happened #1009
                                    • 15. Re: Creating images error.
                                      trace?
                                      • 16. Re: Creating images error.
                                        Assets_iceBlock6
                                        • 17. Re: Creating images error.
                                          replace your createEnemy() with the following and copy and paste the traces.
                                          trace(this.stage);
        var gap:int = 100;
        var enemy:Bitmap = Assets.iceBlock();
                                          trace(enemy);
                                          trace(enemy.x);
                                          trace(enemy.width);
                                          trace(stage);
                                          trace(enemyImageHolder.stage)
        enemyA.push(enemy);
                                          • 18. Re: Creating images error.
                                            null
                                            ArgumentError: Error #1112: Argument count mismatch on class coercion.  Expected 1, got 0.
                                                      at Level/createEnemy()[C:\Users\Brendon Battye\Adobe Flash Builder 4.5\Ice Mountain\src\Level.as:55]
                                            • 19. Re: Creating images error.
                                              your class can't get a reference to the stage.  you need to pass to your class something that's in the display list.
                                              • 20. Re: Creating images error.
                                                How would I begin to do that, don't fully understand.
                                                • 21. Re: Creating images error.
                                                  you need to pass a displaylist object to your class or use a class with a static variable to pass a reference to the stage.
                                                  • 22. Re: Creating images error.
                                                    So create a function like: public function createObjectEnemy():Sprite
                                                    and then pass it through as enemy = createObjectEnemy(); and do the things I want to it in the  for loop?
                                                    • 23. Re: Creating images error.
                                                      no.
                                                      from somewhere you're using something like:
                                                      var level:Level=new Level();
                                                      correct?  if yes, and the following trace() reveal the stage:
                                                      trace(this.stage);
                                                      use:
                                                      var level:Level=new Level(this.stage); // and change your Level constructor to accept this stage reference.
                                                      • 24. Re: Creating images error.
                                                        Still the same thing happening with these changes.. I must have done it wrong.
                                                        Trace Output: [object Stage]
                                                        Level constructor name: public function Level(stage:Stage)
                                                        Error: #1009 - Null
                                                        • 25. Re: Creating images error.
                                                          stage is a reserved word.  don't use it for a parameter name:
                                                          public function Level(stageVar:Stage){
                                                          trace(stageVar);
                                                          • 26. Re: Creating images error.
                                                            Now do I use that variable in the function to reference stage in the other function? Like: stageVar.stageWidth
                                                            • 27. Re: Creating images error.
                                                              yes.
                                                              but you'll need to make that parameter available outside your construtor in Level:
                                                              var _stage:Stage; // declare your variable
                                                              public function Level(stageVar:Stage){ // in your constructory define _stage
                                                              _stage=stageVar;
                                                              • 28. Re: Creating images error.
        Your very helpful, I normally work with Main Class so never encountered this until now
        Thankyou!
        • 29. Re: Creating images error.
        you're welcome.
