7 Replies Latest reply: May 3, 2013 3:02 AM by Falcon79 RSS
    Assembler and PDF/A ??
    jpadron_uy Community Member
      We have Adobe LC ES2 SP2 and froms Server service license.
      Well, we need to convert PDF to PDF / A, we are trying to use the Assembler service.
      In the documentation "in Acrobat 9 and PDF/A-1 LiveCycle ES" (http://www.adobe.com/content/dam/Adobe/en/devnet/livecycle/pdfs/readercomp_pdfa.pdf), page 2, "Available tools ", there is a table where it says:
      Source / Tool / ---- Function ----- Usage --- 1a -1b
      LC ES / Assembler / conversion / automated / no / yes
      LC ES / Assembler / validated -/ automated / no / yes
      From this we can deduce that using the Assembler service can convert and validate PDF/A-1b.
      However, the tests we have made ??in this regard, by IVS utility not seem to work, and server-side errors are generated.
      We are trying to validate (using the Assembler service) a very simple PDF, which also meets PDF/A-1b know that, which we found through:
      DDX: [<DDX xmlns="http://ns.adobe.com/DDX/1.0/">
      <DocumentInformation result="info" source="doc1" />
      </DDX>]
      Response: [<?xml version="1.0" encoding="UTF-8"?>
      <DocInfo xmlns="http://ns.adobe.com/DDX/DocInfo/1.0/">
        <Title/>
        <Author>Javier Padrn Mrida</Author>
        <CreatedDate>2012-01-23T15:05:31Z</CreatedDate>
        <ModifiedDate>2012-01-23T15:06:21Z</ModifiedDate>
        <Creator>Acrobat PDFMaker 8.1 para Word</Creator>
        <Producer>Acrobat Distiller 8.1.0 (Windows)</Producer>
        <Version>1.4</Version>
        <NumPages>1</NumPages>
        <PDFAConformance isCompliant="notValidated" compliance="PDF/A-1b"/>
        <FormType>NotAForm</FormType>
        <PageSizes>
          <PageSize pages="1-1" width="595.22pt" height="842.0pt"/>
        </PageSizes>
        <PageRotations>
          <PageRotation pages="1-1" rotate90="0"/>
        </PageRotations>
        <PageLabels>
          <PageLabel pages="1-1" start="1" format="Decimal"/>
        </PageLabels>
      </DocInfo>]
      As expected PDFAConformance is PDF/A-1b ... But if we modify the DDX for detailed validation:
      <DocumentInformation result="info" source="doc1">
      <PDFAValidation
      ignoreUnusedResources="true"
      resultLevel="Detailed"/>
      </DocumentInformation>
      </DDX>]
      Response: [[object Object]
      null]
      We tested with different types of PDF and in any case the Assembler service seems to be able to process the labels "PDFAValidation" or "PDFAProfile", the server side we get:
      [com.adobe.livecycle.assembler.client.OperationException: ALC-ASM-S00-002: Failed to execute the DDX - error messages provided. Caused by: com.adobe.internal.ddxm.ValidationException: DDXM_S00003: The DDX did not pass validation against the specification. Check the job log for details.; nested exception is:
      at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder.java:222)
      faultDetail: com.adobe.internal.ddxm.ddx.DDX.logInvalidMessage DDXM_S23001: Element PDFAValidation is invalid since document conversion is not enabled.]
      So finally the question is: Is it possible to generate any type of PDF / A using only the Assembler service?
