4 Replies Latest reply on Sep 23, 2013 2:35 AM by vinothr82
    InDesign server CS 5.5 - app.scriptArgs.get doesn't work in jsx script or simpleclient problem
    hxkris-dev
      Hello
      I'm working with Adobe InDesing Server CS 5.5 and having problem that *.jsx script is not able to read input parameters passwd from sampleclient.exe or SOAP (same story in both cases)
      I run following command:
           sampleclient.exe -host localhost:8080 "c:\CreateJPEG.jsx" param1="1"
      also
           sampleclient.exe -host localhost:8080 "c:\CreateJPEG.jsx" param1=1
      and even
           sampleclient.exe -host localhost:8080 "c:\CreateJPEG.jsx" "param1=1"
      app.scriptArgs.get("param1") is always FALSE (see script body below).
      Please help, I couldn't find an answer anywhere. All documents stats that this should work in a way I described, but it doesn't. Script is performed but param1 is not set.
      Here is the script:
      #target  InDesignServer
      app.scriptPreferences.version = 7.0;
      main();
      function main()
        var eRet;
        if (app.scriptArgs.get("param1"))
          var sXMLFilePath = "C:\\CreateJPEG.xml";
          var eRet = app.createJpeg (sXMLFilePath);
