1. Re: "After effects has stopped working", but doesn't?
Mylenium Jan 24, 2012 9:34 AM (in response to Paul Lewis)Could simply be a performance issue where Windows is not properly receiving a "I'm still here" message from the main application window. If everything works, I wouldn't go crazy over it. This may fix itself magically one day when you install a new graphics driver or a Windows Update replaces a system library. Trying to get to the bottom of it now and installing random new drivers and componenhts when there is no dire need may only make things worse...
Mylenium
2. Re: "After effects has stopped working", but doesn't?
Dave LaRonde Jan 24, 2012 9:35 AM (in response to Paul Lewis)I won't tell you to stop using Dynamic Link, but if you're using Open GL acceleration in AE, I WILL tell you to stop using it.
3. Re: "After effects has stopped working", but doesn't?
Paul Lewis Jan 24, 2012 10:30 AM (in response to Paul Lewis)Mylenium: Thanks for the info, that could very well be what is happening. I didn't know if maybe this was a common issue with a common solution, and I've been just working through it and haven't had any issues.
Dave: Haha thanks, I already disabled Open GL that was my first idea, I had issues with that in the past.
Either way I will wait and see what happens, and if it stops I'll post back just incase someone has a similar issue and wants to know the final outcome. I've noticed a lot of people leave things open ended making it hard to figure out what happened in the end.
