3 Replies Latest reply on Jan 24, 2012 2:16 PM by richardh6
    [JS CS5] Get a reference to a block of text
    richardh6 Level 1
      There's one basic thing I've never been able to figure out. How do you get a reference to a specific block of text, with indexes that you specify?
      For instance, if the following text were the beginning of an InDesign story called "story"
      The black cat walks in the hall
      and if for some reason you wanted to get a reference to the text object that goes from story.characters[2] to right before story.characters[11] (whose contents would be "e black c", if I'm not mistaken), how would you do that?
      (Assume there is only one textStyleRange in this object).
        • 1. Re: [JS CS5] Get a reference to a block of text
          richardh6 Level 1
          In other words, something analagous to
          "The black cat walks in the hall".substring(2,11)
          but for Indesign text objects, instead of strings.
          I'm sure there's something really simple I'm just not thinking of.
          • 2. Re: [JS CS5] Get a reference to a block of text
            To grab a range of characters, use itemByRange on the story's Characters property:
            story = app.activeDocument.stories[0];
            range = story.characters.itemByRange(2,11);
            alert ("Story: "+story.contents+"\nRange: "+range.contents+"\nType: "+range.constructor.name+"\nLength: "+range.length);
            returns this:
            • 3. Re: [JS CS5] Get a reference to a block of text
              richardh6 Level 1
              Thank you Jongware, that's great!
              I didn't try that because I assumed that collections of characters wouldn't be counted as blocks of text for the purposes of things like searching, but I was wrong. I added this to your example:
              (Starting with story.contents == "The black cat walks down the hall.")
              var story = app.activeDocument.stories[0];
              var range = story.characters.itemByRange(2,11);
              app.findTextPreferences = NothingEnum.nothing;
              app.changeTextPreferences = NothingEnum.nothing;
              app.findTextPreferences.findWhat = "black";
              app.changeTextPreferences.changeTo = "white";
              range.changeText();
              and it totally worked. Turned into "The white cat walks down the hall."
