0 Replies Latest reply on Jan 24, 2012 2:35 PM by kkudiksx
    List's ItemRenderer - setStyle does not work
    kkudiksx Level 1
      I have a List which I can drag things into each "row".
      Each row is rendered using an itemRenderer which is an HBox wrapping a couple of Labels and a spacer inside.
      I am trying to change the style of each row when I am dragging over an item to each row using the dragEnter handler.
      I get the renderer and I try to set the following styles:
      renderer.setStyle('borderColor', 'red');
      renderer.setStyle('borderStyle', 'solid');
      renderer.setStyle('borderThickness', '3');
      renderer.setStyle('borderVisible', 'true');
      Even though the styles get set when I debug, the styles are not shown on the screen.
      Any ideas why?
      This used to work in Flex 3.2 but now that I upgraded to Flex 4.5 it does not work.
      The itemRenderer is as follows - UserTaskSummary.mxml
      <mx:HBox xmlns:mx="library://ns.adobe.com/flex/mx"
               xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark">
          <fx:Script>
              <![CDATA[
              import  com.company.UserInfo;
              [Bindable]
              public var currentUser:UserInfo;
          </fx:Script>
          <mx:Label id="nameLabel"
                    text="{data.userInfo.fullName}"
                    fontWeight="{(this.currentUser.id == this.data.userInfo.id) ? 'bold' : 'normal' }"/>
          <mx:Spacer width="100%"/>
          <mx:Canvas
                  cornerRadius="20"
                  borderStyle="solid"
                  borderThickness="0">
              <mx:Label id="statsLabel"
                        text="{data.statistics.openItems}"
                        fontWeight="{(data.statistics.openItems > 0) ? 'bold' : 'normal' }"
                        width="100%" textAlign="center"/>
          </mx:Canvas>
          <mx:Spacer width="1"/>
      </mx:HBox>
      Inside the mxml where the ItemUnderReportingList is displayed:
              public function getRendererFactory(currentUser:UserInfo):ClassFactory {
                  var factory:ClassFactory = new ClassFactory(UserTaskSummary);
                  factory.properties = {'currentUser': currentUser};
                  return factory;
          <wkflcontrols:ItemUnderReportingList id="userSelectorList"
                                               width="100%" height="100%"
                                               dataProvider="{pm.data.members}"
                                               creationComplete="pm.getQueueMembership()"
                                               change="pm.getQueueMembership(); pm.selectUser(event)"
                                               labelField="fullName"
                                               itemRenderer="{getRendererFactory(pm.data.me)}"
                                               dragEnter="pm.checkDragToUser(event)"
              private var highlightedStyle:Object =  { "borderStyle": 'solid', "borderColor": 'red', "borderThickness": '3' , "borderVisible": 'true'};
              public function checkDragToUser(event:DragEvent):void
                  var renderer:UserTaskSummary = ItemUnderReportingList(event.target).getItemRendererUnderCursor(event) as UserTaskSummary;
                  if (renderer && this.isAllowedToDragOnUser(renderer, event.dragSource.dataForFormat("items") as Array))
                      DragManager.acceptDragDrop(UIComponent(event.target));
                      this.highlightCurrentRenderer(renderer);
              private function highlightCurrentRenderer(renderer:UserTaskSummary):void
                  for (var style:String in this.highlightedStyle)
                      renderer.setStyle(style, this.highlightedStyle[style]);
                 --> declared in ItemUnderReportingList.as which extends List
              public function getItemRendererUnderCursor(event:MouseEvent):IListItemRenderer
                  var pt:Point = new Point(event.stageX, event.stageY);
                  pt = super.globalToLocal(pt);
                  var yy:Number = 0;
                  var n:int = super.listItems.length;
                  for (var i:int = 0; i < n; i++)
                      if (super.listItems[i].length)
                          if (pt.y < yy + super.rowInfo[i].height)
                              var m:int = super.listItems[i].length;
                              if (m == 1)
                                  return super.listItems[i][0];
                              var j:int = Math.floor(pt.x / super.columnWidth);
                              return super.listItems[i][j];
                      yy += super.rowInfo[i].height;
                  return null;
      I've tried to include all the relevant methods that are invoked in the process, hopefully someone can spot what's happening wrong and why the style is no longer set.
      I don't like the way the renderer is obtained either but the getItemRendererUnderCursor works and I've tested it thoroughly as I thought it was getting the wrong itemRenderer - but it's not!
