0 Replies Latest reply on Jan 24, 2012 3:45 PM by gtomps@lm
    Find unplaced text files and then place in document
    gtomps@lm
      I've used this script for some time, I'm pretty sure it originated out of these forums.  I'm hoping to modify it so that when the list of non placed files appears rather than revealing the file in the finder, to have it load into the indesign curser to be placed in the active document.
      set myUnplacedFiles to {}
      set myChosenFiles to false
      tell application "Finder"
                set myFolder to (choose folder)
                set myFinderFilenames to name of document files of myFolder
      end tell
      tell application "Adobe InDesign CS5.5"
        activate
                tell active document
                          set myID_LinksNames to name of links
                          repeat with i in myFinderFilenames
                                    set myTest to «class ktxt» of ((i as string) as record)
                                    if i is not in myID_LinksNames then
                                              set end of myUnplacedFiles to i
                                    end if
                          end repeat
                          if myUnplacedFiles is not {} then
                                    set myChosenFiles to choose from list myUnplacedFiles with prompt "These files are not placed. Select one and click OK to display it in the Finder or Cancel to continue working in InDesign."
                          else
                                    display dialog "All files of this folder seems to have been placed" buttons {"OK"} default button "OK"
                          end if
                end tell
      end tell
      if myChosenFiles is not false then
        activate
                          reveal file ((myFolder as string) & (item 1 of myChosenFiles as string))
                end tell
      end if
