osIntegration.mount() failed error
Rich Schafer Jan 24, 2012 4:41 PMI'm receiving an "osIntegration.mount() failed" error (see below) when trying to connect using my custom handler in Drive. This error only happens on the Mac. Connection to the same CMS through Windows 7 works perfectly. The error seems to be related to the URL entered in Drive. For example, if I enter
icms://mobiledemo.flatironssolutions.com:8443/icmsserver/repo
I get the error. However, if I enter
icms://mobiledemo:8443/icmsserver/repo
it works. So at first, it appears to be related to entering a fully qualified host name. However, I have also see it fail on a different host without a fully qualified name (e.g, icms://mtcdmtl601:8080/icmsserver/gpp_dev_repo01). It is consistent in that if a URL works, it will always work; if it fails, it will always fail.
Here's the error from the log file:
2012/01/24 14:43:22,392 [ConnectionHandler-Adobe Drive-20671] INFO GetServerInfoHandler - -->In()
2012/01/24 14:43:22,392 [ConnectionHandler-Adobe Drive-20671] INFO GetServerInfoHandler - -->Out()
2012/01/24 14:43:22,520 [ConnectionHandler-Adobe Drive-20671] INFO ConnectHandler - -->In()
2012/01/24 14:43:22,641 [ConnectionHandler-Adobe Drive-20671] INFO ConnectHandler - -->Out()
2012/01/24 14:43:22,641 [ConnectionHandler-Adobe Drive-20671] WARN DataManager - No IEventService for server ( | icms://mtcdmtl601:8080/icmsserver/gpp_dev_repo01 | icms://mtcdmtl601:8080/icmsserver/gpp_dev_repo01 | enableOfflineEditing: false | isOfflineEditing: false)
2012/01/24 14:43:22,642 [ConnectionHandler-Adobe Drive-20671] INFO GetAssetsHandler - -->In()
2012/01/24 14:43:22,642 [ConnectionHandler-Adobe Drive-20671] INFO GetAssetsHandler - -->Out()
2012/01/24 14:43:22,649 [ConnectionHandler-Adobe Drive-20671] INFO GetVolumeIconsHandler - -->In()
2012/01/24 14:43:22,650 [ConnectionHandler-Adobe Drive-20671] INFO GetVolumeIconsHandler - -->Out()
2012/01/24 14:43:22,819 [ConnectionHandler-Adobe Drive-20671] ERROR MountService - osIntegration.mount() failed
com.adobe.drive.data.model.DriveException: the server with uuid icms://mtcdmtl601:8080/icmsserver/gpp_dev_repo01 could not be mounted
at com.adobe.drive.internal.biz.filesystem.mount.OperatingSystemIntegrationMac.mount(Operati ngSystemIntegrationMac.java:95)
at com.adobe.drive.internal.biz.filesystem.mount.MountService.internalMount(MountService.jav a:144)
at com.adobe.drive.internal.biz.filesystem.mount.MountService.mount(MountService.java:102)
at com.adobe.drive.ui.ncomm.handler.MountServerHandler.mountServer(MountServerHandler.java:2 74)
at com.adobe.drive.ui.ncomm.handler.AddServerHandler.handle(AddServerHandler.java:136)
at com.adobe.csi.internal.ncomm.InvokeHandler.handle(InvokeHandler.java:88)
at com.adobe.csi.internal.ncomm.NCommDelegate.execute(NCommDelegate.java:107)
at com.adobe.versioncue.internal.nativecomm.host.Host.execute(Host.java:200)
at com.adobe.versioncue.internal.nativecomm.host.ConnectionHandler.handleRequest(ConnectionH andler.java:162)
at com.adobe.versioncue.internal.nativecomm.host.ConnectionHandler.run(ConnectionHandler.jav a:81)
at java.lang.Thread.run(Thread.java:655)
2012/01/24 14:43:22,824 [ConnectionHandler-Adobe Drive-20671] INFO DataManager - java.lang.NullPointerException
Any help would be greatly appreciated.
