1 Reply Latest reply on Jan 27, 2012 4:47 AM by vav_djjd
    SLIDER-FADER HELP!!!
    Aledragon
      Can anyone help me?
      I need to create a multimedia app that allow user to see different tipe of illumination on an artwork.
      I mean: I don't know how to create slider/fader that allow user to reveal one image with wipe or from 0 to 100% opacity control.
      See the example down here.
      Thanks a lot if someone can help me!!!
        • 1. Re: SLIDER-FADER HELP!!!
          vav_djjd
          Hi Alessandro,
          hope, this is what you're looking for:
          property pNum -- sprite number of slider
          property pSliderBase -- the number of sprite on which the slider is moved
          property pLocA, pLocB -- left corner and right corner of sprite on which the slider is moved
          property pImgMem_1, pImgMem_2 -- the two images, which should be shown on the canvas; they have to be of the same dimensions!
          property pStartAt -- where the slider should be placed on start (in %)
          property pCanvasSprt  -- the canvas sprite on which the two images are shown
          property pX, pY  -- the left & upper corner in the canvas image, on which the two images are aligned (to be centered on the canvas)
          on beginSprite me
            pNum = me.spritenum
            pLocA = sprite(pSliderBase).rect[1] + sprite(pNum).member.rect[3]/2.0
            pLocB = sprite(pSliderBase).rect[3] - sprite(pNum).member.rect[3]/2.0
            pX = integer(sprite(pCanvasSprt).member.rect[3]/2.0 - member(pImgMem_1).rect[3]/2.0)
            pY = integer(sprite(pCanvasSprt).member.rect[4]/2.0 - member(pImgMem_1).rect[4]/2.0)
            sliderLocH = pLocA + ((pLocB-pLocA)/100.0)* pStartAt
            sprite(pNum).loc = point(sliderLocH, sprite(pSliderBase).locV)
            me.setImgsRect(sliderLocH)
          end
          on mouseDown me
            repeat while _mouse.stillDown
              _player.cursor(290)
              sliderLocH = max(pLocA, min(pLocB, _mouse.mouseH))
              sprite(pNum).locH = me.setImgsRect(sliderLocH)
              _movie.updateStage()
            end repeat
          end
          on setImgsRect me, currentLoc
            visible_1 = integer( (currentLoc-pLocA) * (member(pImgMem_1).rect[3]/(pLocB-pLocA)) )
            visible_2 = member(pImgMem_1).rect[3] - visible_1
            sprite(pCanvasSprt).member.image.copypixels(member(pImgMem_1).image, rect(pX, pY, pX+visible_1, pY+member(pImgMem_1).rect[3]), rect(0, 0, visible_1, member(pImgMem_1).rect[4]))
            sprite(pCanvasSprt).member.image.copypixels(member(pImgMem_2).image, rect(pX+visible_1, pY, pX+member(pImgMem_2).rect[3], pY+member(pImgMem_2).rect[3]), rect(visible_1, 0, member(pImgMem_2).rect[3], member(pImgMem_2).rect[4]))
            return currentLoc
          end
          on exitFrame me
            _movie.go(_movie.frame)
          end
          on getPropertyDescriptionList me
            description = [:]
          description.addProp(#pSliderBase, \
              [#format: #integer, \
               #default: 0, \
               #comment: "1. SpriteNum of slider base:  "])
          description.addProp(#pCanvasSprt, \
               #default: 0, \
               #comment: "2. canvas: spriteNum of canvas:  "])
            description.addProp(#pImgMem_1, \
              [#format: #string, \
               #default: "", \
               #comment: "3. image: member name:  "])
              description.addProp(#pStartAt, \
               #default: 50, \
               #range: [#min: 0, #max: 100], \
            #comment: "3b. image: visible area on start (%):  "])
             description.addProp(#pImgMem_2, \
               #default: "", \
               #comment: "4. image: member name:  "])
            return description
          end
          make new behavior out of this and put it on your slider sprite. Be aware that image_1 and image_2 must have same dimensions. The canvas can be any kind of #bitmap but must be of greater size than image_1. Hope, this will help!
          Jürgen
