4 Replies Latest reply on Jan 25, 2012 5:53 AM by pamsharpe
    Edit an OS Commerce template in dreamweaver
    pamsharpe Level 1
      Hi
      I downloaded an os commerece template for my first e commerce store and everything is set up ok, just need to edit the whole template to my products and colours. I am trying to remove the stamp at the bottom that says designed by monstertemplate, with their website links at the bottom but not having any luck. I can see the the links code when I turn on the live code view in dreamweaver but cant see it when I go to codes to try and edit it. Maybe I am missing something and would appricate any help. This is the website:
      http://creativeinky.com/site/index.php - The links I want to remove are at the footer of the website. This has not been edited yet and the store is not functional.
      This is what I see in codes:( I have tried to remove oscommerce at the top but that does not help). Which code is for the stamp at the bottom links as I cannot see it in this code view where I can edit it. Please help.
      <?php
        $Id: index.php 1739 2007-12-20 00:52:16Z hpdl $
        osCommerce, Open Source E-Commerce Solutions
        http://www.oscommerce.com
        Copyright (c) 2003 osCommerce
        Released under the GNU General Public License
        require('includes/application_top.php');
      // the following cPath references come from application_top.php
        $category_depth = 'top';
        if (isset($cPath) && tep_not_null($cPath)) {
          $categories_products_query = tep_db_query("select count(*) as total from " . TABLE_PRODUCTS_TO_CATEGORIES . " where categories_id = '" . (int)$current_category_id . "'");
          $cateqories_products = tep_db_fetch_array($categories_products_query);
          if ($cateqories_products['total'] > 0) {
            $category_depth = 'products'; // display products
          } else {
            $category_parent_query = tep_db_query("select count(*) as total from " . TABLE_CATEGORIES . " where parent_id = '" . (int)$current_category_id . "'");
            $category_parent = tep_db_fetch_array($category_parent_query);
            if ($category_parent['total'] > 0) {
              $category_depth = 'nested'; // navigate through the categories
            } else {
              $category_depth = 'products'; // category has no products, but display the 'no products' message
        require(DIR_WS_LANGUAGES . $language . '/' . FILENAME_DEFAULT);
      <!doctype html public "-//W3C//DTD HTML 4.01 Transitional//EN">
      <html <?php echo HTML_PARAMS; ?>>
      <head>
      <?php require(DIR_WS_INCLUDES . 'header_includes.php'); ?>
      </head>
      <?php
        if ($category_depth == 'nested') {
          $category_query = tep_db_query("select cd.categories_name, c.categories_image from " . TABLE_CATEGORIES . " c, " . TABLE_CATEGORIES_DESCRIPTION . " cd where c.categories_id = '" . (int)$current_category_id . "' and cd.categories_id = '" . (int)$current_category_id . "' and cd.language_id = '" . (int)$languages_id . "'");
          $category = tep_db_fetch_array($category_query);
      <body>
      <!-- header //-->
      <?php $tab_sel = 2; ?>
      <?php require(DIR_WS_INCLUDES . 'header.php'); ?>
      <!-- header_eof //-->
      <!-- body //-->
      <table border="0" class="<?php echo MAIN_TABLE; ?>" cellspacing="0" cellpadding="0">
      <tr>
          <td class="<?php echo BOX_WIDTH_TD_LEFT; ?>"><table border="0" class="<?php echo BOX_WIDTH_LEFT; ?>" cellspacing="0" cellpadding="0">
      <!-- left_navigation //-->
      <?php require(DIR_WS_INCLUDES . 'column_left.php'); ?>
      <!-- left_navigation_eof //-->
          </table></td>
      <!-- body_text //-->
          <td class="<?php echo CONTENT_WIDTH_TD; ?>"><?php include(DIR_WS_BOXES . 'panel_top.php');?>
      <?php echo tep_draw_top();?>
                                              <?php new contentBoxHeading_ProdNew($info_box_contents);?>
      <?php echo tep_draw3_top();?>
                          <table border="0" width="100%" cellspacing="0" cellpadding="0" class="main sub_category">
                    <tr>
      <?php
          if (isset($cPath) && strpos('_', $cPath)) {
      // check to see if there are deeper categories within the current category
            $category_links = array_reverse($cPath_array);
            for($i=0, $n=sizeof($category_links); $i<$n; $i++) {
              $categories_query = tep_db_query("select count(*) as total from " . TABLE_CATEGORIES . " c, " . TABLE_CATEGORIES_DESCRIPTION . " cd where c.parent_id = '" . (int)$category_links[$i] . "' and c.categories_id = cd.categories_id and cd.language_id = '" . (int)$languages_id . "'");
              $categories = tep_db_fetch_array($categories_query);
              if ($categories['total'] < 1) {
                // do nothing, go through the loop
              } else {
                $categories_query = tep_db_query("select c.categories_id, cd.categories_name, c.categories_image, c.parent_id from " . TABLE_CATEGORIES . " c, " . TABLE_CATEGORIES_DESCRIPTION . " cd where c.parent_id = '" . (int)$category_links[$i] . "' and c.categories_id = cd.categories_id and cd.language_id = '" . (int)$languages_id . "' order by sort_order, cd.categories_name");
                break; // we've found the deepest category the customer is in
          } else {
            $categories_query = tep_db_query("select c.categories_id, cd.categories_name, c.categories_image, c.parent_id from " . TABLE_CATEGORIES . " c, " . TABLE_CATEGORIES_DESCRIPTION . " cd where c.parent_id = '" . (int)$current_category_id . "' and c.categories_id = cd.categories_id and cd.language_id = '" . (int)$languages_id . "' order by sort_order, cd.categories_name");
          $number_of_categories = tep_db_num_rows($categories_query);
          $rows = 0;
          while ($categories = tep_db_fetch_array($categories_query)) {
            $rows++;
            $cPath_new = tep_get_path($categories['categories_id']);
      $p_pic_sub = '<a href="' . tep_href_link(FILENAME_DEFAULT, $cPath_new) . '">' . tep_image(DIR_WS_IMAGES . $categories['categories_image'], $categories['categories_name'], SUBCATEGORY_IMAGE_WIDTH, SUBCATEGORY_IMAGE_HEIGHT) . '</a>';
      $p_name_sub = '<b><a href="' . tep_href_link(FILENAME_DEFAULT, $cPath_new) . '">' . $categories['categories_name'] . '</a></b>';
                  $width = (int)(100 / (MAX_DISPLAY_CATEGORIES_PER_ROW-0)) . '%';
                  echo '<td align="center" width="' . $width . '">'.tep_draw_prod2_top().'
                                              <table cellpadding="0" cellspacing="0" border="0" class="wrapper_box">
                                                        <tr><td class="pic4_padd">'.tep_draw_prod_pic_top().''.$p_pic_sub.''.tep_draw_prod_pic_bottom().' </td></tr>
                                                        <tr><td class="name name4_padd">'.$p_name_sub.'</td></tr>
                                              </table>'.tep_draw_prod2_bottom().'
                                    </td>'."\n";
                            if ($col!=(MAX_DISPLAY_CATEGORIES_PER_ROW-1)){
                            echo '
                                              <td>'.tep_draw_separator('spacer.gif', '1', '1').'</td>
                            }else{
                            if ((($rows / MAX_DISPLAY_CATEGORIES_PER_ROW) == floor($rows / MAX_DISPLAY_CATEGORIES_PER_ROW)) && ($rows != $number_of_categories)) {
                                    echo '
                          </tr><tr><td class="prod_line_x" colspan="'.(MAX_DISPLAY_CATEGORIES_PER_ROW + MAX_DISPLAY_CATEGORIES_PER_ROW -1).'">'.tep_draw_separator('spacer.gif', '1', '18').'</td></tr>' . "\n";
                                    echo '<tr>' . "\n";
                if ($col==MAX_DISPLAY_CATEGORIES_PER_ROW-1){
                $col=0;
                }else{
                $col++;
      // needed for the new products module shown below
          $new_products_category_id = $current_category_id;
                    </tr>
                  </table>
      <?php echo tep_draw3_bottom();?>
      <?php echo tep_draw_bottom();?>
                                              <?php new contentBoxHeading_WHATS_NEW($info_box_contents, true, false);?>
                                              <?php include(DIR_WS_MODULES . FILENAME_NEW_PRODUCTS); ?>
                </td>
      <!-- body_text_eof //-->
                <td class="<?php echo BOX_WIDTH_TD_RIGHT; ?>"><table border="0" class="<?php echo BOX_WIDTH_RIGHT; ?>" cellspacing="0" cellpadding="0">
      <!-- right_navigation //-->
      <?php require(DIR_WS_INCLUDES . 'column_right.php'); ?>
      <!-- right_navigation_eof //-->
          </table></td>
        </tr>
      </table>
      <!-- body_eof //-->
      <!-- footer //-->
      <?php require(DIR_WS_INCLUDES . 'footer.php'); ?>
      <!-- footer_eof //-->
      </body>
      <?php
        } elseif ($category_depth == 'products' || isset($HTTP_GET_VARS['manufacturers_id'])) {
      // create column list
          $define_list = array('PRODUCT_LIST_MODEL' => PRODUCT_LIST_MODEL,
                               'PRODUCT_LIST_NAME' => PRODUCT_LIST_NAME,
                               'PRODUCT_LIST_MANUFACTURER' => PRODUCT_LIST_MANUFACTURER,
                               'PRODUCT_LIST_PRICE' => PRODUCT_LIST_PRICE,
                               'PRODUCT_LIST_QUANTITY' => PRODUCT_LIST_QUANTITY,
                               'PRODUCT_LIST_WEIGHT' => PRODUCT_LIST_WEIGHT,
                               'PRODUCT_LIST_IMAGE' => PRODUCT_LIST_IMAGE,
                               'PRODUCT_LIST_BUY_NOW' => PRODUCT_LIST_BUY_NOW);
          asort($define_list);
          $column_list = array();
          reset($define_list);
          while (list($key, $value) = each($define_list)) {
            if ($value > 0) $column_list[] = $key;
          $select_column_list = '';
          for ($i=0, $n=sizeof($column_list); $i<$n; $i++) {
            switch ($column_list[$i]) {
              case 'PRODUCT_LIST_MODEL':
                $select_column_list .= 'p.products_model, ';
                break;
              case 'PRODUCT_LIST_NAME':
                $select_column_list .= 'pd.products_name, ';
                break;
              case 'PRODUCT_LIST_MANUFACTURER':
                $select_column_list .= 'm.manufacturers_name, ';
                break;
              case 'PRODUCT_LIST_QUANTITY':
                $select_column_list .= 'p.products_quantity, ';
                break;
              case 'PRODUCT_LIST_IMAGE':
                $select_column_list .= 'p.products_image, ';
                break;
              case 'PRODUCT_LIST_WEIGHT':
                $select_column_list .= 'p.products_weight, ';
                break;
      // show the products of a specified manufacturer
          if (isset($HTTP_GET_VARS['manufacturers_id'])) {
            if (isset($HTTP_GET_VARS['filter_id']) && tep_not_null($HTTP_GET_VARS['filter_id'])) {
      // We are asked to show only a specific category
              $listing_sql = "select " . $select_column_list . " p.products_id, p.manufacturers_id, p.products_price, p.products_tax_class_id, IF(s.status, s.specials_new_products_price, NULL) as specials_new_products_price, IF(s.status, s.specials_new_products_price, p.products_price) as final_price from " . TABLE_PRODUCTS . " p left join " . TABLE_SPECIALS . " s on p.products_id = s.products_id, " . TABLE_PRODUCTS_DESCRIPTION . " pd, " . TABLE_MANUFACTURERS . " m, " . TABLE_PRODUCTS_TO_CATEGORIES . " p2c where p.products_status = '1' and p.manufacturers_id = m.manufacturers_id and m.manufacturers_id = '" . (int)$HTTP_GET_VARS['manufacturers_id'] . "' and p.products_id = p2c.products_id and pd.products_id = p2c.products_id and pd.language_id = '" . (int)$languages_id . "' and p2c.categories_id = '" . (int)$HTTP_GET_VARS['filter_id'] . "'";
            } else {
      // We show them all
              $listing_sql = "select " . $select_column_list . " p.products_id, p.manufacturers_id, p.products_price, p.products_tax_class_id, IF(s.status, s.specials_new_products_price, NULL) as specials_new_products_price, IF(s.status, s.specials_new_products_price, p.products_price) as final_price from " . TABLE_PRODUCTS . " p left join " . TABLE_SPECIALS . " s on p.products_id = s.products_id, " . TABLE_PRODUCTS_DESCRIPTION . " pd, " . TABLE_MANUFACTURERS . " m where p.products_status = '1' and pd.products_id = p.products_id and pd.language_id = '" . (int)$languages_id . "' and p.manufacturers_id = m.manufacturers_id and m.manufacturers_id = '" . (int)$HTTP_GET_VARS['manufacturers_id'] . "'";
          } else {
      // show the products in a given categorie
      // We are asked to show only specific catgeory
              $listing_sql = "select " . $select_column_list . " p.products_id, p.manufacturers_id, p.products_price, p.products_tax_class_id, IF(s.status, s.specials_new_products_price, NULL) as specials_new_products_price, IF(s.status, s.specials_new_products_price, p.products_price) as final_price from " . TABLE_PRODUCTS . " p left join " . TABLE_SPECIALS . " s on p.products_id = s.products_id, " . TABLE_PRODUCTS_DESCRIPTION . " pd, " . TABLE_MANUFACTURERS . " m, " . TABLE_PRODUCTS_TO_CATEGORIES . " p2c where p.products_status = '1' and p.manufacturers_id = m.manufacturers_id and m.manufacturers_id = '" . (int)$HTTP_GET_VARS['filter_id'] . "' and p.products_id = p2c.products_id and pd.products_id = p2c.products_id and pd.language_id = '" . (int)$languages_id . "' and p2c.categories_id = '" . (int)$current_category_id . "'";
            } else {
      // We show them all
              $listing_sql = "select " . $select_column_list . " p.products_id, p.manufacturers_id, p.products_price, p.products_tax_class_id, IF(s.status, s.specials_new_products_price, NULL) as specials_new_products_price, IF(s.status, s.specials_new_products_price, p.products_price) as final_price from " . TABLE_PRODUCTS_DESCRIPTION . " pd, " . TABLE_PRODUCTS . " p left join " . TABLE_MANUFACTURERS . " m on p.manufacturers_id = m.manufacturers_id left join " . TABLE_SPECIALS . " s on p.products_id = s.products_id, " . TABLE_PRODUCTS_TO_CATEGORIES . " p2c where p.products_status = '1' and p.products_id = p2c.products_id and pd.products_id = p2c.products_id and pd.language_id = '" . (int)$languages_id . "' and p2c.categories_id = '" . (int)$current_category_id . "'";
          if ( (!isset($HTTP_GET_VARS['sort'])) || (!ereg('^[1-8][ad]$', $HTTP_GET_VARS['sort'])) || (substr($HTTP_GET_VARS['sort'], 0, 1) > sizeof($column_list)) ) {
              if ($column_list[$i] == 'PRODUCT_LIST_NAME') {
                $HTTP_GET_VARS['sort'] = $i+1 . 'a';
                $listing_sql .= " order by pd.products_name";
                break;
          } else {
            $sort_col = substr($HTTP_GET_VARS['sort'], 0 , 1);
            $sort_order = substr($HTTP_GET_VARS['sort'], 1);
            switch ($column_list[$sort_col-1]) {
                $listing_sql .= " order by p.products_model " . ($sort_order == 'd' ? 'desc' : '') . ", pd.products_name";
                break;
                $listing_sql .= " order by pd.products_name " . ($sort_order == 'd' ? 'desc' : '');
                break;
                $listing_sql .= " order by m.manufacturers_name " . ($sort_order == 'd' ? 'desc' : '') . ", pd.products_name";
                break;
                $listing_sql .= " order by p.products_quantity " . ($sort_order == 'd' ? 'desc' : '') . ", pd.products_name";
                break;
                break;
                $listing_sql .= " order by p.products_weight " . ($sort_order == 'd' ? 'desc' : '') . ", pd.products_name";
                break;
              case 'PRODUCT_LIST_PRICE':
                $listing_sql .= " order by final_price " . ($sort_order == 'd' ? 'desc' : '') . ", pd.products_name";
                break;
      <body>
      <!-- header //-->
      <!-- body //-->
      <tr>
          </table></td>
      <?php
      // optional Product List Filter
                if (PRODUCT_LIST_FILTER > 0) {
              $filterlist_sql = "select distinct c.categories_id as id, cd.categories_name as name from " . TABLE_PRODUCTS . " p, " . TABLE_PRODUCTS_TO_CATEGORIES . " p2c, " . TABLE_CATEGORIES . " c, " . TABLE_CATEGORIES_DESCRIPTION . " cd where p.products_status = '1' and p.products_id = p2c.products_id and p2c.categories_id = c.categories_id and p2c.categories_id = cd.categories_id and cd.language_id = '" . (int)$languages_id . "' and p.manufacturers_id = '" . (int)$HTTP_GET_VARS['manufacturers_id'] . "' order by cd.categories_name";
            } else {
              $filterlist_sql= "select distinct m.manufacturers_id as id, m.manufacturers_name as name from " . TABLE_PRODUCTS . " p, " . TABLE_PRODUCTS_TO_CATEGORIES . " p2c, " . TABLE_MANUFACTURERS . " m where p.products_status = '1' and p.manufacturers_id = m.manufacturers_id and p.products_id = p2c.products_id and p2c.categories_id = '" . (int)$current_category_id . "' order by m.manufacturers_name";
            $filterlist_query = tep_db_query($filterlist_sql);
            if (tep_db_num_rows($filterlist_query) > 1) {
                            echo tep_draw_side_top();
              echo '
                          <table cellpadding="0" cellspacing="0" border="0" class="select2">
                                    <tr><td align="right" class="main">' . tep_draw_form('filter', FILENAME_DEFAULT, 'get') . '<b>'.TEXT_SHOW . '</b>  ';
                echo tep_draw_hidden_field('manufacturers_id', $HTTP_GET_VARS['manufacturers_id']);
                $options = array(array('id' => '', 'text' => TEXT_ALL_CATEGORIES));
              } else {
                echo tep_draw_hidden_field('cPath', $cPath);
                $options = array(array('id' => '', 'text' => TEXT_ALL_MANUFACTURERS));
              echo tep_draw_hidden_field('sort', $HTTP_GET_VARS['sort']);
              while ($filterlist = tep_db_fetch_array($filterlist_query)) {
                $options[] = array('id' => $filterlist['id'], 'text' => $filterlist['name']);
              echo tep_draw_pull_down_menu('filter_id', $options, (isset($HTTP_GET_VARS['filter_id']) ? $HTTP_GET_VARS['filter_id'] : ''), 'onchange="this.form.submit()"');
              echo tep_hide_session_id() . '</form></td></tr>
                          </table>' . "\n";
                          echo tep_draw_side_bottom();
      // Get the right image for the top-right
          $image = DIR_WS_IMAGES . 'table_background_list.gif';
            $image = tep_db_query("select manufacturers_image from " . TABLE_MANUFACTURERS . " where manufacturers_id = '" . (int)$HTTP_GET_VARS['manufacturers_id'] . "'");
            $image = tep_db_fetch_array($image);
            $image = $image['manufacturers_image'];
          } elseif ($current_category_id) {
            $image = tep_db_query("select categories_image from " . TABLE_CATEGORIES . " where categories_id = '" . (int)$current_category_id . "'");
            $image = $image['categories_image'];
                                              <?php include(DIR_WS_MODULES . FILENAME_PRODUCT_LISTING); ?>
                </td>
          </table></td>
        </tr>
      </table>
      <!-- body_eof //-->
      <!-- footer //-->
      </body>
      <?php
        } else { // default page
      <body>
      <!-- header //-->
      <?php $tab_sel = 222; ?>
      <!-- body //-->
      <tr>
      <?php
                if           ($tab_sel == 222)          {
                                              <tr><td><?php require(DIR_WS_INCLUDES . 'column_left.php'); ?></td></tr>
                              </table></td>
      <?php
      <!-- Welcome_box_start -->
      <?php /*  tep_draw_heading_top();  */?>
      <?php /*  tep_draw_heading_top_3();  */?>
      <?php   /*  echo tep_draw_prod_top();  */  ?>
           <!--   <table border="0" width="100%" cellspacing="0" cellpadding="0">
                <tr><td class="main"><?php /*  echo tep_customer_greeting();  */    ?></td></tr>
                <tr><td><?php    /*  echo tep_draw_separator('pixel_trans.gif', '100%', '10');  */   ?></td></tr>
                <tr><td class="main"><?php    /*   echo TEXT_MAIN;  */    ?></td></tr>
              </table>  -->
      <?php   /*  echo tep_draw_prod_bottom();  */   ?>
      <?php /*  tep_draw_heading_bottom_3();  */?>
      <?php  /*   echo tep_draw_separate();    */   ?>
      <!-- Welcome_box_end -->
                $sum2 = 4;
                                              <?php include(DIR_WS_MODULES . FILENAME_NEW_PRODUCTS);?>
                                              <?php include(DIR_WS_MODULES . FILENAME_UPCOMING_PRODUCTS); ?>
                </td>
          </table></td>
        </tr>
      </table>
      <!-- body_eof //-->
      <!-- footer //-->
      <?php
      </body>
      <?php require(DIR_WS_INCLUDES . 'footer_includes.php'); ?>
      </html>
      <?php require(DIR_WS_INCLUDES . 'application_bottom.php'); ?>
