• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
possiblilities for null= in <cfqueryparam
Enthusiast ,
Jan 25, 2012 Jan 25, 2012
why can't I do this:
<cfqueryparam value="#structFromParsedXML.ClientID#" cfsqltype="cf_sql_varchar" null="not structKeyExists(structFromParsedXML, 'ClientID')"
whats the best workaround for this?
TOPICS
Advanced techniques
Views
1.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 26, 2012 Jan 26, 2012
Actually, the logic you wish to apply is a bit subtle. If the key ClientID does not exist in the struct, then you want the value to be NULL. ColdFusion would then ignore the value attribute, whatever it is.
However, I do believe you could improve the code logic by doing something like
Outsid
Votes
Translate
Translate
Guide ,
You can do that. What's the problem?
Votes
Translate
Translate
Report
Report
LEGEND ,
Two reasons:
1) the expression you have in your NULL attribute is a string.  It needs to be boolean.
2) all the attribute values for a tag need to be defined.  So if your null condition was true, your VALUE value would be invalid.
You need to wrap your <cfqueryparam> tag in an if/else block which checks the key exists, and either use it or send just a null.
Adam
Votes
Translate
Translate
Report
Report
Advocate ,
While the parameter must exists, you can do logic like this (I use it all the time):
<cfparam name="structFromParsedXML.ClientID" default="" />
<cfquery...>
  clientID = <cfqueryparam value="#structFromParsedXML.ClientID#" cfsqltype="cf_sql_varchar" null="#evaluate('NOT len(structFromParsedXML.ClientID)')#" />
</cfquery>
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Just a quick point that you should not need to use the evalute function in this case.
<cfqueryparam value="#structFromParsedXML.ClientID#" cfsqltype="cf_sql_varchar" null="#NOT len(structFromParsedXML.ClientID)#" />
Should work just fine.
Votes
Translate
Translate
Report
Report
Community Expert ,
Outside cfquery tag:
<cfset isNullValue = true>
<cfset id          = "">
<cfif structKeyExists(structFromParsedXML, 'ClientID')>
    <cfset isNullValue = false>
    <cfset id     = structFromParsedXML.ClientID>
</cfif>
Within cfquery tag:
<cfqueryparam value="#id#" cfsqltype="cf_sql_varchar" null="#isNullValue#">
Votes
Translate
Translate
Report
Report
Enthusiast ,
Jan 27, 2012 Jan 27, 2012
LATEST
thanks guys, love the answers, I'll implement bkbk's
Votes
Translate
Translate
Report
Report
Resources
Documentation
