13 Replies Latest reply on Jan 30, 2012 8:23 AM by jetrased
    Modal Focus Question
    jetrased Level 1
      Hi
      IU am using popupManager to display a login form for an application. I was having issues getting the popup to become the active focus (I was not able to tab to the textInput fields, the parent application was getting the focus).
      I implemented mx.core.IFlexDisplayObject in my Login component that I was loading and the textFields became able to be tabbed. However I noticed something else. They became tabbable when I had set the modal value to false. The drawback is that the application in the background does not get disabled awaiting the login details.
      The problem i am having is: I want the modal set to true while also enabling the tabbing. I am wondering what the best way to achieve this is?
      Should I set it to false and disabel the background? (if so -how) Or is there something I am missing?
      The PopUp gets called on creation complete. I am wondering alos is it a timing thing, of the popup getting created at the same time as the application and hence not getting the focus?
      Creating the PopUp form the main application.
      stwLogOn = StwLogOn(PopUpManager.createPopUp(this, StwLogOn, true));
      stwLogOn.addEventListener("clickOK", handleCloseLogOnDlg);
      Any suggestions woudl be great.
        • 1. Re: Modal Focus Question
          Flex harUI Adobe Employee
          Does the popup implement IFocusManagerContainer?
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.<http://www.adobe.com/>
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: Modal Focus Question
            jetrased Level 1
            Hi
            Ah no id does not, I used the BorderContainer component instead as I believe that inherits the IFocusManagerContainer and the problem is gone. Thanks for that
            • 3. Re: Modal Focus Question
              jetrased Level 1
              Hi
              Random bug I noticed, I am using a setINterval method to delay the calling of my Modal window popup. This along with the IFocusManagerContainer seemed to have eliminated my problem. However I checked running it in chrome and the problem is back, works fine in IE and Firefox, any thoughts on what might be causing this?
              The setinterval has a 2second delay to allow the application to loading befor epoppint up the login form
              • 4. Re: Modal Focus Question
                saisri2k2 Level 4
                Yes, I agree with jetrased, use Timer or setInterval to delay setting the focus, even I use 2 sec
                • 5. Re: Modal Focus Question
                  jetrased Level 1
                  Any ideas on why the delay needs to be longer for chrome? Tried googling but is there a way to set different intervals / timers depending on the browser?
                  • 6. Re: Modal Focus Question
                    Relying on timers is a bad practice.  It is effectively trying to fix an intermittent problem with an intermittent event.  There is a certain amount of probability involved.
                    It is better to understand the sequence of events and use events to trigger the focus code.  Usually, waiting for applicationComplete is a good time to put up a popup, and the popup should wait for creationComplete before setting focus.  If that doesn’t work, I would delay via callLater from the creationComplete event, not a timer.
                    Alex Harui
                    Flex SDK Developer
                    • 7. Re: Modal Focus Question
                      jetrased Level 1
                      • I tried to use the applicationComplete but it doesn't seem to wrok. I am wondering about your setting focus, I am currently not setting any focus, wondering if that is my problem.
                      here is the code example
                      <ns:WorkspaceApplication xmlns:mx="http://www.adobe.com/2006/mxml"
        xmlns:ns="http://www.ns.com/flex/mxml" creationComplete="creationComplete()">
                      Then in that method I am calling
                      callLater(popupLogOnDlg);
                      And the Method then calling the popup
                      stwLogOn = new StwLogOn();
                                                    PopUpManager.centerPopUp(stwLogOn);
                      The component stwLogOn is built on BorderContainer
                      • 8. Re: Modal Focus Question
                        Usually, a popup’s creationComplete handler calls setFocus() on something.
                        Alex Harui
                        Flex SDK Developer
                        • 9. Re: Modal Focus Question
                          jetrased Level 1
                          When I called set focus on one of the text input fields, the focus is put onto that field . However when I tab, it goes back to the application in the background.
                          I can't think why that is happening.
                          • 10. Re: Modal Focus Question
                            You sure your popup implements IFocusManagerContainer?
                            Alex Harui
                            Flex SDK Developer
                            • 11. Re: Modal Focus Question
                              jetrased Level 1
                              Yeah it should, I have attached code incase I am way off.
                              <s:BorderContainer            cornerRadius="10"  borderStyle="inset" borderWeight="6"           left="10" right="10" top="10" bottom="10"
        xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:sas="http://www.sas.com/flex/mxml"
        xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="200"
        implements="mx.managers.IFocusManagerContainer"
        defaultButton = "{okBtn}" creationComplete="doIt(event)">
                                        <fx:Script>
                                                  <![CDATA[
                                                            import com.sas.commons.controls.Alert;
                                                            import com.sas.commons.images.ImageLibrary;
                                                            import mx.events.CloseEvent;
                                                            import mx.events.FlexEvent;
                                                            import mx.managers.FocusManager;
                                                            import mx.managers.IFocusManagerContainer;
                                                            import mx.managers.PopUpManager;
                                                            public var focus:FocusManager
                                                            private function handleClickOK():void
        dispatchEvent(new Event("clickOK"))
                                                            private const BACKGROUND_COLOR:Object = "haloBlue";
                                                            private function formItem_focusIn(evt:FocusEvent):void {
        var item:FormItem = FormItem(evt.currentTarget.parent);
        item.setStyle("backgroundAlpha", 0.2);
        item.setStyle("backgroundColor", BACKGROUND_COLOR);
                                                            private function formItem_focusOut(evt:FocusEvent):void {
        item.setStyle("backgroundColor", null);
                                                            protected function doIt(event:FlexEvent):void
        // TODO Auto-generated method stub
        nameTextInput.setFocus();
                                        </fx:Script>
                                        <mx:Form width="100%"  paddingTop="50">
                                                  <mx:FormItem width="100%" fontThickness="620" fontSize="15"  label="User name:" horizontalAlign="center">
                                                            <mx:TextInput width="100%"
        focusIn="formItem_focusIn(event);"
        focusOut="formItem_focusOut(event);" restrict="A-Za-z0-9_." id="nameTextInput"/>
                                                  </mx:FormItem>
                                                  <mx:FormItem  width="100%" fontThickness="220" fontSize="15" label="Password:" horizontalAlign="left">
        focusOut="formItem_focusOut(event);" id="keywordTextInput" displayAsPassword="true"/>
                                                  </mx:FormItem>
                                        </mx:Form>
                                        <mx:HBox x="0" y="120" width="100%" horizontalAlign="right" >
                                                  <sas:Spacer height="10"/>
                                                   <sas:Button label="Log On" id="okBtn" click="handleClickOK()"/>
                                                  <sas:Spacer width="10"/>
                                        </mx:HBox>
                              </s:BorderContainer>
                              • 12. Re: Modal Focus Question
                                If you type a few chars before you tab, does it go in the TextInput?
                                Alex Harui
                                Flex SDK Developer
                                • 13. Re: Modal Focus Question
                                  jetrased Level 1
                                  No even if you type and then tab, you can see the backgroup shell being selected. So the focus moves off the popup.
