4 Replies Latest reply on Jan 26, 2012 2:59 PM by christrom
    Brush changes affect every brush
    christrom Level 1
      Hi everyone,
      I've noticed something in CS5 that I find a bit frustrating. In CS4 when you go to the brush panel you can alter scatter/shape dynamics/fade/dual brush etc and then when you click on another brush in the same panel it will switch these checkboxes on and off depending on which brush you select. Now in CS5 whenever you edit a brush it effectively applies these settings globally to every brush on the list and whatever checkboxes you've messed with applies to every brush in the list. The only way around it is to save each new brush and use the brush preset list to select them. It seems a bit strange? I suppose I can see the logic in it in some way, but is there any way of getting the brushes to behave like they did before?
      Chris
