7 Replies Latest reply on Jan 27, 2012 9:35 AM by andrepazleal
    Counter behavior
    andrepazleal Level 1
      Hello there, I´m doing an system simulation, it loads thru the XML the system image location, the clicks fields, type fields(i.e.: for data fields), etc...
      My problem I have a widget on the screen that count how many times the user clicks the screen, if the user clicks the right place go to next frame if dont, the counter add´s a value.
      In the image above I have two images, the top one is when the screen have it only one click field there´s no problem it will count the three time and do the action, but if if have like the above screen, three choices where he can click the numbers of try´s, when he click one time the spaces are full because it have three option off course, the counter will _xscale the movie clip right? How can I fix that, making one click at a time even with a lot of click fields...? Here´s my AS for that:
      //GETTING THE INTERVENTIONS
              for(i=0; i < intervencao_max; i++)
                  intervencao_node = new_tela_node.childNodes[6].childNodes[i];
                  intervencao_tipo = intervencao_node.childNodes[0].firstChild;
                  intervencao_salto= intervencao_node.childNodes[1].firstChild;
                  intervencao_x = intervencao_node.childNodes[5].childNodes[0].firstChild.nodeValue;
                  intervencao_y = intervencao_node.childNodes[5].childNodes[1].firstChild.nodeValue;
                  intervencao_width = intervencao_node.childNodes[6].childNodes[0].firstChild.nodeValue;
                  intervencao_height = intervencao_node.childNodes[6].childNodes[1].firstChild.nodeValue;
                  intervencao_image_node = new_tela_node.childNodes[6].childNodes[i].childNodes[7].firstChild.firstChild;
                  intervencao_image_x = intervencao_node.childNodes[7].childNodes[1].childNodes[0].firstChild;
                  intervencao_image_y = intervencao_node.childNodes[7].childNodes[1].childNodes[1].firstChild;
                  if(intervencao_tipo.toString() == "Clique")
                      this.createEmptyMovieClip("click_mc"+i, 100+i);
                      this["click_mc"+i].beginFill(0xCCFF00,50);
                      this["click_mc"+i].moveTo(0, 20);
                      this["click_mc"+i].lineTo(140, 20);
                      this["click_mc"+i].lineTo(140, 140);
                      this["click_mc"+i].lineTo(0, 140);
                      this["click_mc"+i]._x = intervencao_x;
                      this["click_mc"+i]._y = intervencao_y;
                      this["click_mc"+i]._width = intervencao_width;
                      this["click_mc"+i]._height = intervencao_height;
                      this["click_mc"+i].endFill();
                      this["click_mc"+i].useHandCursor=false;
                      if(intervencao_salto.toString() == 'true')
                          this["click_mc"+i].onMouseDown = function()
                              mouse_try++;//ADDING THE COUNTER HERE
                              trace(mouse_try)
                              if(this.hitTest(_root._xmouse, _root._ymouse))
                                  score+=divisao_score;
                                  mouse_try=0;
                                  disable();
                                  next_tela();
                              else
                                  try_mc.swapDepths(14);
                                  try_mc._visible=true;
                                  mouse_pointer.swapDepths(15);
                                  try_mc.progress_mc._xscale= try_mc.progress_mc._xscale+33
                                  if(mouse_try == 3 )
                                      disable();
                                      delete this.onMouseDown;
                                      mouse_pointer._visible=true;
                                      var tween:Tween = new Tween(mouse_pointer, "_alpha", Regular.easeIn, 0, 100, .5, true);
                                      var tween:Tween = new Tween(mouse_pointer, "_y", Regular.easeIn, _ymouse, this._y+this._height/2, 1.5, true);
                                      var tween:Tween = new Tween(mouse_pointer, "_x", Regular.easeIn, _xmouse, this._x+this._width/2, 1.5, true);
                                      tween.onMotionFinished = function()
                                          var tween:Tween = new Tween(mouse_pointer, "_alpha", Regular.easeIn, mouse_pointer._alpha, 0, .5, true);
                                              mouse_try=0;
                                              next_tela();
      Thank you
        • 1. Re: Counter behavior
          i'm not sure what you're asking.
          are you trying to count the number of times a user clicks your stage?
          is there some problem with your textfields?
          • 2. Re: Counter behavior
            Kglad, yes I´m trying to count the number of clicks my main problem is, inside the loop above I create an MC (this.createEmptyMovieClip("click_mc"+i, 100+i);) for each one of the locations, sometimes it have one more location to do the same action, like the image I upload the below image have the option to click the (x) the (OK) or the (Cancel), so I have 3 MC theres and the counter counts the three times when the user press just one time, how can I separate the counter for each one of the MC´s but still if the user presses the wrong location count´s for each one of them...
            Thank you...
            • 3. Re: Counter behavior
              you could use getTimer() to determine if the most recent click occured at about the same time as the previous click.
              • 4. Re: Counter behavior
                No, it wont work, the same problem...
                I´m trying to use a listener, it works, but I lost the mouse_mc _xmouse go to the right option when the user click the wrong choice, how can I fix that...? My previous code I was using on the same loop so it was easy, but now...!!
                                this["click_mc"+i].beginFill(0xCCFF00,0);
                                        trace(chance)
                                            chance=0;
                                            disable();
                                            var tween:Tween = new Tween(try_mc.progress_mc, "_xscale", Strong.easeIn, try_mc.progress_mc._xscale, 0, .2, true);
                                                next_screen();
                                        else
                                            Mouse.addListener(mouse_listener)
                var mouse_listener:Object = new Object();
                mouse_listener.onMouseDown = function():Void
                    chance++;
                    if(chance == 3)
                        Mouse.removeListener(mouse_listener);
                        Key.removeListener(key_listener)
                        this._visible=false;
                        var tween:Tween = new Tween(mouse_pointer, "_y", Regular.easeIn, _ymouse, this.click_mc._y+this.click_mc._height/2, 1.5, true);
                        var tween:Tween = new Tween(mouse_pointer, "_x", Regular.easeIn, _xmouse, this.click_mc._x+this.click_mc._width/2, 1.5, true);
                                next_screen();
                • 5. Re: Counter behavior
                  why do you say, it won't work?
                  • 6. Re: Counter behavior
                    Because if I use the listener I could use one listener for all the movieClips, I think that´s a far way better solution, just have to figure out how the mouse_mc will show the correct answer for the user...
                    • 7. Re: Counter behavior
                      Dont get me wrong your help is essential...!!!
