7 Replies Latest reply on Jan 30, 2012 5:06 AM by BKBK
    cfloop over dynamically generated check boxes and radio buttons
    pmlink360
      Hello, I have a page where a user can select a project, via a checkbox then select a radio buttion with the following options "Support, Oppose, Not Known". The form fields are dynamically generated, can be anywhere from 1 to many. here is a screenshot:
      A user has to at least select 1 but can select many. The checkbox names are dynamically generated and follow this naming convention:
      f_project_1
      f_project_2
      the radio buttons are named similar:
      f_support_1
      f_support_2
      So, on my submit page I need to loop through each of these and insert into my database. before I just had a select box with projects(no support, oppose stuff) and I used the following code and it worked great.
      <CFLOOP INDEX="projectlist" LIST="#Form.f_project#">
                <cfoutput>
                          <CFQUERY  datasource="#datasource#" name="insertproject">
                                    INSERT into contactrecord_project
                                    (contactrecord_project_id,
                                    contactrecord_project_nm,
                  project_support)
                                    Values ('#newid#','#projectlist#',)
                          </CFQUERY>
                </cfoutput>
      </CFLOOP>
      I'm just brain dead today, can someone please help me out with looping over the list and getting it inserted into my database
        • 1. Re: cfloop over dynamically generated check boxes and radio buttons
          BKBK Adobe Community Professional & MVP
          <cfdump var="#form#">
          <cfform>
          Proj 1: <cfinput name="f_project_1" type="checkbox">||
          Support 1: <cfinput name="f_support_1" type="radio" value="support11">|
          Support 1: <cfinput name="f_support_1" type="radio" value="support12">|
          Support 1: <cfinput name="f_support_1" type="radio" value="support13" checked="yes">|
          <br>
          Proj 2: <cfinput name="f_project_2" type="checkbox">||
          Support 2: <cfinput name="f_support_2" type="radio" value="support21">|
          Support 2: <cfinput name="f_support_2" type="radio" value="support22">|
          Support 2: <cfinput name="f_support_2" type="radio" value="support23" checked="yes">|
          <br>
          Proj 3: <cfinput name="f_project_3" type="checkbox">||
          Support 3: <cfinput name="f_support_3" type="radio" value="support31">|
          Support 3: <cfinput name="f_support_3" type="radio" value="support32">|
          Support 3: <cfinput name="f_support_3" type="radio" value="support33" checked="yes">|
          <br>
          <cfinput name="sbmt" type="submit" value="send">
          </cfform>
          <cfloop from="1" to="6" index="idx">
              <cfset projectName = "f_project_" & idx>
              <!--- Do something (for example, an insert) only if a project is selected on the form. Otherwise, do nothing. --->
              <!--- Note: Checked radio buttons return value, however checked checkboxes only return "ON" --->
              <cfif structKeyExists(form,"#projectName#")>
                  Your insert query goes here. The values to insert are: <br>
                  <cfoutput>Project name: #projectName#; Support: #form["f_support_" & idx]#</cfoutput><br>
              </cfif>
          </cfloop>
          • 2. Re: cfloop over dynamically generated check boxes and radio buttons
            pmlink360 Level 1
            Hey BKBK.....How can I get only the number into the projectname variable? Right now it is inserting "f_project_1" for example....I just want "1"
            Thanks.
            • 3. Re: cfloop over dynamically generated check boxes and radio buttons
              Dan Bracuk Level 5
              BKBK's answer gave you the value of the formfield.  If you run this code:
              <cfdump var = "#form.f_project_1#">
              what do you see?
              • 4. Re: cfloop over dynamically generated check boxes and radio buttons
                pmlink360 Level 1
                Hi Dan, Here is my code for  the dynamic creation of the checkboxes & radio buttons
                <cfloop query="getprojects">
                                           <tr>
                                     <td bgcolor="##CCCCCC"><input type="checkbox" name="f_project_#project_name_id#" value="#project_name_id#" id="f_project_#project_name_id#"  onClick="javascript:enableField_#project_name_id#()">#project_name#</td>
                                   <td bgcolor="##CCCCCC"><input name="f_support_#project_name_id#" type="radio" value="1" id="f_support_#project_name_id#" disabled></td>
                                   <td bgcolor="##CCCCCC"><input name="f_support_#project_name_id#" type="radio" value="0" id="f_support_#project_name_id#" disabled></td>
                                   <td bgcolor="##CCCCCC"><input name="f_support_#project_name_id#" type="radio" value="2" id="f_support_#project_name_id#" checked disabled></td>
                                  </tr>
                          </td></tr>
                          </cfloop>
                So If I dump the form variable f_project_1 it = 1
                BKBK's code does not appear to me to use the value created from the form(I did not provide that code when I first created this thread)....he sets it with   <cfset projectName = "f_project_" & idx>
                Thanks for any assitance you can provide.
                • 5. Re: cfloop over dynamically generated check boxes and radio buttons
                                             <tr>
                                       <td bgcolor="##CCCCCC"><input type="checkbox" name="f_project_#project_name_id#" value="#project_name_id#" id="f_project_#project_name_id#"  onClick="javascript:enableField_#project_name_id#()">#project_name#</ td>
                                    </tr>
                            </td></tr>
                            </cfloop>
                  I assumed the project names to be f_project_1, f_project_2, and so on. That is what your "naming convention" said.
                  In any case, your code appears to have done most of the work already. My suggestion should now read:
                          <cfoutput>
                            Project ID: #idx#;
                           </cfoutput><br>
                      </cfif>
                  </cfloop>
                  • 6. Re: cfloop over dynamically generated check boxes and radio buttons
                    pmlink360 Level 1
                    Thanks BKBK...that did it....I appreciate you getting back to me.
