7 Replies Latest reply on Jan 27, 2012 11:11 AM by the_wine_snob
    Need help reading the info from GSpot...
    davidbeisner2010 Level 3
      I've got an uncompressed .mov file that someone exported from FCP (not sure which version) for me to put a new music bed on and upload to our website. I attempted to import it PrPro, but it failed to import and gave me an unknown codec error. I opened the file in GSpot and got the below screenshot, which I don't really know how to read properly. I also tried repackaging the file using MPEG Streamclip, but got a file with audio and no video... Help?
        • 1. Re: Need help reading the info from GSpot...
          the_wine_snob Level 9
          David,
          You might get more useful info from MediaInfo, than G-Spot, with that/those file(s).
          I also find that the Properties utility in QT Pro (Ctrl+J), does better with MOV files.
          • 2. Re: Need help reading the info from GSpot...
            Thanks, Bill... here's the info from MediaInfo (I don't own QT Pro):
            General
            Complete name                    : F:\PCI\MLK\MLK Day 2012\Barber_MLKDay_sans_music.mov
            Format                           : MPEG-4
            Format profile                   : QuickTime
            Codec ID                         : qt
            File size                        : 3.31 GiB
            Duration                         : 4mn 32s
            Overall bit rate mode            : Variable
            Overall bit rate                 : 104 Mbps
            Encoded date                     : UTC 2012-01-20 00:24:50
            Tagged date                      : UTC 2012-01-27 16:13:10
            Writing library                  : Apple QuickTime
            ©TSC                             : 2997
            ©TSZ                             : 100
            Video
            Format                           : Intermediate Codec
            Codec ID                         : icod
            Codec ID/Hint                    : Apple
            Duration                         : 4mn 32s
            Bit rate mode                    : Variable
            Bit rate                         : 103 Mbps
            Width                            : 1 920 pixels
            Height                           : 1 080 pixels
            Display aspect ratio             : 16:9
            Frame rate mode                  : Constant
            Frame rate                       : 29.970 fps
            Scan type                        : Interlaced
            Scan order                       : Top Field First
            Bits/(Pixel*Frame)               : 1.655
            Stream size                      : 3.26 GiB (99%)
            Language                         : English
            Tagged date                      : UTC 2012-01-20 00:31:22
            Color primaries                  : BT.709-2, SMPTE 274M, SMPTE 296M
            Transfer characteristics         : BT.709-2, SMPTE 170M, SMPTE 274M, SMPTE 293M, SMPTE 296M
            Matrix coefficients              : BT.709-2, SMPTE 274M, SMPTE 296M
            Audio
            Format                           : PCM
            Format settings, Endianness      : Little
            Format settings, Sign            : Signed
            Codec ID                         : sowt
            Duration                         : 4mn 32s
            Bit rate mode                    : Constant
            Bit rate                         : 1 536 Kbps
            Channel(s)                       : 2 channels
            Sampling rate                    : 48.0 KHz
            Bit depth                        : 16 bits
            Stream size                      : 49.9 MiB (1%)
            Language                         : English
            Menu
            Duration                         : 4mn 32s
            Language                         : English
            Encoded date                     : UTC 2012-01-20 00:31:22
            • 3. Re: Need help reading the info from GSpot...
              Ah, an Apple Intermediate CODEC. Perhaps this ARTICLE will give you some tips?
              • 4. Re: Need help reading the info from GSpot...
                Thanks, Bill... I'll have to take the file over to our Mac lab and work on it there... I wonder if PrPro on the Mac will open it? We'll find out!
                • 5. Re: Need help reading the info from GSpot...
                  David,
                  That is a good question, and I cannot answer it. Not sure if that CODEC can be used by PrPro, on a Mac. I'd see if one of your Macs has it (might ONLY work in FCP?), and give it a try. Might have to go back to FCP and be Saved with some other CODEC.
                  Please report what you find in the Mac lab, as I will certainly learn something.
                  • 6. Re: Need help reading the info from GSpot...
                    FYI, PrPro did read the file just fine on the Mac… exported out using a
                    cross-platform codec, so I’ve got a version I can work with on my PC.
                    Thanks for the help!
                    • 7. Re: Need help reading the info from GSpot...
                      Great news!
                      Thanks for reporting your success.
