6 Replies Latest reply on Mar 30, 2012 8:28 AM by jfb00
    AdvancedDatagrid Sort
    jfb00 Level 3
      I am trying to do a generic sort function for ADG such as:
      public static function sortCompareFunction(obj1:Object, obj2:Object, gc:AdvancedDataGridColumn):int {
               return ObjectUtil.numericCompare(Number(obj1[gc.dataField].toString().replace(',','')), Number(obj2[gc.dataField].toString().replace(',','')));
      I got the idea from here:
      http://cookbooks.adobe.com/post_Sorting_numeric_values_in_a_Flex_DataGrid-2881.html
      ArgumentError: Error #1063: Argument count mismatch on assets.valueObjects::Utils$/sortCompareFunction(). Expected 3, got 2.
      I am using SDK 4.5.1, can anyone help with this?
      Thanks!
        • 1. Re: AdvancedDatagrid Sort
          jfb00 Level 3
          bump1
          • 2. Re: AdvancedDatagrid Sort
            jfb00 Level 3
            bump2
            nobody can give an idea?
            • 3. Re: AdvancedDatagrid Sort
              Sathyamoorthi Level 2
                   You can't do in this way.
                   create your own datagridcolumn and write this sortcompare function there
              public  function sortCompareFunction(obj1:Object, obj2:Object):int
                       return ObjectUtil.numericCompare(Number(obj1[dataField].toString().replac e(',','')), Number(obj2[dataField].toString().replace(',','')));
              this will suely work!!!
              • 4. Re: AdvancedDatagrid Sort
                jfb00 Level 3
                Thanks for you reply and help.
                This is what i am trying to avoid becuase I have so many datagrids with many columns. I am trying to create a generic function in my utils.as file.
                It is not way to do it?
                Best,
                • 5. Re: AdvancedDatagrid Sort
                       I ask you to extend dataridcolumn and create your custom datagird column. this is what you really need.
                  DgdColumn2.as
                  package Dg2
                      public class DgdColumn2 extends DataGridColumn
                          public function SrtCmpFnNumeric(objItem1:Object, objItem2:Object):int
                              return ObjectUtil.numericCompare(objItem1[dataField], objItem2[dataField]);
                  in your main.as
                  var dgdClmn:DgdColumn2;
                  var column:Array = new Array();
                  for(var i:int = 0; i < 10; i++)
                      dgdClmn = new DgdColumn2();
                      dgdClmn.sortCompareFunction = dgdClmn.SrtCmpFnNumeric;
                      column.push(dgdClmn);
                  datagrid.columns = column;
                  • 6. Re: AdvancedDatagrid Sort
                    jfb00 Level 3
                    That works, only if I have to construct the columns dynamic.
                    Can I use this in a datagrid that it doesn't created by that way?
                    Thanks!
