• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Overlapping bleed on spreads with facing pages
Community Beginner ,
Jan 27, 2012 Jan 27, 2012
I am printing a brochure with facing pages, some where photos and graphic elements span both pages. With "Facing Pages" turned on, the two pages align perfectly.
However, my printing service requires that I print each page separately with a .125 inch bleed on all four sides of the page. This is easy enough. I turn off the "facing pages" in DOCUMENT SETUP then extend my color and graphic bleeds on all four sides.
When printed and after cutting, the pages and elements will line up perfectly.   My problem is when I then turn on "Facing Pages" again just to see how the brochure will look, the elements of the inner bleed overlap one another. In preview mode for single pages, the bleed is not shown on all four sides. Using preview mode with facing pages, I still see the "Bled elements" on the right hand side of the left page and the left hand side of the right page.
Is there a way to create the bleed on all four sides of a single page that my printer requires but still be able to turn on the facing pages to see how it looks without seeing the overlap in the center (from the required single page bleeds) where the two pages meet?   I would appreciate thoughts from anyone.
TOPICS
How to
Views
53.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Where are you turnon on facing pages again? Sounds like in Acrobat, and if you have inside bleeds they show.
A screen shot would be really helpful. Use the camera icon onthe web page to embed your capture in a post like this:
Votes
Translate
Translate
Report
Report
Hi Peter,
Thanks for your quick reply. I am refrring to the display within InDesign.
Here is a screen-grab of a single page showing the bleed marks and the extended graphical elements (In this case, the olive colored box and the line). This is a right-hand-page of a spread. You can see that I extended the graphical elements on all sides to the red line indicating a .125 inch bleed.
This view is nin NORMAL mode. If I was to change it to PREVIEW, then of course the bleed would not be shown.
Now, when I turn on the FACING PAGES in InDesign and am in PREVIEW mode, the bleed is not shown anywhere except on the inside. Notice how the olive box and the horizontal line bleed from the right-hand page to the left hand page and how the colored box from the left hand page bleeds over to the right-hand page.
Again, when I preint single pages for my printer, the bleed will show on all four sides which is of course what I want. But what I need to know is if there is a way to show facing pages within InDesign without the internal bleed showing so I can show myself and others how this will look?
When I print spreads out to pdf, it still looks the way it does on the screen. Others have said that an iternal bleed is usually not necessary because the bidning will cover up any blemish in the printing/cutting, but these pages will be wire bound so edge-to-edge coverage is mandatory.
I hope this helps.
Any ideas from Peter or anyone erlse would be great.
Thanks!!!
Votes
Translate
Translate
Report
Report
Community Expert ,
Sorry, the answer is if you need the sort of inside bleed I'm seeing here that requires splitting the spread, there's no way to put it back together ithe same document. All is not lost, though, if all you are looking for is to see it as a spread for proofing. Place the pages from this file into a new one and crop off the bleeds. You can use a script to automate the process, and you'll find a really good one here: InDesignSecrets » Blog Archive » Zanelli Releases MultiPageImporter for Importing both PDF and INDD ...
Votes
Translate
Translate
Report
Report
Peter,
I will try this now.
I wish there was a way to do this organically within InDesign, but this could work as a time saver for sure.
Thank you so much.
Votes
Translate
Translate
Report
Report
Community Expert ,
In this situation I'm tempted to make my page size larger by the amount of the inside bleed and set the inside bleed value to 0, then increase the inside margin by the same amount and add a guide on the master page where the real page edge will be (along with manual crop marks, so you'll probably want to add some slug, too, and notes for the printer explaining what you did). Finally, add a layer on top and put a [Paper]-filled rectangle over the spine in the bleed area. Turn the layer off while working and for final output, but turn it on for making your proof spreads. This gives a more accurate view of a spiral bound book, in my opinion.
Votes
Translate
Translate
Report
Report
Pretty damn clever. Thank you Peter.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 28, 2012 Jan 28, 2012
I was thinking about this some more this morning, and it occurred to me that if you have more time than good sense (like me), you could add a graphic on the layer you hide to simulate the wire binding, too. That would make for an even more impressive client presentation, and if you do a lot of wire-bound work it might even be worth the effort to make and save the graphic for re-use.
Votes
Translate
Translate
Report
Report
Community Expert ,
If you manually add an inside bleed, you have to watchout for crossovers—you'll no longer be able cross a single image across the gutter without losing the part of the image that crosses over. You'll have to repeat the image on each page and offset for the bleeds.
Votes
Translate
Translate
Report
Report
Community Expert ,
Good point. Not a huge concern, I'd guess, though, for a spiral bound doc (though my sensibilities may not be anyone else's regarding when it would be approriate to cross the spine).
Votes
Translate
Translate
Report
Report
Peter and Rob,
Thank you for all of your help. For the stated purpose, I utilized Peter's idea and just created another InDesign document and placed each page (without the bleeds showing) in this new document. I spaced each page an 1/8 of an inch and also (prior to Peter's suggestion...lol) wsted time and created a graphic to look like a spiral bind and included that on the master page. All of this just to show my partners how the book would look when finsihed as well as be instructional for my printer.
All this being said, it would be nice if Adobe had an option that when in presentation mode with a spread, that the bleed elements are hidden not only on the outside of the presentation but on the spine as well.
Thanks again everyone.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 03, 2022 Nov 03, 2022
I found all the responses quite time consuming. So, I created a single page pdf, (without including my bleeds as you would for printing). Then I opened my document in Acrobat pro/reader and viewed the document as a two page view. In the menu across the top, View>Page Display>Two Page view. This eliminates the overlap bleed in the centre margin and is far quicker than running a script.
Votes
Translate
Translate
Report
Report
Feb 15, 2023 Feb 15, 2023
The issue is here is that you can't run style guides that switch/align relative to the spine (away from/towards spine) - ideal for folios so the page number is always outside etc.
I've found I manually have to split apart the bleeding pages in the pages box but that gets tiresome for a wire-bound book which might be many pages long. I suppose you could set up master left and right pages and manually assign them right before export so you're sidestep the issue the addition of a single page throwing the whole document alignment out, but it's fiddly indeed.
It would be really nice if Adobe could just let us have bleed at the spine for facing page documents. Even if one of the preview modes throws everything back together again. Anyway...
Votes
Translate
Translate
Report
Report
New Here ,
Jun 13, 2023 Jun 13, 2023
Here's my issue. INDD Page with 5mm bleed all round. including inside gutter. These two pages have fullpage colour backgounds that bleed into the centre of the book. Designed on two INDD pages as a spread, output as single PDF/x press quality pages - produces a mirror 5mm strip on each inside bleed area. Similarly, when theres a full bleed picture on one page and not on the other, same effect. I want Indesign to output to PDF honoring the inside gutter bleed. Printer requirements.black ornage mirror bleeds.pngfull page bw image bleed.pngimage bleed png.png
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Hi @JayneGould , The original post is from 2012, so you might want to start a new thread. It’s normal for the inside bleed to come from the opposite page—almost all binding methods fold, rather than trim, the spread on the spine, so the inside bleed would be removed by the printer in the page imposition. The exception would be a binding method where the inside edge is trimmed —e.g. Wire-O binding.
Votes
Translate
Translate
Report
Report
