4 Replies Latest reply on Jan 30, 2012 3:01 PM by apmaui808
    Script To Generate Parallel Lines in Photoshop
    apmaui808 Level 1
      How can I generate parallel lines so that each line is spaced uniformly as it fills up the entire document? In the simple script below, I used the underscore to create the line. My problem seems to be that the succeeding lines (layers) are always aligned to the first layer in the iteration. How can that be fixed? Thanks in advanced.
      // This script will create parallel lines which can be used for designing pages with lines
      var defaultRulerUnits = preferences.rulerUnits;
      preferences.rulerUnits = Units.PIXELS;
      bgLine = new SolidColor();
            bgLine.rgb.red = 255;
            bgLine.rgb.green = 255;
            bgLine.rgb.blue = 255;
            backgroundColor = bgLine;
      var newDocumentRef = documents.add(600,1000, 72.0, "Parallel Lines Generator");
      newDocumentRef = null;
      var textArray = [
                  "_____________________________________________________________________________________",
      //if additional lines are needed, it can be just added to the array
      var AD = activeDocument ;
      for(a=1;a<=textArray.length;a++){
            var TextLayer = AD.artLayers.add();
            TextLayer.kind = LayerKind.TEXT;
            TextLayer.opacity = 100;
             var txtRef = TextLayer.textItem;
                  txtRef.font = "Arial";
                  txtRef.contents = textArray[a-1];
                  txtRef.size = 12;
                  var textPosition = [30,  20]; // 30 is the margin and 20 is distance from top. The next text line should be 20 + 20 (can be any uniform increment desired)
                  txtRef.position = textPosition;  // I cannot seem to get the next layer move down by a uniform increment, let us say 20 pixels
      // Merge all the Text Layers and leave the entire file unflattened
          var background = AD.layers[AD.layers.length -1];
          if (background.isBackgroundLayer) {
              background.visible = false;
              AD.mergeVisibleLayers();
              background.visible = true;
      // At this point, I like to rename the merged text layer with a layer name "Parallel Lines" before saving it as psd file.
      preferences.rulerUnits = defaultRulerUnits;
        • 1. Re: Script To Generate Parallel Lines in Photoshop
          If you want to draw lines why are you using text, Why not just add an empty layer get the document width and hight and loop through the document hieght  I=0  while I is <  height by some spacing factor  in each iterration make a new line selection at height i document wide and stroke the line selection..
          • 2. Re: Script To Generate Parallel Lines in Photoshop
            c.pfaffenbichler Level 9
            And why not simply create a Pattern? (Edit: And then use a Pattern Layer. )
            JJMack already mentioned Selections, Paths would be another option for creating a Layer of lines.
            apmaui808, could you please elaborate what exactly you are trying to achieve?
            • 3. Re: Script To Generate Parallel Lines in Photoshop
              Paul Riggott Level 6
              And here is another alternative....
              #target Photoshop
              app.bringToFront();
              function main(){
              if(!documents.length) return;
              var win = new Window( 'dialog', 'Draw Lines' );
              g = win.graphics;
              var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.99, 0.99, 0.99, 1]);
              g.backgroundColor = myBrush;
              win.orientation='row';
              win.p1= win.add("panel", undefined, undefined, {borderStyle:"black"});
              win.g1 = win.p1.add('group');
              win.g1.orientation = "row";
              win.title = win.g1.add('statictext',undefined,'Draw Lines');
              win.title.alignment="fill";
              var g = win.title.graphics;
              g.font = ScriptUI.newFont("Georgia","BOLDITALIC",22);
              win.g5 =win.p1.add('group');
              win.g5.orientation = "row";
              win.g5.alignment='fill';
              win.g5.spacing=10;
              win.g5.st1 = win.g5.add('statictext',undefined,'Number of lines Vertical');
              win.g5.st1.preferredSize=[150,20];
              win.g5.et1 = win.g5.add('edittext',undefined,'0');
              win.g5.et1.preferredSize=[50,20];
              win.g5.et1.onChanging = function() {
                if (this.text.match(/[^\-\.\d]/)) {
                  this.text = this.text.replace(/[^\-\.\d]/g, '');
              win.g10 =win.p1.add('group');
              win.g10.orientation = "row";
              win.g10.alignment='fill';
              win.g10.st1 = win.g10.add('statictext',undefined,'Number of lines Horizontal');
              win.g10.st1.preferredSize=[150,20];
              win.g10.et1 = win.g10.add('edittext',undefined,'0');
              win.g10.et1.preferredSize=[50,20];
              win.g10.et1.onChanging = function() {
              win.g15 =win.p1.add('group');
              win.g15.orientation = "row";
              win.g15.alignment='fill';
              win.g10.st1 = win.g15.add('statictext',undefined,'Line Width');
              win.g10.dd1 = win.g15.add('dropdownlist');
              for(var t =1;t<21;t++){
                  win.g10.dd1.add('item',t);
              win.g10.dd1.selection=0;
              win.g100 =win.p1.add('group');
              win.g100.orientation = "row";
              win.g100.alignment='fill';
              win.g100.bu1 = win.g100.add('button',undefined,'Add Lines');
              win.g100.bu1.preferredSize=[110,25];
              win.g100.bu2 = win.g100.add('button',undefined,'Cancel');
              win.g100.bu2.preferredSize=[110,25];
              win.g100.bu1.onClick=function(){
              win.close(0);
              var horz = Number(win.g10.et1.text);
              var vert = Number(win.g5.et1.text);
              var lineWidth = win.g10.dd1.selection.index + 1;
              var crossHatch = activeDocument.artLayers.add();
              crossHatch.name = "Draw Lines";
              var spaceH = activeDocument.height.as('px')/(horz+1);
              var spaceV = activeDocument.width.as('px')/(vert+1);
              var spcH = spaceH;
              var spcV = spaceV;
              for(var a =0;a<horz;a++){
                 lineHorzVert(spcH,'H',lineWidth);
                 spcH +=spaceH;
              for(var v =0;v<vert;v++){
                  lineHorzVert(spcV,'V',lineWidth);
                  spcV +=spaceV;
              function lineHorzVert(space,HV,strokeWidth) {
              if(HV.toLowerCase() == 'h'){
                  HV = 'Sngr'; LT = 'Top ';
                  }else{
                       HV = 'Sngc'; LT = 'Left';
              var Black = new SolidColor();
              Black.rgb.hexValue = '000000';
                  var desc = new ActionDescriptor();
                      var ref = new ActionReference();
                      ref.putProperty( charIDToTypeID('Chnl'), charIDToTypeID('fsel') );
                  desc.putReference( charIDToTypeID('null'), ref );
                      var desc2 = new ActionDescriptor();
                      desc2.putUnitDouble( charIDToTypeID(LT), charIDToTypeID('#Pxl'), space );
                  desc.putObject( charIDToTypeID('T   '), charIDToTypeID(HV), desc2 );
                  try{
                  executeAction( charIDToTypeID('setd'), desc, DialogModes.NO );
                  activeDocument.selection.stroke (Black, strokeWidth, StrokeLocation.CENTER, ColorBlendMode.NORMAL, 100, false);
                  activeDocument.selection.deselect();
                  }catch(e){}
              win.center();
              win.show();
              main();
              • 4. Re: Script To Generate Parallel Lines in Photoshop
                apmaui808 Level 1
                This is exactly the script I am looking for. Thanks a lot. Now I can make probably guest sign-books or customized notebooks with special images underneath...
