1 Reply Latest reply on Jan 28, 2012 10:26 PM by jefecame
    How to Edit the xml node value using flex from the front end UI
    alokgswamy@gmail.com Level 1
      Hi All,
      I am having a use case with flex 4.6
      1> To read the external xml file
      2> Display the tree structure in the front end UI
      3> Edit the node values of the xml file from the front end UI and save it back
      How to go about the above use case, any blogs or links on the above case will be help
      Alok
