6 Replies Latest reply on Jan 29, 2012 2:09 PM by johnbullas
    Inserting filename and page numbers into multiple PDF files?
    johnbullas
      Have since seen this thread, BUT still interested in the syntax of the code
      to insert filename and page # into multiple files:
      http://forums.adobe.com/thread/951925?tstart=0
      Good Evening (GMT!)
      I have approx 100 PDFs with one or two pages in each, they are English translations
      of Russian language test certificates and the formatting/feel of the originals is lost in
      the translations. The only real link between the two sources is the "_RUS" and "_ENG"
      filename suffixes and the common leading filenames otherwise. Thus I need to maintain
      a record of the filename in any page I print off, should there be a need to refer back to
      the original if the translation is open to artistic licence.
      I have a script (below) that happily adds a page x/y and filename into the active file,
      what I would like is to be able to do this insertion into multiple files as defined by a
      portfolio or a selection via a select files dialogue box
      I am quite out of my depth now as my past skirmishes with JavaScript have set
      cookies and tweaked a few other browser doodads in webauthoring
      Any help most appreciated on this one...
      Kind Regards
      Dr B
      Southampton
      UK
      NB the filename inserted may be corrupted as a result of my last tweakings
      will sort that one out ASAP....
      // SetRemoveFooter
      // Modified as marked
      // Menu item generation
      app.addSubMenu({ cName: "Footer",cUser: "Set/Remove Complex Footer", cParent: "File", nPos: 20 });
      app.addMenuItem({ cName: "Set Filename", cParent: "Footer", cExec: "SetFooter(1)"});
      app.addMenuItem({ cName: " -> Set Date .... centered", cParent: "Footer", cExec: "SetFooter(2)"});
      app.addMenuItem({ cName: " -> Set Date .... right", cParent: "Footer", cExec: "SetFooter(3)"});
      //add page x of y
      app.addMenuItem({ cName: "Set Page ", cParent: "Footer", cExec: "SetFooter(4)"});
      app.addMenuItem({ cName: "Set Both", cParent: "Footer", cExec: "SetFooter(5)"});
      app.addMenuItem({ cName: "-------------------------------", cParent: "Footer",cExec: "{}"});
      app.addMenuItem({ cName: "Remove Both", cParent: "Footer", cExec: "RemoveFooter(5)"});
      app.addMenuItem({ cName: "Remove Date Time (Filename)", cParent: "Footer", cExec: "RemoveFooter(1)"});
      app.addMenuItem({ cName: "Remove Page", cParent: "Footer", cExec: "RemoveFooter(4)"});
      //Set/remove Footer
      function SetFooter(ARG)
      var re = /.*\/|\.pdf$/ig;
      var FileNM = + this.path.replace(re,"")+".pdf";
      var Path = this.path;
      var AcDate = new Date();
      var AcDateFormat = "dd/mm/yyyy"
      var Box2Width = 100
      for (var p = 0; p < this.numPages; p++)
      var aRect = this.getPageBox("Crop",p);
      var TotWidth = aRect[2] - aRect[0]
      if (ARG<=3 || ARG==5)
      {var fd = this.addField("xftDate", "text", p, [30,15, TotWidth-30-30,30]);
      //print output?
      fd.value = util.printd(AcDateFormat, AcDate) + " (" + FileNM +")";
      // TEXT SIZE SETTING
      fd.textSize=12; fd.readonly = true;
      if (ARG==1){ fd.alignment="left" };
      if (ARG==2){ fd.alignment="center" };
      if (ARG==3){ fd.alignment="right" };
      if (ARG==4 || ARG==5)
      {var bStart=(TotWidth/2)-(Box2Width/2)
      var bEnd=((TotWidth/2)+(Box2Width/2))
      var fp = this.addField(String("xftPage"+p+1), "text", p, [bStart,30,bEnd,15]);
      // print output?
      fp.value = "Page: " + String(p+1)+ "/" + this.numPages;
      fp.textSize=12; fp.readonly = true;
      fp.alignment="center";
      function RemoveFooter(ARG)
      if (ARG<=3 || ARG==5) {var x = this.removeField("xftDate");}
      if (ARG==2 || ARG==5) {for (var p = 0; p < this.numPages; p++)
      var x = this.removeField(String("xftPage"+p+1)); }
      will
