19 Replies Latest reply on Jan 29, 2012 10:47 PM by kglad
    Trace instance+Remove bitmaps
    McbainGames11 Level 2
      Hey,
      Well at the moment I am searching for my instance called instance11 but I can't find it because I need to remove a movieclip and I need that instance name to remove it(I think)
      package
                import com.greensock.*;
                import com.greensock.easing.*;
                import com.greensock.plugins.*;
                import com.kglad.HitF;
                import flash.display.Bitmap;
                import flash.display.DisplayObject;
                import flash.display.MovieClip;
                import flash.display.Sprite;
                import flash.display.Stage;
                import flash.events.Event;
                import flash.events.MouseEvent;
                import flash.events.TimerEvent;
                import flash.filters.DisplacementMapFilter;
                import flash.utils.Timer;
                TweenPlugin.activate([AutoAlphaPlugin]);
                public class Level extends Sprite
                          public var hitF:HitF = HitF.getInstance();
                          public var myTimer:Timer = new Timer(1000, 30);
                          public var birdImageHolder:Sprite = new Sprite();
                          public var timer_limit:int = 30;
                          public var _stage:Stage;
                          public var timerNum:int;
                          public var star_lives:int = 3;
                          public var hitClear:Boolean = true;
                          public var birdA:Array = [];
                          public var birdImage:Bitmap = new Assets.bird();
                          public var enemyA:Array = [];
                          public var enemyImageHolder:Sprite = new Sprite();
                          public var currentImage:Bitmap = new Assets.levelOne();
                          public var star:Sprite = new Sprite();
                          public var star_one:Bitmap = new Assets.star();
                          public var star_two:Bitmap = new Assets.star();
                          public var star_three:Bitmap = new Assets.star();
                          public var tryAgainImageHolder:Sprite = new Sprite();
                          public var tryAgainImage:Bitmap = new Assets.tryAgain();
                          public var mainMenuImageHolder:Sprite = new Sprite();
                          public var mainMenuImage:Bitmap = new Assets.mainMenu();
                          public function Level(stageVar:Stage)
                                    _stage = stageVar;
                                    activateControls();
                          public function activateControls():void
                                    createEnemy();
                                    createStars();
                                    createBird();
                                    currentLevel();
                                    myTimer.start();
                                    myTimer.addEventListener(TimerEvent.TIMER, TimerHandler);
                                    addEventListener(Event.ENTER_FRAME, loopF);
                          public function deactivateControls():void
                                    timerNum = 0;
                                    birdA[0].parent.removeChild(birdA[0]);
                                    birdA.splice(0,1);
                                    star_one.parent.removeChild(star_one);
                                    star_two.parent.removeChild(star_two);
                                    star_three.parent.removeChild(star_three);
                                    removeEventListener(Event.ENTER_FRAME, loopF);
                                    myTimer.stop();
                                    myTimer.removeEventListener(TimerEvent.TIMER, TimerHandler);
                                    //instance11 name goes here when found ??     .enemyImageHolder.removeChild(getChildByName("enemy"));
      //I want to remove my enemy objects..
                                    for(var i:int = enemyA.length - 1; i >= 0; i--)
                                              enemyA[i].parent.removeChild(enemyA[i]);
                                              enemyA.splice(i,1);
                          public function createBird():void
                                    addChild(birdImageHolder);
                                    birdImageHolder.y = 330;
                                    birdImageHolder.addChild(birdImage);
                                    birdImage.y = -37;
                                    birdImage.x = -40;
                                    birdA.push(birdImage);
                                    birdImage.alpha = 0;
                                    TweenLite.to(birdImage, 4, { alpha:1, visible:1, ease:Expo.easeOut });
                          public function createEnemy():void
                                    var max_enemies:int = 10;
                                    var gap:int = 100;
                                    for(var i:int=0; i<max_enemies; i++)
                                              addChild(enemyImageHolder);
                                              var enemy:Bitmap = new Assets.iceBlock();
                                              enemyImageHolder.addChild(enemy);
                                              enemy.x = Math.random() * _stage.stageWidth - enemy.width;
                                              enemy.y = - i * (gap + enemy.height) - 60;
                                              enemyA.push(enemy);
                                              enemy.name = "enemy";
                                              trace(enemy);
      //this outputs: instance11.instance14.enemy
                                    enemyImageHolder.alpha = 0;
                                    TweenLite.to(enemyImageHolder, 4, { alpha:1, visible:1, ease:Expo.easeOut });
                          public function createStars():void
                                    addChild(star);
                                    star_one.x = 0;
                                    star_one.y = 330;
                                    star_one.name = "star_one";
                                    star.addChild(star_one);
                                    star_two.x = 49;
                                    star_two.y = 330;
                                    star_two.name = "star_two";
                                    star.addChild(star_two);
                                    star_three.x = 95;
                                    star_three.y = 330;
                                    star_three.name = "star_three";
                                    star.addChild(star_three);
                                    star.alpha = 0;
                                    TweenLite.to(star, 4, { alpha:1, visible:1, ease:Expo.easeOut });
                          public function updateEnemyPosition():void
                                    var fall_limit:int = 2;
                                    for(var i:int; i<enemyA.length; i++)
                                              var enemy:DisplayObject = enemyA[i] as DisplayObject;
                                              enemy.y += fall_limit;
                          public function updateBirdPosition():void
                                    birdImageHolder.x = mouseX;
                          public function loopF(event:Event):void
                                    updateBirdPosition();
                                    updateEnemyPosition();
                                    checkHitF();
                          public function currentLevel():void
                                    addChild(currentImage);
                                    currentImage.x = 150;
                                    currentImage.y = -39;
                                    currentImage.name = "currentImage";
                                    currentImage.alpha = 0;
                                    TweenLite.to(currentImage, 2, {x:150, y:160, alpha:1, visible:1, ease:Expo.easeOut});
                          public function checkHitF():void
                                    for (var i:int=enemyA.length-1; i>=0; i--)
                                              if (hitF.hit(birdA[0],enemyA[i]) && hitClear)
                                                        star_lives--;
                                                        hitClear = false;
                                                        addChild(enemyA[i]);
                                                        enemyA.splice(i,1);
                                              } else {
                                                        hitClear = true;
                                    if ((star_lives == 1))
                                              star_one.alpha = 1;
                                              star_two.alpha = 0.5;
                                              star_three.alpha = 0.5;
                                    else if ((star_lives == 2))
                                              star_one.alpha = 1;
                                              star_two.alpha = 1;
                                    else if ((star_lives == 3))
                                              star_one.alpha = 1;
                                              star_two.alpha = 1;
                                              star_three.alpha = 1;
                                    else if(star_lives < 1)
                                              deactivateControls();
                                              tryAgain();
                          public function TimerHandler(event:Event):void
                                    timerNum++;
                                    if(timerNum == 2)
                                              removeChild(getChildByName("currentImage"));
                                    if(timerNum == timer_limit)
                                              tryAgain();
                          public function tryAgain():void
                                    addChild(tryAgainImageHolder);
                                    tryAgainImage.y = 115;
                                    tryAgainImage.x = 145;
                                    tryAgainImage.name = "tryAgain";
                                    tryAgainImageHolder.addChild(tryAgainImage);
                                    tryAgainImageHolder.addEventListener(MouseEvent.CLICK, tryAgainClick);
                                    tryAgainImageHolder.addEventListener(MouseEvent.ROLL_OVER, tryAgainRollOver, false, 0, true);
                                    tryAgainImageHolder.addEventListener(MouseEvent.ROLL_OUT, tryAgainRollOut, false, 0, true);
                                    addChild(mainMenuImageHolder);
                                    mainMenuImage.y = 190;
                                    mainMenuImage.x = 145;
                                    mainMenuImage.name = "mainMenu";
                                    mainMenuImageHolder.addChild(mainMenuImage);
                                    mainMenuImageHolder.addEventListener(MouseEvent.CLICK, mainMenuClick);
                                    mainMenuImageHolder.addEventListener(MouseEvent.ROLL_OVER, mainMenuRollOver, false, 0, true);
                                    mainMenuImageHolder.addEventListener(MouseEvent.ROLL_OUT, mainMenuRollOut, false, 0, true);
                                    tryAgainImage.alpha = 0;
                                    TweenLite.to(tryAgainImage, 4, { alpha:1, visible:1, ease:Expo.easeOut });
                                    mainMenuImage.alpha = 0;
                                    TweenLite.to(mainMenuImage, 4, { alpha:1, visible:1, ease:Expo.easeOut });
                          public function deleteTryAgain():void
                                    removeChild(getChildByName("tryAgain"));
                                    removeChild(getChildByName("mainMenu"));
                          public function tryAgainClick(event:Event):void
                                    //deleteTryAgain();
                                    activateControls();
                          public function tryAgainRollOver(event:Event):void
                                    event.currentTarget.alpha = 0.5;
                          public function tryAgainRollOut(event:Event):void
                                    event.currentTarget.alpha = 1;
                          public function mainMenuClick(event:Event):void
                                    //deleteTryAgain();
                                    Main.instance.arrangeMenu();
                          public function mainMenuRollOver(event:Event):void
                          public function mainMenuRollOut(event:Event):void
      Basically I want to find a way to remove my enemy bitmaps and tryagain and mainmenu bitmaps and I think I have to find where it is in the DisplayObjectContainer which is instance11.instance14.enemy but I am having trouble identifying instance11, I know instance 14 is enemyImageHolder.
      That is what I am trying to do please help me remove these things
