1. Re: Is it possible to use or find more than five colors?
VikramSethi Jan 30, 2012 4:31 AM (in response to more than five colors?)Hello Jasmin,
Kuler does not support more than five colors as of now. It would be great if you can talk about a few workflows where you find having more than five colors useful.
Regards,
Kuler team
2. Re: Is it possible to use or find more than five colors?
bucket Nov 12, 2013 3:06 PM (in response to more than five colors?)As a UX designer, I'm not only creating a UIs for sites with a 5 color pallet but sometimes I'm required to intoduce user customization into my site/apps that allow the user to select their own color to represent a category. An example of this might be a calendar app where assigning unique colors to different calendars would be done by the user. A range of colors that match the over all look and feel of the app/site is very appealing, even if choice is given to the user to select their own color.
In any case, it would be nice to be able to generate more than a limiting 5 colors.
Great app BTW. I use it all the time.
3. Re: Is it possible to use or find more than five colors?
lebing Dec 16, 2013 3:17 PM (in response to VikramSethi)Just wanted to add to this discussion. As a brand designer along with defining color usage, across ui, print, etc., I distribute and manage access to our brand standards. Currently we share .ase files via a centralized brand site. If we could share these via Kuler it could be great. We also create pallettes that are more extensive than 5 colors. My thinking would be that we would initially create a pallette in one of the CC apps (illustrator, fireworks, indesign, etc.) and sync the pallette to kuler so that anyone within our organization or externally would always have the latest version of our color systems. Beyond that it would be great if we could grant access to people within our organization permissions to edit or not. Maybe this is built into CC in some way, if so I'm not familiar.
Best,
Tyler
4. Re: Is it possible to use or find more than five colors?
LucidLethargy Jan 10, 2014 10:19 AM (in response to VikramSethi)I am rather shocked at this 5 color limitation. Every company I've ever worked at has a palette of at least 10 colors they use all across the board. Please add the option to expand this, I find it insanely shortsighted that this is not allowed. The workaround is easy enough (multiple sets) but this seems so incredibly unnecessary and disjointed. I also find it odd you can't name these colors individually, why is that?
5. Re: Is it possible to use or find more than five colors?
Dave E Jan 10, 2014 11:42 AM (in response to LucidLethargy)Hi LucidLethargy,
Thanks for the perspective.
Kuler is focused almost entirely on color inspiration. Our philosophy has been that 5 colors is a good jumping off point--and, adding more colors would move the focus away from inspiration and more towards production. I genuinely want to know if you agree or disagree with this line of thinking?
All that said, there is still probably room in Kuler for more colors or some sort of deeper view of each theme. And, I defnitiley think this is something we should investigate further.
Looking forward to your response.
Dave -
6. Re: Is it possible to use or find more than five colors?
LucidLethargy Jan 14, 2014 1:44 PM (in response to Dave E)I was attempting to use Kuler as a means to unite all the adobe programs around my color templates. With this use in mind, I was definitely interested in seeing the option to add more colors. Strangely enough, however, I've learned Kuler doesn't sync with photoshop CC (you can save to the web from it, but you can't download to PS from Kuler,) so I'm not entirely sure how useful this is to me. I have to manually download the profiles and drag them into the swatches category in order to use them, which to be fair is pretty useful (better than me manually entering them) - but it's a far cry from the ideal cloud-based organization structure of having your pallette's right where you need them in all your adobe applications.
My two cents: Adobe needs a much more comprehensive overhaul for tieing in professional pallette's. This may be Kuler, or it may not... either way, I see no difference thus far between using the products as I used to and using the creative cloud. When I think of cloud-based products I think of everything I need being tied to my account. Currently that's not possible with colors, it seems.
For what it's worth, I think it's implemented very well in InDesign, so with that respect I think Kuler is great save for the limitation of 5 colors. Perhaps it's worth having a "create" category, and a "library" category - that way you can label each color and save them in any amount you wish for retention of your current pallette's. I think that would be really cool - and if it was tied into Photoshop the same way it is tied into InDesign it would be nearly perfect. Seems like a relatively small tweak to the overall structure with a big payoff for us professionals if it can be implemented.
7. Re: Is it possible to use or find more than five colors?
Dave E Jan 17, 2014 9:50 AM (in response to LucidLethargy)This is really helpful. Thank you for hte input LucidLethargy.
8. Re: Is it possible to use or find more than five colors?
SGoodship Feb 7, 2014 5:08 PM (in response to Dave E)Kuler is a very kul tool. I have been experimenting with it on my iPhone and really want to incorporate into workflow. If you are doing branding, you have primary color themes and secondary themes. This is often going to amount to more than 5 colors. Often, a designer knows that they have to create a specific number of colors for a design project (maybe a set of icons or something). 5 is just not helpful for the way designers work. I understand that Kuler was initially intended as inspiration but the minute you decided to integrate with Adove apps and carry themes into the apps to use, it's way beyond inspiration. A color inspiration tool that can go right into practical design is needed and if that is Kuler, you seem like you are most of the way there already. Thanks for being open to feedback.
9. Re: Is it possible to use or find more than five colors?
Guldvarg Mar 14, 2014 6:07 AM (in response to VikramSethi)Hi, im a designer of apps, games, webs and brands in general.
I've just recently found the integration of Kuler in Illustrator and love it!
A option to add more colors in Kuler in combination with a extended Adobe suite integration would make Kuler a must have for every project since you that way can avoid having to manually set up a color scheme for every new project and the hassle to sync that color scheme between the products in your suite.
10. Re: Is it possible to use or find more than five colors?
jmlg12 May 1, 2014 8:37 AM (in response to Dave E)Hi,
I agree with all post of that feed, even if the first intent of Kuler was to capture and share some "cool" mood about color harmony for a Designer, it's a so cool and smart tool and environment that I'm confident that Adobe can't restrict Kuler in managing only 5 swatches at a time.
But in the other hand, it would be great if you can extend the tool allowing to name each swatch, selecting the default color schemas (rgn, hex, Lab,...) but also by extending the support of .ase files in AdobeBridge, AEM Dam, or even desktop explorer I'm order to manage/Crete a thumbnail of the "color swatches" natively.
In my opinion, once again, as often at Adobe, it's a very cool app issued from the developers creative team, but which is not pushed enough at a "professional" usable level.
JM
11. Re: Is it possible to use or find more than five colors?
Dazzer2473 Oct 23, 2014 2:49 AM (in response to more than five colors?)I am part of a team of designers working together across multiple clients with multiple colour palettes. I thought Adobe colour would be a great alternative to using libraries to share client colour specifications within a team and across multiple Adobe apps. However, it is restrictive in terms of the amount of colours that can be added as many of our clients have colour palettes that exceed 5 across primary and secondary brand colours. This could be very powerful in terms of being as design tool rather than a tool for inspiration only which seems limited and pointless.
