1 Reply Latest reply on Jan 30, 2012 12:35 PM by Dave LaRonde
    Making all assets end at the same time
    Deaner77 Level 1
      I need to have all my assets in my project end at the same time. Is there a way to allign the ends of them all?
      Dean
        • 1. Re: Making all assets end at the same time
          Dave LaRonde Level 6
          If everything is still footage, no problem: do a Select All, go to the point in time where everything should end and hit Option-] (left bracket, Mac) to set an identical out point for all layers.
          If there is video, an image sequence or something rendered from, say, a 3D application, you can use this trick ONLY if the layer's duration allows it.  Otherwise you'll have to enable Time Remapping to create a freeze frame at the current tail, and then use the Opt-] trick.
          Or just make the comp duration shorter, and forget about out points.
