1 Reply Latest reply on Jan 30, 2012 1:30 PM by cosikora
    Repeat / Restart Function on Condition
    cosikora
      Hello,
      I am attempting to put a statement in my .mxml file to make a private function restart if a certain condition is met.  I am not pro at coding in .mxml, but I believe I have a start at solving this issue.  Below it the code for my function, up to the point that the code would restart, if the condition is true:
      The last five lines are devoted to making the function restart itself if the condition 'mapServicesArray.length < 13'.  The line 'init (private function populateLayerDataDictionary);' is supposed to trigger the restart, but I am not sure how to do it (this code clearly doesn't, it is a test of mine).  Any advice would be welcome.
      Thank you in advance! (and sorry for my poor code formatting in this post!)
        • 1. Re: Repeat / Restart Function on Condition
          cosikora Level 1
          Here is the code to the function as I have it so far:
             private function populateLayerDataDictionary():void
              //the smallest and largest scales reasonably possible
              var smallestScale:Number = map.lods ? map.lods[0].scale : 1000000000;
              var largestScale:Number = map.lods ? map.lods[map.lods.length - 1].scale : 1;
              var data:Object;
              var priority:int = 0;
              var agsVersion:Number;
              // The next line controls whether the proxy in the <httpproxy> tag in config.xml
              // is used for each layer.  If want this set it to true; otherwise set it to false.
              // If there is no <httpproxy> tag in config.xml then the value of useProxy doesn't matter.
              var useProxy:Boolean = true;
              for each (var layer:Layer in map.layers)
               trace(layer.id);
               if (layer is ArcGISDynamicMapServiceLayer)
                var dmsLayer:ArcGISDynamicMapServiceLayer = layer as ArcGISDynamicMapServiceLayer;
                if (useProxy) dmsLayer.proxyURL = configData.proxyUrl;
                agsVersion = dmsLayer.version;
                if (isNaN(agsVersion))
                 // This happens if the map includes a service that is turned off or doesn't exist
                 mapServicesProcessed++;
                 continue;
                //make an object for this map service to hold the layer information
                var dmsMapServiceObj:Object = {id: dmsLayer.id, layers: new Array(), priority: priority++, url: dmsLayer.url, token: dmsLayer.token, proxyUrl: dmsLayer.proxyURL};
                //add the map service object to the array of map services
                mapServicesArray.push(dmsMapServiceObj);
                // set the max and min scales
                var maxScale:Number = layer.maxScale;
                var minScale:Number = layer.minScale;
                var getScales:Boolean = (maxScale == 0 && minScale == 0);
                if (getScales)
                 for each (var layerInfo:LayerInfo in dmsLayer.layerInfos)
                  if (layerInfo.maxScale > 0 && (maxScale == 0 || layerInfo.maxScale < maxScale)) maxScale = layerInfo.maxScale;
                  if (layerInfo.minScale > 0 && layerInfo.minScale > minScale) minScale = layerInfo.minScale;
                 layer.maxScale = maxScale > 0 ? maxScale : largestScale;
                 layer.minScale = minScale > 0 ? minScale : smallestScale;
                data = {name: dmsLayer.name, url: dmsLayer.url, token: dmsLayer.token, rtDefExpr: "", proxyUrl: dmsLayer.proxyURL};
                dmsLayer.getAllDetails(new AsyncResponder(onResult, onFault, data));
               else if (layer is ArcGISTiledMapServiceLayer)
                var tmsLayer:ArcGISTiledMapServiceLayer = layer as ArcGISTiledMapServiceLayer;
                if (useProxy) tmsLayer.proxyURL = configData.proxyUrl;
                agsVersion = tmsLayer.version;
                 continue;
                var tmsMapServiceObj:Object = {id: tmsLayer.id, layers: new Array(), priority: priority++, url: tmsLayer.url, token: tmsLayer.token, proxyUrl: tmsLayer.proxyURL};
                mapServicesArray.push(tmsMapServiceObj);
                if (layer.maxScale == 0 && layer.minScale == 0 && tmsLayer.tileInfo)
                 layer.maxScale = tmsLayer.tileInfo.lods[tmsLayer.tileInfo.lods.length - 1].scale;
                 layer.minScale = tmsLayer.tileInfo.lods[0].scale;
                data = {name: tmsLayer.name, url: tmsLayer.url, token: tmsLayer.token, rtDefExpr: "", proxyUrl: tmsLayer.proxyURL};
                tmsLayer.getAllDetails(new AsyncResponder(onResult, onFault, data));
               else if (layer is FeatureLayer)
                var feaLayer:FeatureLayer = layer as FeatureLayer;
                var layerDetails:LayerDetails = feaLayer.layerDetails;
                var tableDetails:TableDetails = feaLayer.tableDetails;
                if (layerDetails)
                 agsVersion = layerDetails.version;
                else if (tableDetails)
                 agsVersion = tableDetails.version;
                else
                 agsVersion = NaN;
                 continue;
                var url:String = feaLayer.url;
                var pos:int = url.lastIndexOf("/");
                url = url.slice(0, pos);
                var feaMapServiceObj:Object = {id: feaLayer.id, layers: new Array(), priority: priority++, url: url, token: feaLayer.token, proxyUrl: feaLayer.proxyURL};
                mapServicesArray.push(feaMapServiceObj);
                data = {name: feaLayer.name, url: url, token: feaLayer.token, rtDefExpr: feaLayer.definitionExpression, proxyUrl: feaLayer.proxyURL};
                var allDetails:AllDetails = new AllDetails();
                allDetails.layersDetails = [layerDetails];
                allDetails.tablesDetails = [tableDetails];
                onResult(allDetails, data);
               else
                // skip other kinds of layers (e.g. image services)
               // restarts and repeats populateLayerDataDictionary if there are missing services
               if (mapServicesArray.length < 13)
