4 Replies Latest reply on Feb 7, 2012 2:49 AM by Peter Spier
    Serial # template w/linked story on path to easily edit number batches
    designer_gurl
      Hey!!! I am making an indesign template for a customer they need it to serialize their product with a laser engraver and this jig that is already made from this same file. What it is is a series of 56 - 1.1" circles with 3 digit serial # following the path of each circle. I am going nuts trying to get this to work but I can't do it! If it is all one linked story I can just drop in a new batch of numbers and they will all be in the right place in 1 second! If it were not following the path I would have been done hours ago! I have linked up the file here so you can see any help thanks!!! I hope I am explaining this well!
      http://binarydetroit.com/helpmeplz/
        • 1. Re: Serial # template w/linked story on path to easily edit number batches
          A real pain in the neck, but doable. And I'd make this a non-facing document and set it up on the master page.
          I'd start with one circle, then click on it with the type on a path tool (cilci the triangle in the lower right of the text tool). Zoom in and use the direct select tool to adjust the inport and outport positions to the desired locations and set the length of the text on the circle.
          Select the circle and use step and repeat to build the grid.
          Click the outport of the first circle, then click in the path area of the second circle that has the text to link them. This should highlight the second circle and you should see the threading arrow inside the inport. Click the outport and continue thread the paths until the whole page is threaded.
          I didn't have any luck with using auto-flow to just place my number list, so I selected my page and from the pages panel menu selected Override All Master Objects. Then I just selecet the text file and clicked the loaded cursor on the path or the first circle (without holding a modifier key). If you have more numbers than circles, add a page and repeat the master objects override, then pick up the overset from the last circle onthe previous page and click on a new circle. I didn't test , but it might work to add multiple pages first, do the overrides, then place the list holding the Alt/Opt key to leave the cursor loaded for each page.
          • 2. Re: Serial # template w/linked story on path to easily edit number batches
            designer_gurl Level 1
            wow thanks so much! that worked like a charm! it was tricky like you said. the text path had to be made for the correct amount of characters - then deleted the characters so it was blank and repeated that into the grid. then it was just a matter of linking each one like you said. this is an extremely useful function no question about it. I knew it could be done but it is like a trick of the trade i guess! thanks again!
            • 3. Re: Serial # template w/linked story on path to easily edit number batches
              I suspect you made more work for yourself than absolutley necessary. I would have made the path a bit longer than the longest string I expect (or even nearly the full circumference) and adjusted the position so that I could either work with left aligned text or center-aligned text. Extra length on the path should not be a problem if each number is on its own line in your number list file.
              • 4. Re: Serial # template w/linked story on path to easily edit number batches
                Sorry, for got to add that in many fonts different numerals use differnt amounts of space, so making the path too tight could cause the list to go into overset at the first number that won't fit.
