0 Replies Latest reply on Feb 1, 2012 6:32 AM by SSzretter
    How to get the reference to the parent or current active window in an AIR app?
    SSzretter
      I have an AIR app with a component that is opening a PopUpWindow via PopUpManager.   The problem is, the pop up opens in the main application window, not the current active AIR window.  This is I am sure because it's using FlexGlobals.topLevelApplication.     SO, how do I get a reference to the current active window either via parent/owner, or some other method?
      I have tried using   this.parent, this.owner  (and this.owner.owner....   this.parent.parent)  , also have tried NativeWindow. which seems to not be available.
      This is an mx datagrid component, and it is opening a popup window in actionscript from a datagrid column filter editor.  So, how do you from that filter editor code open a pop up window / get a reference.
      Thanks!
      Update: I decided to create a new project for the component, and add in the Air libraries. Now I am able to access the "NativeApplication.nativeApplication.activeWindow" call. That gives me the correct Air window. However, it does not seem to be working:
      PopUpManager.addPopUp(this, NativeApplication.nativeApplication.activeWindow as DisplayObject);
      My popup does not appear. I am assuming because "activeWindow" is not actually a DisplayObject? (so how do I get the DisplayObject if that's the case?)
      UPDATE:
      Could it be a bug still?    http://jimmyflex.blogspot.com/2008/06/popupmanager-doesnt-work-in-air-windows.html
        https://bugs.adobe.com/jira/browse/SDK-12565
