3 Replies Latest reply on Oct 30, 2006 10:15 AM by herr mueller
    Antimated
    joesmoes
      Hello,
      I was wondering is there a way to layer some slides to keep moving constantly wile letting the under layer be paused!
      Please Help me!!!
        • 1. Re: Antimated
          herr mueller Level 1
          If you are not referring to a Flash Slide Presentation:
          Enclose the slides that you want to keep moving in a movieClip symbol.
          This will give them a timeline independent of the main timeline.
          Place a stop(); on the main timeline where you want the other slides to pause.
          If you are referring to a Flash Slide Presentation:
          Make the non-animating slides part of the Root slide (Default :presentation)
          This should receive a stop(); action on a second layer you create name actions
          • 2. Re: Antimated
            joesmoes Level 1
            i'm using the "Flash Document"
            I have stoped the main slide but it also stops all the layers
            Thanks!
            • 3. Re: Antimated
              joesmoes,
              Re-read my post. It requires the layers that need to continue to be placed in a movieclip symbol.
