1. Re: Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
Ankit_Jain Feb 8, 2012 8:51 AM (in response to ajkessel)Could you please let me know if you are facing this issue with any PDF that you try to open or only with a specific PDF? Also, do you face the same issue while accessing PDFs in the browser as well?
Please download the PDF at: kb2.adobe.com/cps/837/cpsid_83708/attachments/Acrobat_Reader_ReleaseNote_10.1.2.pdf and see if Acrobat still stalls for some time while rendering it.
2. Re: Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
gotchabebe May 9, 2012 12:49 PM (in response to Ankit_Jain)Amazing that ADOBE CAN NOT HELP US SOLVE THIS HUGE PROBLEM!!!! Instead of offering a solution to our major problem with this HORRIBLE PRODUCT ADOBE ACROBAT X PRO -- They always turn it around and ask another stupid question !!!
3. Re: Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
tmiskiew2 Jun 21, 2012 5:34 AM (in response to gotchabebe)Adobe Acrobat Reader X is a bummer, I agree 100%
Now, here is the solution to your problem: Go to Edit -> Preferences -> and uncheck the Option "Enable Protected Mode at Startup". Now close you Acrobat Reader and when you start it again it shloud not freeze anymore.
4. Re: Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
Roberto L Dec 27, 2012 8:18 AM (in response to ajkessel)Preferences-->security(enhanced)
Add folder path (where all your pdf are)
It work for me even for the pdf that are no inside this folder
Then a go back to add one more folder and the first folder that i add was not there
Did a repair acrobat
Go back to preference an the folder add is back
So i decide to uncheck "Automatically trust sites from my Win os security zone"
Since then everything work fine for me so i don't know witch part of this process fix my problem
Good luck
RL
5. Re: Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
JTB1965 Jan 15, 2013 10:28 PM (in response to Roberto L)"Automatically trust sites from my Win os security zone"
This has helped alot. I was entering a document and then after a few seconds it would freeze for 20-30 seconds and then come good, darn frustrating! Turned off "Automatically trust sites from my Win OS security zone" now allows me to operate as normal. Every once in a while a document would pause but I don't believe it is related to this issue.
Thanks for the suggestion.
6. Re: Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
geier Dec 16, 2013 5:21 AM (in response to JTB1965)On my computer, a issue with similiar symtoms was a network path pointing to an unavailable computer. Opening local files until the path disappeared from the recent files resolved the issue.
7. Re: Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
MHammes Apr 22, 2014 8:09 AM (in response to ajkessel)I changed recently used documents list to 1 [Preferences/Documents]. This has resovled the problem for me so far.
Variables:
Acrobat Version: 10.1.9
Document Size: 42x30
File location: Desktop
File creator: CutePDF Writer
Application: PScript5.dll Version 5.2.2
PDF Producer: GPL Ghostscript 8.15
PDF Version: 1.6 (Acrobat 7.x)
Prior to that, I tried unchecking "Automatically trust sites from my Win OS security zones" [Preferences/Security (Enhanced)]
and unchecking "Enable Enhanced Security" to no avail.
8. Re: Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
SumitV Aug 21, 2014 10:05 PM (in response to ajkessel)Hi All,
Can you please try the step below:
- Launch Acrobat;
- Go to Preferences -> Documents -> Documents in Recent used list.
Change value from 5 > 1
- Close and relaunch Acrobat.
9. Re: Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
jkbucks Oct 20, 2014 7:14 AM (in response to SumitV)Hi, I was actually searching for a solution to this problem for my Mac (2013 Mac Pro, 6x3.5ghz, 64 gb ram, 12 tb raid 0, all updates to Acrobat and OS X 10.9 - really should never have an issue with programs hanging) and tried SumitV's suggestions. Lo and behold, my recent documents list was set to 100 by default. Bringing that down to 10 has solved the issue. If your system is slower, taking it down to 5 or 1 may help.
Thanks SumitV!
