3 Replies Latest reply on Feb 1, 2012 2:12 PM by kglad
    Images load and shakes screen
      My SWF loads external images from an XML file.
      The problem is the layout shakes up and down as each image is being loaded into the grid because the images are bigger in size than the thumbnail "holder" they are being placed in. They are bigger so when you click on a thumb and the layout zooms in, the images won't be pixelated.
      I added all the images to the library of the fla file and exported in frame 1 but it didn't solve the shaking. Preloader worked, but images were still loaded in and then shrunk down to size.
      How can I keep the SWF from loading the images then shrinking them. Any help or suggestions would be much appreciated.
        • 1. Re: Images load and shakes screen
          after loading is complete, smooth your thumb and then add to the stage at an integer x and integer y.
          • 2. Re: Images load and shakes screen
            musicismything Level 1
            Thanks for your response... the images are loaded dynamically through XML.
            Here is the code for loading the thumbs... what section would I apply visibility to? Also, the smoothing, not sure where to apply it. I will look up bitMap.draw(), thanks.
            // loadThumbnails
            function loadThumbs(list:Array):Void {
                // set stage size
                // create holder
                var holderMC:MovieClip = createEmptyMovieClip("holder_MC", 1);
                // populate images
                for (var i:Number = 0; i<list.length; i++) {
                    //attach item to the holder
                    itemMC = holderMC.attachMovie("item_MC", "item_MC_"+i, i);
                    // size of the loader panel
                    itemMC.loader_MC.panel_MC._width = thumbWidth;
                    itemMC.loader_MC.panel_MC._height = thumbHeight;
                    // put thumbnail
                    //item name
                    itemMC.name = list[i].attributes.name;
                    //thumb links
                    itemMC.thumbLink = list[i].attributes.thumbLink;
                    //item number
                    itemMC.n = i;
                    // events
                    // over
                    itemMC.onRollOver = function(){
                        // fade in
                        ZigoEngine.doTween(this.loader_MC, "_brightness", 0,1 ,"easeOutExpo");
                        // tooltip if set to true
                    // out
                    itemMC.onRollOut = itemMC.onReleaseOutside = function(){
                        //fade out
                        ZigoEngine.doTween(this.loader_MC, "_brightness", -50,1 ,"easeOutExpo");
                        // remove tooltip
                    // press
                    itemMC.onRelease = function(){
                        // if theres thumbLink
                        // open link without zooming
                        if(this.thumbLink != undefined){
                            getURL(this.thumbLink, "_blank");
                            // stop movement
                            movingNav = false;
                            //record last Stage Width and Height
                            lastStageW = stageW;
                            lastStageH = stageH;
                    //put number if enumerates is set to true
                        itemMC.numero_TXT.text = (i + 1);
                    // type of sorting
                    if(sortType == "v"){
                        // Sort Vertical//
                        // pos
                        xPos = xIni+(thumbWidth+thumbMargin)*count;
                        itemMC._x = xPos;
                        itemMC._y = yPos;
                        //change row if stage is shorter than row length
                        if ((xPos + thumbWidth)>stageW) {
                            //reset count
                            count = 0;
                            // reset xPos
                            xPos = xIni;
                            // change row
                            yPos = yPos+thumbHeight+thumbMargin;
                        } else {
                            // inc count
                        }// if
                        // Sort Horizontal//
                        // pos
                        yPos = yIni+(thumbHeight+thumbMargin)*count;
                        itemMC._x = xPos;
                        itemMC._y = yPos;
                        //change column if stage is shorter than column length
                        if ((yPos + thumbHeight)>stageH) {
                            //reset count
                            count = 0;
                            // reset xPos
                            yPos = yIni;
                            // change column
                            xPos = xPos+thumbWidth+thumbMargin;
                        } else {
                            // inc count
                        }// if
                    }// tpye of sorting
                }// for
                // put holder for loaded big image
                imageMC = createEmptyMovieClip("loader_MC", 2);
                //start moving only the first time
                    movingNav = true;
                //enter event for moving
                holderMC.onEnterFrame = moveNav;
                //then center
                // put fixed mas for holder
                // if s not set to full screen
            • 3. Re: Images load and shakes screen
              the first problem i see is the is no panel_MC in your load target once loading starts.  so, setting that width/height does nothing useful.
